Question about Phoenix Technologies ImageCast (ax-200xx1t-0100) for PC
Not recognise network card
Image Cast worked fine with Windows XP SP2. Have upgraded to SP3 now my boot disks don't recognise the net work card. Is it a non compatability issue with Win XP SP3? I have had trouble with other older software with the upgrade to SP3.
    Scholar:
  • 155 Answers
Get the SP2 back since you have worked with that well. If the win Xp still suggest for updgrade to Sp3 express you can ignore it anyway. Just click cancell to any install command from the XP SP3 xpress.
Hope it might help you.
Posted on Jun 22, 2009
Should I buy a new router or upgrade OS?
Well, I find Verizon's statement rather confusing. The OS really has little to with actually connecting to the router and getting an IP address for access to the Internet. Now, trying to use an older browser to actually get INTO the router may be a bit more of an issue. Older browsers may not be compatible with the Webpage that Verizon uses for the router access. You say that the VAIO has Windows XP SP2. Is there some reason why you never upgraded it to SP3? SP3 provides a big upgrade to the OS and there are hundreds of other security patches that followed SP3. Without it, the OS is dreadfully out of date, and this may be more of an issue than the simple fact that it is Win XP. I say this because I have four PCs running Windows XP, and four running Windows 10 on my Verizon FIOS router right now. Two of the XP machines are wired to the network and two are wireless. So I can vouch that Windows XP itself is not the disqualifying issue. If you could provide more information on what you tried to do and what the results were I could possibly be of more assistance. Something tells me the folks at Verizon just didn't want to work with you or their current expertise doesn't go back far enough to relate to Windows XP anymore.
Nov 04, 2015 | Sony VAIO Computers & Internet
Tip
Perform a Custom Install to Upgrade from Windows XP to Windows 7
TIP1: If you are running Window 5 (XP) even with SP3 you will most certainly require a Custom Install, this is a 5 step complex process so don't rush it, to upgrade to Windows 7 if you just go ahead and expect that the upgrade CD will do everything for you dissapointment will most certainly be your results.
You will need at least 1GB of RAM ( or 2GB if you want to use the Windows (x86) 32-bit XP compatibilty mode on Windows 7 if your hardware won't support hardware assisted virtualization technology then this mode is not for you so 1GB will be fine) and a 1GHz processor and 16GB of free hard drive space if you don't have these forget it. Also you will require a graphics card that supports Aero for full use of all Windows 7 functionality so you might want to consider a new AGP graphics card as well your choice.
There will be several driver issues with webcams and other devices that will not work after the upgrade run the Windows 7 upgrade advisor tool before you even attempt it, you will also require the Windows Easy Transfer Tool later on so download this now.
I suggest that you first create a drive image using Ghost v14.0 and save a good image of your old WinXPSP3 partition prior to the upgrade. This will be your safety net restore points can't help you here. Its also worth using the preboot antivirus scanner bundled with Ghost before the upgrade you can use my autoupdater Antivirus Defintions CD creator to ensure you can scan with the latest defntions, download this from either LINK1 or rapidshare LINK2 these are posted exclusively for Fixya users.
Follow these instructions HERE in this PDF to assist you you will require an external USB and the I386 cabinet files from your OEM preinstalled version or from the original WinXP CD and the Windows 7 upgrade CD.
Also your WinXP must include the NET. Framework v2.0 x86 (32bit) runtime files and at least SP2 prior to the upgrade, I suggest you check using these NET Framework check tools to see what version you have. to check your service pack type c:winver at the run prompt
TIP2: If you have DRM (digital rights management) protected files from iTunes or similar download sites check that these can be restored after the upgrade if not back these up first as a matter of course.
TIP3: The upgrade from Windows Vista (v6.0) is a bit easier so if in any doubt upgrade to Vista first then Windows 7, if you miss out a step you can render your PC useless hence the first image step is highly recommended if the upgrade fails.
Good Luck !
on Dec 28, 2009 | Microsoft Windows XP Professional SP3 Full...
Front buttons don't work on CF-19 (MK2) After upgrade from xp sp2 to xp sp3!
