Question about Toshiba Satellite P105-S6177 Notebook
Turn on laptop and i get a black screen
It acts like it going to boot but it goes to a black screen with the letter j in the upper left hand corner.. i used the recovery disk and it could not find file. it said to got to start and search but i cant even get that far.
  • alex94539 May 11, 2010
    Whats the model number?
  • Premi Feb 01, 2012
    did you find a solution for that black screen and letter J on the right corner !!!!! I have the
    Same Problem with my toshiba , need help ... kindly reach me at premicool@gmail.com
    Thank you.
    Sergeant:
  • 280 Answers
If it is Vista, insert the installation disc and go into restore. Make a system restore. In case of XP go into safe mode and do a system restore
Posted on Jun 22, 2009
How do I fix when I touch a key to put in information and it prints a different number or letter than the one touched
Here is a way to recalibrate the touchscreen without having to go through the menus:
If your Nuvi has the problem that when you press one key but another key is highlighted, then either your touchscreen is defective or it is miscalibrated.
For example, pressing the letter "A" on the QWERTY keypad, actually highlights the letter "S" or "Q" or "Z". On the non-QWERTY keypad, this may show up as "B".
Method #1: If you can get to the main menu, press the "wrench/tools" icon and then the "Display" icon. Now press the calibrate screen button and go through the entire procedure of pressing each dot as it appears on the screen until it says "Done".
Method # 2: Follow this procedure if you can't get to the main menu or any menu thereafter.
First, turn the unit OFF.
Nuvi 3xx & 6xx Series: Hold down the on/off power button and don't let go of it.
On the screen it will say "Pre-boot mode"..... keep holding the button down..... after some time you will eventually come to a screen with dots. If the screen says "Loading" and does not go to to the calibration screen with the dots, you will need to connect the Nuvi to a PC with a USB cable and rename the file "GUPDATE.GCD" within the Garmin directory to "GUPDATE.OLD". Once the file has been renamed, repeat the above procedure.
Once you reach the calibration screen, now you can let off of the on/off power button. Go through the entire procedure of pressing each dot as it appears on the screen until it says "Done".
Nuvi 2xx/2xxW Series: Turn the Nuvi off. Place your finger on the upper left-hand corner of the screen and then slide the on/off power switch to the left and hold until you see the calibration screen. Note: Some 2xxW models require the procedure below for the 7xx.
Nuvi 7xx Series: Turn the Nuvi off. Touch the screen anywhere and keep your finger there while moving the on/off switch to left (don't wait for Garmin logo to come up) and then quickly moving the switch the right (lock position). After a short while, you will reach the calibration screen. Go through the entire procedure of pressing each dot as it appears on the screen until it says "Done".
Nuvi 8xx Series: Turn the Nuvi off. Remove the battery from the Nuvi for at least 10 seconds. Press and hold your finger on screen, while putting the battery back in. The Nuvi will boot-up and you should see the text "Pre-boot Mode" appear on the screen. Continue pressing on the screen until pre-boot goes away and the progress bar appears. Now remove your finger. After a short while, you will reach the calibration screen. Go through the entire procedure of pressing each dot as it appears on the screen until it says "Done".
Nuvi 11xx, 12xx, 13xx, 14xx, 16xx, 24xx, 25xx Series: Turn off the Nuvi. Place your finger on the upper left-hand corner of the screen and then push down on the power button to turn the unit on. Release the power button when the Garmin logo appears. Continue to press on the upper left-hand corner of the screen until you see the calibration screen.
Once completed the Nuvi will display Calibration Complete
This will recalibrate your touchscreen to the LCD display.
If this doesn't resolves your problem. then your touchscreen may be defective.
Oct 10, 2015 | Garmin Nuvi 1350LMT
Garmin nuvi 1200 wont let me type the right letters
Try recalibrating the touchscreen. The procedure can be found here:
http://www.sharc.net/discus/messages/6/77.html?1315261162
Press each dot to recalibrate the screen.
Feb 28, 2013 | Garmin nuvi 1200 Car GPS Receiver
White cursor in upper left corner
Remove ALL media, DVD, CD, USB, etc. Unplug, remove battery, plug in, reboot, at boot start tapping F-10 to do a System Restore, use this procedure to restore to a date before this issue: http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&prodSeriesId=3832468&objectID=c01634414#A1 Post results.
Feb 02, 2013 | HP Mini 1000 Netbook
It wont boot, goes to black screen with whit blinking dash
Yes, this sounds like the traditional black screen issue, but it's different! This machine is a Dell Dimension 3000 with XP. System won't boot. After Blue Dell BIOS splash screen with F2 & F12 options, it just goes black. There will ultimately be a white cursor in the upper left hand corner. I can edit BIOS with F2, I can get in to the boot menu with F12, but I can't do anything after that. I can even get in to the Safe Mode menu (F8), but it never boots.
Aug 14, 2011 | Gateway LT2001u Netbook
When booting up, the monitor status splash shows up. Then it goes into a black screen with some small white boxes in upper left-hand corner. It takes forever to display the log-in screen, probably more...
Switch ON the PC, boot the PC in 'Safe Mode' by continuously tapping F8 button after you switch On.
Let windows boot in Safe Mode and log in to windows.
Go to 'Start'--->Programs--->Accessories--->System Tools--->System Restore
Here you will have to check "Restore computer to an earlier time' and click Next
Now you will find one Month Calendar window with Dates below, go to the previous month by clicking the '<' sign in the upper left hand corner of the Month Calendar and select any date that you see in Bold.
The detail of that particular date should show "System Checkpoint" and time on the right hand side box. Select that date.
Now, Click on Next and System Restore will start and windows will take a reboot.
After reboot your problem should be resolved.
Please leave a vote if you like my answer
Apr 03, 2011 | Computers & Internet
My dell laptop wont turn on the screen is black with a little line blinking in the upper left hand corner
When your computer is booting up you have the option to press F2 or F12.
PRESS F2 -Set Up
When your in the Set Up go down to Boot Device Configuration(BDC)
Now under Hard Disk Boot Priority
You Will see first boot device
second
third
and boot other device
For the first boot device select "HARD DISK"
After you have made the first boot device hard disk press F10 to SAVE and RESTART
Dec 06, 2010 | Dell C500 Notebook
A black _ in the upper left hand corner (size of underscore)
It is what we call a "Shatted Pixel" and you can fix it by flashing your screen
Dec 22, 2009 | Dell Computers & Internet
Laptop screen stays blank at boot
Try reseating the memory card.
See if that works.
Jun 02, 2009 | Acer Aspire 4315 Notebook
Letters in upper left hand corner of screen
You may find it in your "Menu" button on your remote, search for anything similar to "HD Logo" and turn it off. Failing that, make sure it isn't stuck on with transparent plastic, haha.
Sep 07, 2007 | Sony FD Trinitron WEGA KV-32XBR400 32" TV
Toshiba Satellite P105-S6177 Notebook Logo
162 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
