Question about Frigidaire 24 in. FDB1050RE Built-in Dishwasher
Water not draining
The water will nt pump out!
  • 57 Answers
Take the cover off the inside off the dishwasher and remove the food scraps and roate the wire around and even use the palm of your hand as a plunger
Posted on Jun 22, 2009
I HAVE A FRIGIDAIRE, Mo#FRT18IL6JB3, WATER IS COMING INTO THE BOTTOM OF FRIDGE AND NT TO THE DRAIN PAN, I CLEANED THE DRAIN HOSE AND IT STILL IS NOT DRAINING, Thanks Dave
Your make up water solenoid valve is leaking by its seat and needs to be replaced. You should be able to find the replacement on searspartsdirect.com.
Sep 28, 2014 | Frigidaire Refrigerators
My dishwasher does'nt drain, how can I fix that?
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If it's still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Jun 08, 2011 | KitchenAid 24 in. KUDP01IL - Multiple...
3 area rugs wee washed but would,nt spin out . E20 kept flashing. I took all but 1 rug out machine finished cycle but still didn,nt wring out This has never happened before
there is a lint screen inside the water pump hose(the one that goes from the outer tub to the pump). if you have a port or access door to get to it remove it, if not you may have to remove the front panel to get to it. you could have debris blocking the drain and causing the computer to delay the spin process.
Feb 09, 2011 | Frigidaire Affinity ATF7000E Front Load...
The machine do not complet the cicle.in the regular cicle, the machine finnish washing but do nt let out the water and the cicle stop at this point
have a look and see if outlet pipe is kinked not allowing water to drain, failing this you may have a blockage in the pump system
Dec 17, 2009 | Washing Machines
Pump nt working proper.y
Check the auto level probe and box, also check the inlet solenoid, one of these three are not functioning.
Nov 17, 2009 | Astoria Argenta AEP-2 Coffee Maker,...
Does nt drain
Check the following to address this issue further.
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer or Control board
Replace if defective (note: uncommon problem).
Jun 19, 2009 | Bosch Dishwashers
I am having a problem with my water well pump ,i bought a new tank for the pump and it still is,nt pumping the water,i took the the pipes up and they were full of water,but the water isn,nt going in the...
did you replace the check valve?
and reprime the pump?
also if the screen at the bottom of the well is plugged you wont get enough volume too fill antthing,and the bladder tank should only run about 2/3 full the pressure on that should be 2 lbs below the pump pressure!!!
if you find that the screen a the bottom of the well is plugged too need too by tablets at the hardware store too put down it cost about 30.00!!
Apr 15, 2009 | Plumbing
Front Loader Wont Purge Water and enter Spin Cycle
it is the drain pump, it is nt working due to lack of power entering its supply line or there is something stuck in the impeller,or its winding failed, u can check it by observing or wait till machine reach the drain cycle when you hear a humming sound during the drain cycle, you isolated already the supply to the drain pump it means the drain pump is working but there is something blocking the hose,impeller and or the pump motor is weak already. if so, call an authorized servicer or service fr the company to do the job, or if u want to fix it by yourslf, first lay down the hose of the machine at floor level, water will comes out, drain it,with that it means no problem with the water line from the tub of the machine to the drain hose, remove the back cover from there u can see the pump get a mechanical plier to remove the clamp,slide the pump or unscrew it if is installed that way then u can check now the pump physically, sometimes small pins is blocking the impeller if there is nothing and when you touch pump is so hot-it is electrically defective-the winding is weak or just what i have said earlier it is blocked or mechanically defective -replace the pump assy- u can order it -try www. repair clinic .com
Apr 06, 2008 | Washing Machines
Water coming out of the drawer
Sorry I do not have an answer for you...I have got a similar problem. Just before spinning water pours out of the dispenser drawer. Checked water pressure, drain holes etc seems ok. If you do get an answer would appreciate you letting me know. Thanks
Oct 18, 2006 | Hotpoint Aquarius WD640 Front Load...
Frigidaire 24 in. FDB1050RE Built-in Dishwasher Logo
146 people viewed this question
Top Frigidaire Dishwashers Experts
Carmen Mikulic
Mike
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
