Question about Toshiba Satellite Pro 6100 Notebook
One of five PCs not connecting to Belkin 54G router
We have a Belkin 54G router. Two desktops are hardwired and work fine. We have three laptops. Two are connected and working fine. The third has been connected in the past but after a IP outage today when all five computers were disconnected now cannot reconnect. This laptop stays stuck in "acquiring network address". We have disconnected, repaired, given it manual IP addresses, nothing seems to work. Any suggestions?
  • heuts Jun 22, 2009
    Thanks. Using a LAN cable we were able to connect to the internet and get the IP address. Wirelessly, with the IP addresses provided, it connected to the router, but we were not able to access any web sites (no internet access).
    What could we do now?
I would connect it to the router using a lan cable to verify that it will get a IP address and connect to the internet. Write down the IP information and make a static wireless connection with that info. It should work hardwired and wirelessly with this info. If it doesn't work wirelessly you may have a bad wireless card or you may find that their is already conflicting static IP info in the connection that has to be removed. Make sure that on your internet protocol (TCP/IP) properties that you have selected "Obtain an IP address automatically" and Obtain DNS server address automatically". Clear any settings that you may see there.
Posted on Jun 22, 2009
My Dell desktop using Windows XP can't connect to my Belkin 5720 router but my laptop still works?
This sounds like a hardware failure, but just in case go to your computer Control Panel-Network Connections(Network and Sharing Center for Vista and above), and check your Network adapter settings. If your Network card is not showing, you may have a driver issue, or a bad NIC (Network Interface Card). It shouldn't matter that your router says" wireless hardware not detected", because you are hardwired from the computer to the router. I would check to see if you may have turned off, or blocked Ethernet connections on your router, I would then change my Cat5 (Ethernet) cable, and finally open the desktop and change out the NIC (Network Interface Card).
Mar 24, 2012 | Belkin Computers & Internet
How do I put security on my Belkin 54g router
You set your security by enabling WEP.
When you get in the interface to configure WEP, set a pass phrase. Write down the 3 numeric keys it generates. Then connect to the wireless using your laptop, etc. When it asks for your passkey, do not enter the pass-phrase; enter one of the three keys that were generated by the router. That's the biggest mistake people make when trying to get wireless to work.
Oct 06, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Problem connecting to router
Log into the Belkin router and make sure that the DHCP services are running. If it is, and you still are not getting addresses, perform a factory reset of the router. There is a link in the web management console to do this.
Jun 22, 2009 | Toshiba Satellite Pro A200-EZ2204X...
Slow ping time
Ping depends on the server network and not the configuration of the laptop.If the ping varies, you need to check the network configuration.
Any further help, let me know.
Thanks for using "Fixya".
Jun 17, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Wont connect to belkin 54g with wpa security applied
Please try using Wireless 'G' mode only in the router. Also, try using 'TKIP' and not TKIP+AES for encryption.
Please rate this solution, if it works for you.
Jun 01, 2009 | Dell Inspiron 6400 Notebook
Loosing connection every 10 to 20 min...
You did not mention which version your router is running (V3, V4, V5).
I would blame the connection loss on a flaw in the firmware. Go to the belkin site and see if there is a new firmware available for you: http://www.belkin.com/support/article/?lid=en&pid=F5D9230-4&aid=8593&scid=222
Looking around I found some people had similar problems: http://cnet.nytimes.com/routers/belkin-wireless-g-plus/4505-3319_7-31489123.html
If this helped, then please leave a comment here, so others might find a solution as well.
Dec 28, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Router stoped working
yes new roughter netgear is easy plug in play vs linksys new model u can try hard reset button on back if your router has one still dont afte rthat cheak dns server code if u need one they woulve told u his to at start maby cheak for latest firmware for it if any is out ok otherwise ya get upgrade be faster then belkin
Oct 06, 2008 | Belkin (F5D5231-4) Router
Unsecured network shows up as secure
The person who has the router attached to there computer must enter the IP for the router and you will be able to reset the password to enter the router. If you need Help doing this I can solve this issue with you through my computer.
Hope This Helps
All The Best,
RCF
May 28, 2008 | Gateway Belkin 54g Wireless DSL/Cable...
Cant connect
Hi! Did you go into the router configuration through IE (Internet Explorer)?
May 24, 2008 | Gateway Belkin 54g Wireless DSL/Cable...
Toshiba Satellite Pro 6100 Notebook Logo
310 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
