Question about Electrolux 24 in. EDW5505EPS Stainless Steel Built-in Dishwasher
My DX302 dishwasher wont heat the water, the heating element is ok.
Yes I had the same problem with the DX302. One of the solder joints on the relay was cracked but hardly visable. Resoldered it and no problems.
How to do it:
Make sure you turn off the power at the wall and pull out the plug. To get to the circuit board remove the screws on the inside top of the door and pull out the front panel (where the buttons are). Press the little clips and the white box containing the circuit board comes free. Remove all the plugs and lever open the small clips holding the box shut. After you open the box pull the circuit board up and have a look at the contacts under the black little box (relay). Use a soldering iron and some flux cored solder and redo the joints. Put it all back together and turn on to see how it goes.
Worked for me.
All the best......
Posted on Aug 05, 2009
The heater relay n/c leg had melted the solder off the board, I re soldered the leg laying it on a bit thicker. cheap fix.
Posted on Jun 24, 2009
Why does my dishlex dishwasher DX302 not heat
Dishwashers require a gap for air flow all the way around, not tight fit.
If it works when out but not installed, check the water pipe is not kinked and the door switch is working properly.
Sep 07, 2017 | Dishwashers
I have a dx302. its not heating the water or drying.
download this manual...
http://epubl.luth.se/1402-1617/2006/118/LTU-EX-06118-SE.pdf
Aug 22, 2008 | Electrolux 24 in. EDW5505EPS Stainless...
DISHLEX DX302 REPLACE HEATING ELEMENT
Remove the device and then restart again
Jan 25, 2014 | Dishwashers
Hi I have a Dishlex DX302. After an intense wash it leaves a film of scum / powder on the dishes and sometimes does not wash properly. I have tried using various soaps and also tried to use a dishwasher...
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Asker
Mar 17, 2011 | Electrolux 24 in. EDW5505EPS Stainless...
Dishlex dx302 not drying dishes. Doesn't seem to be as hot as usual when opened immediately after finished. Steam not present.
Check your heating element..
How to Replace the Dishwasher Heating Element
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Mar 04, 2011 | Dishwashers
Electrolux dishwasher DX302 isn't drying the dishes. What might be wrong?
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
heatman101
Aug 27, 2010 | Dishwashers
F1 error code -wont advance after it hits wash cycle--heater ohms out ok-any solutions?
F1 Water heating fault, selected temperature not reached within 60 minutes · Incoming water temperature too cool
· Heating element burned out
· Thermostat defective
Feb 02, 2010 | Asko D1776 Built-in Dishwasher
Water doesn't heat up
The most common reason for no heating is the failure of the heating element which is located beneath the lower spray arm. Inspecting it for breaks and damage would be the first step. If you do not see obvious damage, after triple checking that poser is off to the DW, pull the kick panel from your DW and check where the heavy gauge wires connect to the two terminals of the heating element.
Please post back here with further questions or what you found, OK?
Dec 14, 2008 | Kenmore 24 in. 17462 / 17464 / 17469...
No heating in dishwasher
Do not plug it into hot water UNPLUG. It needs cold water going through the system.
It may be the heating element or just a loose connection on the computer panel.
If you have any Questions plese do not hesitate to ask
Dec 03, 2008 | Dishwashers
Electrolux 24 in. EDW5505EPS Stainless Steel Built-in Dishwasher Logo
694 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Starnley Johnwells
Starnley Johnwells
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
