Question about Kitchen Ranges
Control panel is no longer made for Tappan gas range, model 30-3989-00-97
  • 10,865 Answers
This is known as built in obsolescence. Unfortunately, your choices now are to either try to find a used identical range and remove the control panel, or get a different range.
Posted on Jun 22, 2009
TAPPAN GAS RANGE MODEL NUMBER MPF500PBWD
the owners manual will not give you any repair info. Only use instructions. Your model has an oven safety gas valve that opens only after the secondary pilot heats the end of capillary properly. You may need to clean/replace the pilot assembly OR replace the oven safety valve. If you need the valve, look on ebay because these things are over $275 from Tappan.
Aug 21, 2014 | Tappan MGF500PBW Gas Kitchen Range
Tappan gas range 50 deg. too hot
I was unable to find a photo large enough to see if this range has stove-front knobs or electronic controls. If it is equipped with a knob for oven control, pull the knob off and peer into the shaft to see if a slotted adjustement is visible. If so, you will need a small-bladed, long shaft screwdriver to reach and adjust it.
Jan 08, 2009 | Tappan TGF320 Gas Kitchen Range
Tappan Millennia range's baking component doesn't work.
Your ignitor has gone out or is no longer drawing enough current to open the gas valve. Replace the oven ignitor and it will fix your problem.
Nov 26, 2008 | Tappan TGF320 Gas Kitchen Range
Oven
Try using a lighter, the type used for grills. Since you can smell gas, the gas valve is working but the egnitter that gives the spark to ignite the gas is apparently not working.
Usually is it not the igniter but the controller that controls the igniter. If using the lighter as suggested, and it lites, you probably will have to replace the igniter controller for the range
Dan Sims
May 23, 2008 | Tappan TGF320 Gas Kitchen Range
F1 and F2
Here are the codes for Tappan ranges:
TAPPAN
Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F0 & F1 EOC (Electronic Oven Control) failure Replace Electronic Oven Control F2 Oven too hot Check Bake function, if OK, replace oven temperature sensor F3 Oven temperature sensor open Check oven temperature sensor, should be ~1100 ohms at room temperature. If too high or low, replace oven temperature sensor F4 Oven temperature sensor shorted Replace oven temperature sensor F5, 6, 7 EOC (Electronic Oven Control) failure Replace Electronic Oven Control F8 Lock switches Check switches and replace if necessary
Nov 06, 2007 | Tappan TGF363 Gas Kitchen Range
Tappan Gas stove
The pilot adjustment screw is located on the back side of the oven temperature thermostat. Lift the cook top to access it. Use a flat screwdriver to adjust... counter clockwise= bigger flame.
Aug 14, 2007 | Tappan TGF363 Gas Kitchen Range
Tappan Range Model TGF657BFWS
Delo, I am not finding that model number, what I have that is close is the model number tgf657bfw5, if this is your model number the F1 code is a bad electronic control, part number 318010300. If this is not your model number, just ignore this post...Catriver..post back
Aug 07, 2006 | Tappan TGF657 Gas Kitchen Range
Kitchen Ranges Logo
52 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
