Question about Dell Dimension 4600 PC Desktop
Power supply or motherboard dell 4600
My dell dimension 4600 has been sluggish and freezing up lately, i downloaded my windows updates(xp) turned it off, unplugged opened it up and did a cursory"dusting" with canned air. I touched almost nothing just opened the flap on the fan then closed it up and when I went to turn it back on NOTHING. Well almost nothing the small green light on the front is on and the fan in the power supply is on. I've been reading various websites to figure out what is wrong and the likeliest culprits are the power supply and the motherboard. I really am little more than a novice when it comes to pc stuff but I'm not afraid to try if the instructions given are geared to a non techie. How do I figure out which power supply will work for my pc given that is an older model and where can I find clear instructions (with photos would be the best)? Or am I on the wrong track altogether?
  • adwyer67 Aug 27, 2009
    I have no sound do I require a battery and how do I install the battery.
  • 6,784 Answers
Ok, you stated that the power supply cooling fan was running at this time. unfortunately, this is not the power supply unit that has failed. the mother board has actually failed in this case. If the power unit was damaged, the cooling fan would not spin. You will need tp replace the mother board in this case. it has failed.
This is not a novice situation. we recommend a service tech for this type of repair. if it was a power supply issue, it would have been quite easy to replace but, this is not the issue here. it the mother board.
Posted on Jun 22, 2009
How can I jump the power switch?
Solid Amber Light on Dimension 4500 - Power supply is suspect ...
en.community.dell.com/support-forums/desktop/f/.../t/18332108?...
Dell
Feb 12, 2007 - 14 posts - ‎4 authors
I have a Dimension 4500 that is obviously a few years old. ... So when I push thepower button "on" now, the light is a constant ... I pulled of the 20-prong conection (to the motherboard) and jumped ... The fan itself can be replaced, if you're good at mechanical projects. .... And the computer started right up. Boot Up Problem With Dell Dimension 4500 - General ...
Sep 5, 2012
Dell Dimension 4500 won't power up - General ...
Oct 24, 2006
Dimension 4600 - Bad Power Supply or Power switch ...
Mar 27, 2006
On/Off butotn failure.. Please Help - Community
Mar 8, 2006
More results from en.community.dell.com
Dell desktop won't start with power button - Forums - CNET
www.cnet.com > Forums > Desktops
CNETAug 5, 2009 - My dell dimension 4500 was accidentally turned off at the power strip and ... There is a light behind the button but no lights on back of computer. ... I have a Dimension 2400 that I'm not using--could I try that power supply in it?
Dell Dimension 4600 won't power up {Resolved} - Virtual Dr
Feb 03, 2016 | Dell Dimension 4500 PC Desktop
Motherboard sound drivers for 845 pc model no DHM
You can download the drivers for Windows XP on the following link:
http://en.softonic.com/s/intel-845-sound-driver/windows-xp
Please inform me if you need the drivers for another operating system like Windows 7, etc
Jan 13, 2014 | Dell Dimension 4600 PC Desktop
High priority updates from microsoft fail to download
Try these links in the order listed:
support.microsoft.com/kb/910336
support.microsoft.com/kb/956705
-B
Dec 31, 2012 | Dell Computers & Internet
Need sound and vedeo driver for dell dimension 4600 motherboard
You can download the Drivers for Windows XP Operating System here:
http://support.dell.com/support/downloads/driverslist.aspx?os=WW1&catid=-1&dateid=-1&impid=-1&osl=EN&typeid=-1&formatid=-1&servicetag=&SystemID=DIM_P4_4600&hidos=NAA&hidlang=en&TabIndex=&scanSupported=False&scanConsent=False
Jun 25, 2010 | Dell Dimension 4600 PC Desktop
Have a dell dimension 4600. I have a blinking
The two biggest culprits would be:
I'd start with the power supply since it's cheap and easy to install.
Find a local computer shop that sells 'em.
Make sure they've got a 100% return policy.
Swap 'em, if it works problem solved.
If not it's probably the motherboard. You could always have a local tech check it out.
Make sure they provide FREE diagnostics. It shouldn't cost you anything to have ti looked at.
Jun 19, 2009 | Dell Dimension 4600 PC Desktop
Computer will not turn on
  • Blinking Amber/yellow: Initial state of LED at power up.
    Indicates system has power, but the POWER_GOOD signal is not yet active.
    If the hard drive LED is off, it is probable that the power supply needs to be replaced.
    If the hard drive LED is on, it is probable that an onboard regulator or VRM has failed.
Apr 28, 2009 | Dell Dimension 4600 PC Desktop
Slave drive into Dell Dimension 5100
Yes it does. It may not have an IDE cable if using SATA hard drive, but it does have a port on the motherboard to plug in the cable you take from your 4600.
Don't forget to rate your answers please!
Jun 07, 2008 | Dell Dimension 4600 PC Desktop
Dell 4600 motherboard
That particular Dell uses a power supply with non-standard wiring. The plug is the same size as an ATX plug, but it's wired differently. If you were to replace motherboard & plug in the standard power supply, it would damage the supply, or the motherboard, or both. Also, the front panel plugs (for power & power LED & hard drive indicator) are proprietary as well. Ideally you should replace it with another Dell Dimension 4600 motherboard. I've found replacements for reasonable prices on some of the auction places on the web. I recently replaced a failed motherboard in my Dimension 8300 with one I got from a popular auction site, I think my cost was about $59 plus shipping.
The other option would be to remove the hard drive, video card (if any), and optical drives, and consider a 'barebones' package from various sites such as geeks or newegg.
Jan 05, 2008 | Dell Dimension 4600 PC Desktop
Dimension 4600 cd/dvd drives not responding
Try uninstalling them in devive manager then rebooting and see
if they are reinstalled automaticaly as drivers should be in xp already.
Just right click on them and select uninstall.
If that doesnt work then try update drivers and let xp search online for them.
Failing that then try changing the cable thats attatched to the motherboard.
Hope that helps? :)
Jan 04, 2008 | Dell Dimension 4600 PC Desktop
Ethernet controller driver
i need an ethernet controller driver for my dell dimension 4600 the operating system is windows xp home edition
Sep 02, 2007 | Dell Dimension 4600 PC Desktop
Dell Dimension 4600 PC Desktop Logo
339 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