From the description, the laptop will only support SP2 the only suggestion I can offer is format the hard drive and reload your original disc to get the front controls back.
Apr 26, 2012 | Panasonic Computers & Internet
The Pinnacle Studio which worked on Windows XP does not work on Window 7. What upgrade software should i get?
I think the best option for you is to Upgrade to Pinnacle Studio 14 which is $0, or Pinnacle Studio 14 Ultimate, which costs $70. An upgrade is cheaper than buying the entire version which will cost you about $130. The upgrade will work with Windows 7, Windows Vista (SP2), Windows XP (SP3).
On the other hand, if a program cannot be run under Windows 7 because of compatibility issues, you can right click on the executable file that will start the application and click Properties. Select Compatibility tab and check the Windows version you know the program worked with before. This will make it run as if it was running in Windows XP. You can find more about this Compatibility issue on Microsoft website: http://windows.microsoft.com/en-AU/windows-vista/Make-older-programs-run-in-this-version-of-Windows
Dec 08, 2010 | Pinnacle Dazzle DVD Recorder
I wan't the product key for service park 2
I recommend you to Purchase a key. Its good in the perspective of System Security and Stability. You will be able to get Online updates(Patches, Other Security Updates) as well as Online Customer Support with Upgraded Software. From here you can do that easily. Windows XP Home Page. If you just want an Upgrade to your Previous product, then Just download and install the Service Pack2 (Now its time to upgrade with SP3 after you have upgraded to SP2. But still SP3 have compatibility issues with Hardware, Drivers and Applications) SP2 SP3 ISO
However if you do not want to install a Pirate Version or need a Corporate key (Fixya does not Recommend Piracy), browse here. Alternate Link.
Please be kind enough to rate the answer if it solves the issue. Feel free to contact me if you need further instructions. Thanks for Contacting Fixya!
Jun 12, 2010 | Microsoft Windows XP Professional With...
I have a new dell desktop w/windows 7 and have this wireless adapter i have tried the driver downloads from belkin but it still will not work
try this one:
1. right click on the driver installer (.exe file) then choose properties.
2. click on compatibility tab.
3. on compatibility mode, check "Run this program in compatibility mode for:"
4. choose between windows xp sp2 or 3 (sp3 usually works fine.), or windows vista sp1 or 2 then click apply.
5. run the driver installer, and see if it solves the problem.
let me know if it helps. thanks!
Feb 23, 2010 | Belkin Wireless-N USB 2.0 Adapter
Changing Windows Disk XP Home Edition/SP2 to SP3
Try downloading SP3 again and save to desktop, then re-install (replacing 1st. installation). There might have been a glitch in the first download.
Oct 14, 2009 | Computers & Internet
PC dosen't play sounds occasionally
heres a suggestion go back to xp service pack 2. service pack is very easy to use and more compatibility than sp3. right now my 10 pc's are all xp sp2 and they have no problems about the sound.hope that helps
CHARCOIS
Sep 14, 2008 | Computers & Internet
Scanner
Go to this link. Select Windows XP in the Select OS box. You will see Canon's printer driver for the BJC-2100, and under 'Software' you will see ISScan_v350.exe which is actually the driver for the IS-22, compatible with Windows XP.
Install and download both files on your computer. I know that Windows XP has a driver already for the BJC-2100, but it may not work properly with the IS Scan driver.
May 15, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Boot cd-rom type:cd-rom/non-emulation booting
No, it's because Microsoft changed the way boot CDs work with SP2. You need an old CD (Windows XP SP1). I had the same problem here, notebook without floppy, it won't boot from the newer XP version CDs (SP2 or SP3) - but an old SP1 CD works!
(Those were all original Microsoft CDs, and the SP2 / SP3 CDs boot just fine on several other PCs I tested. It's just that some old hardware has a problem with the boot mode used on newer Windows CDs.)
Sep 20, 2007 | Computers & Internet
Computers & Internet Logo
90 people viewed this question
Top Phoenix Technologies Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a Phoenix Technologies Computer and Internet Expert? Answer questions, earn points and help others
