Question about Kicker Solo-Baric L7 S15L72 Car Subwoofer
Diaphram replacement Im looking for a replacement  diaphram  for a L7 12 in solobaric sub  my friend burnt his coil and im going to replace it for him but i cant find a place to order the from
    New Friend:
  • 101 Answers
i hope this helps.if you burnt out a coil chances r u might ve warped the basket or magnet . check that first. rating please
Posted on Jan 23, 2008
Are sony xplod 1100 watt 10'' subs 2 ohm stable
No keep on trying end blow everry thing up, Buy some real subs.
Nov 29, 2012 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
Well its not really the fuel tap that im looking to change but the diaphragm need changing so can someone explain to step by step to changing the the diaphragm?? and do i need a special silicon or oil to...
Hi Im not 100% certain what the hyosung diaphram looks like, but most are held in with 4 small screws holding the plate where the vac line goes. There will be a spring and plunger activated off the centre of the diaphram. This should come with the new diaphram.
You will need to remove the fuel tap first, or have the tank upside down on something soft.
You are only dealing with a few screws and a couple of parts, so just go slow and remember how it came apart.
a thin smear of rubber grease my help fit the new diaphram, do not use silicon, it can stop the diaphram moving and is not petrol proof
Aug 10, 2010 | Hyosung Comet 250 Motorcycles
XM-2002GTW Car Amp: i have 2 dual 2-ohms solobaric speakers and im try...
I researched your amp and it looks like its not even 2 ohm stable :( the problem with these companies is they lable there amps 1200 watts MAX, that means they tested the amp in a perfect enviroment and the amp fried somewhere in the ball park of 1200 watts, your best bet is to save your money and buy a nicer amp that is two or one ohm stable... that being said the best way to wire your subs is in series
May 17, 2010 | Sony XM-2002GTW Car Amp
How do you hook the wires into the back of the speaker so that the voice coils will function corectly
Without knowing what voice coils you have on your sub and what ohm load you are trying to get your amp to, there is no way to tell you the exact way you will need to wire your solobaric. Heres a great link that will show you all the different variations you can use and the resulting ohm loads:
Sep 28, 2009 | Kicker S15L7 Car Subwoofer
I have a 1990 GSXR 750 that will not sart
check to see if you have power ( + ) running were it suppose to go ,then check your ( - ) to see if everything is tight . Look for burnt wires , or check your fuses. check out the coils,and there sparkplug wires,and also the wires running to the coils.See if you got to replace some ( burnt out parts) use a tester to see if you got fire running to were it suppose to go.check GAS flow.
Mar 26, 2009 | 1990 Suzuki GSX-R 750 L
Engine lite, detonation problem, rattle sometime when accelation
o2 sensors and/or ignition coil(s). they prolly burnt out your catalytic converter and thats why you hear rattles. same problem but im buyin a new one so what do i care - let the dealer deal with it. 02 sensors are like 80-1xx bucks and coils are like 50 a pop. not too expensive just look around and get a handy friend to replace it. shops will ******** you and charge ungodly amounts. good luck!
Jan 20, 2009 | 2003 Nissan Maxima
Solo x 10 dual 2 ohm smells burnt and smoke
there is no such speaker as a solo-X L5.
The Solobaric L5 is 450Watts RMS and 900 Peak.
Check your documentation, and no warranty except Massive Audio covers Burned Voicecoils as it is deemed customer abuse.
If it is a typo, and not an L5, your combination (as long as each is level matched) should be ok to run on that sub. When wiring it as you describe, the two amplifiers need to be identically matched in order for both coils to play at the same level.
Seek professional installations so your warranty is intact.
Dec 21, 2008 | Kicker Solo-Baric L5 Car Subwoofer
How to wire up my kicker 12inch solobaric l5 2ohm to my zx500 2ohm mono amp. should it be ran in parallel or series? what is the best suggestion
Well first of all all solobarics are dual voice coil so you have 2 2ohm voice coils so if you wire them in parallel the sub will be pulling a 1ohm load wich would in time blow out your amp. So you want to wire both voice coils in series to produce a 4ohm load.
Oct 25, 2008 | Kicker Car Audio & Video
no as the the voice coil has been burnt out there is no way u can repair them. didnt you test the subs out before you bought them? remember if u buy used den allways check em out!
Jul 12, 2008 | Kicker Solo-Baric L5 Car Subwoofer
Blown solobaric?
how did he messed up? anyways, if u push the cone of the sub down and u hear a sound like "TUN!" its most likely ur sub is irremediably damaged. The cone needs to come up perfectly as a good sub would do. I need to know exactly what ur friend did b.c it is quite weird to mess a good sub by slightly switching cables
May 24, 2008 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Kicker Solo-Baric L7 S15L72 Car Subwoofer Logo
100 people viewed this question
Top Kicker Car Audio & Video Experts
Tygh Duval
Tygh Duval
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
