Hello sir, that is a on going problem with power washers the pump not working, than works sporadically. the main cause is leaving the pressure hose hooked up to the machine over a long period of ,not draining hose & machine, in the winter time the hose & pump willfreeze causing hose & pump to expand and burst. build up of calcium deposits from hard water clogging up pump nozzle,valves in the gun handle,clogging hose fittings and screens.one of these has to be your problem.you can find a parts brake down at KARCHER.COM.orRJ BOWERS.COM . and manuals,these are good info,sites,hope this helps, MrFixIt,oh could you please rate this solutions.thankyou ---
Was using my power washer and ran out of gas, filled tank and when I tried to restart, the pull got...
(More)
Was using my power washer and ran out of gas, filled tank and when I tried to restart, the pull got stuck. I have only used it twice. It has not more then 6 hours of use. Any recommendations on what I should do? By the way, can you confirm the type of oil the washer uses. Is it a special oil or a standard used in other equipment?
Pressure washer with Honda GX160 5.5 HP OHV-Starts easily and idles fine but when load is...
(More)
Pressure washer with Honda GX160 5.5 HP OHV-Starts easily and idles fine but when load is applied(i.e. start to pressure wash or move to full throttle)engine dies. Fuel fills bowl/sediment cup readily when valve is turned on. Bowl/sediment cup have been cleaned and carburator fuel path reemed with fine wire. Any suggestions?
Motor stops, washer was working , full level in oil and good oil. Don't starts again, apparently...
(More)
Motor stops, washer was working , full level in oil and good oil. Don't starts again, apparently barred engine, does not "turn" around.
