Question about LG 32LG30 32 in. LCD HDTV
23" LG with green border and dark colors surrounding faces
I have 23" LG about 3-4 yrs old. It comes on instantly but the picture has shades of red and blue and a green border making faces sometimes stand out but everything around them is dark colored. It has done this for several months, but there is often a little click and the picture is fine. The next time it turns on, same old problem and the good picture no longer comes back.Any ideas?
SOURCE: LG tv color problem
i had the same problems, called LG customer service, advise to check components cable, and make sure they were all blugged in correctly, ans sure engough, the red cable was discontected ,and after correcting that, the problem was solved
Posted on Oct 01, 2007
  • 6 Answers
SOURCE: Vertical bar on Daewoo Plasma screen
YES YOU HAVE DRY JOINTS UNPLUG FROM POWER SUPPLY REMOVE THE BACK/ INSIDE YOU SHOULD SEE AT THE BOTTOM SEVERAL RIBENED CONECTORS FROM THE SCREEN ITSELF? UNDERNEATH YOU SHOULD BE ABLE TO SEE 2 OR 4 COMPONENTS CAREFULLY APPLY A HOT SOLDERING IRON AN SOLDER THE ONE THAT YOU ARE HAVEING PROBLEMS YOU SHOULD NOW HAVE FULL PICKTURE AGAINE ANY PROBS email me andymay2@msn.com
Posted on Mar 23, 2008
DR NITIN
  • 221 Answers
SOURCE: Green shadows in dark scenes
You should contact Service Center to resolve this issue.
Posted on Jun 18, 2008
  • 197 Answers
SOURCE: lg plasma tv lost red color
bad component cable
Posted on Jun 07, 2009
freelance-au
  • 131 Answers
SOURCE: LG 60PC1D making clicking sounds
Hi
A common problem for these is bad capacitors in the power supply, Remove the back from your Tv and look at the power supply on the left hand side.
You will see roughly around 9 x capacitors that are bulged / domed shaped on top usually these are valued at 3300uf 10V any that have bulged or leaked a brown like substance should be changed.
This will cure the problem as they overheat being sat next to a heatsink that gets very hot!
Try and change them for the same 3300uf but a higher voltage.
Hope this helps
Please rate my reply ++++
Posted on Apr 05, 2010
What is the purpose of an R2 filter?
Each filter intensifies its color and darkens others, especially the color opposite on the color wheel. They're not of much use in color photography, unless you want weird color casts, but they come into their own in black&white photography.
For example, a red filter intensifies red and darkens blue. It can make a sky look almost black, making clouds pop out. Similarly it can darken foliage. A green filter on the other hand will brighten foliage.
If your camera can take black&white photos, try taking pictures of a red rose with green leaves with and without the filters. With one combination the rose and the leaves will be the same shade. With a red filter the rose will be bright against the dark leaves. With a green filter you'll get a dark rose with bright leaves.
With digital photography you can achieve the same effect in postprocessing, but some times its easier to get the result in camera.
Apr 28, 2012 | Quantaray 55mm Red R2 Lens Filter
LG Television color is all green shades
If your picture looks green on all inputs and it slowly degraded, then you have an optical block problem. not repairable.
Dec 28, 2011 | LG RU52SZ30 52" Television
Contrast really dark but seems to improve after the tv has been on several hours
Hi:
You may have a problem with the inverters in the unit, they are responsible for lighting up the back panel. Check or have checked the power supply voltage to the inverters, should be around 18-24 volts DC. Also leaky capacitors on the power supply will cause this issue as well as leaky or puffy capacitors on the inverter.
Sep 08, 2011 | LG 32LG30 32 in. LCD HDTV
My plasma picture looks green
You are proberbly using RGB leads, wich is red green blue, each colour runs through each cable, have a look at your cables maybe one is loose, or damaged. check on both ends, but the cables MAY NOT be red green and blue, but the terminals that the plug into will be.
Jul 05, 2009 | Hitachi 55HDX99 55 in. Plasma HDTV
Picture calibration settings for 42lg70
Picture Menu
Picture Mode: Expert1
*Backlight: 16
*Contrast: 83
*Brightness: 53
Sharpness: 50
*Color: 55
*Tint: 0
Expert Control
  • Fresh Contrast: Off
  • Noise Reduction: Medium
  • Gamma: Medium
  • Black Level: Low
  • Real Cinema: On
  • TruMotion: Low
  • Color Standard: HD (N/A w/HDMI)
  • White Balance: Warm
  • **Method: 10-Point IRE
    • 10 IRE
      • **Red: 1
      • **Green: 2
      • **Blue: -16
    • 20 IRE
      • **Red: -6
      • **Green: 0
      • **Blue: -7
    • 30 IRE
      • **Red: -5
      • **Green: 0
      • **Blue: -4
    • 40 IRE
      • **Red: -8
      • **Green: 0
      • **Blue: -4
    • 50 IRE
      • **Red: -4
      • **Green: 4
      • **Blue: -4
    • 60 IRE
      • **Red: -6
      • **Green: 6
      • **Blue: -5
    • 70 IRE
      • **Red: -8
      • **Green: 3
      • **Blue: -10
    • 80 IRE
      • **Red: -8
      • **Green: 7
      • **Blue: -16
    • 90 IRE
      • **Red: -9
      • **Green: 5
      • **Blue: -18
    • 100 IRE
      • **Red: -10
      • **Green: 4
      • **Blue: -9
Color Management System
  • Red Color: 0
  • Red Tint: 0
  • Green Color: 0
  • Green Tint: -15
  • Blue Color: 0
  • Blue Tint: 11
  • Yellow Color: 15
  • Yellow Tint: 2
  • Cyan Color: -15
  • Cyan Tint: 0
  • Magenta Color: 0
  • Magenta Tint: -1
lg70 nice tv excellent processor just to bad there is no intensity control on color management oh well still better than what the three s are pushing block out the hype lg will be number 1 in a few years haters are starting to come around and well leds coming,
p.s. i dont work for lg just tired of losers bashing stuff because they dont own it.
im isf certified those settings are right on the money straighter than a ruler
Oct 05, 2008 | Televison & Video
Dark picture, mostly red colors
if you set is over 4 yrs old the tube is at fault,you may try to adjust the screen settings.
Mar 27, 2008 | Zenith B25A76R 25" TV
Sony Trinitron K29 inch CRT TV screen shows green shade!
i have the same problem with my sony trinton tv 36 inch if you know how to fix this please email me on amir.dhawan@gmail.com
Dec 30, 2007 | LG Flatron 295LM 22" LCD Monitor
Red/pink shades in dark areas happens only 6ins down from top
Sounds like you have a cap that leaky or a ic thats getting hot,
if you want to try and fix it yourself get a can of freeze it
http://www.chemtronics.com/products/product.asp?id=78
and when the problem appears spray the can on each (ic or cap) part till the problem goes away.
Dec 03, 2007 | LG DU-42PY10 42 in. Plasma HDTV
No Picture
Did you have color problems in past? Most of these sets have convergence problems. Amps goes out. But you should have seen some type of distortion from color, red,blue, green. If no color problems then maybe vertical ouput out or horizontal output bad.
Sep 09, 2007 | Hitachi Director's Series 65XWX20B 65"...
LG 32LG30 32 in. LCD HDTV Logo
105 people viewed this question
