Question about Daewoo DW500M Top Load Washer
I have a front loading washing machine that smells inside. Any suggestions ???
    President:
  • 1,653 Answers
IMPORTANT: Read thoroughly. DO NOT add detergent or other laundry products to this cycle.
1. Remove all items from the washer.
2. Open the dispenser drawer and 2/3 cup (160 mL) of liquid chlorine bleach to the bleach compartment. DO NOT use more than 2/3 cup (160mL) of bleach per cycle as this will lead to product damage.
3. Close the washer door and dispenser drawer.
4. Select the Clean Washer cycle or a full wash cotton 104 F wash (40 C). DO NOT use any higher temperature as this will cause unnecessary fumes
5. Press Start and allow cycle to complete.
6. If the bad odour persists, repeat the procedure 1 or 2 more times. This may be necessary if this is the first time you have run this cycle.
7. After the cycle is complete, leave the door open slightly to allow ventilation and drying of the washer interior.
8. Repeat the cleaning procedure monthly.
To maintain the washer freshness:
1. Use only HE High Efficiency detergent.
2. Leave the door open after each cycle to for better ventilation and drying of the washer interior.
3. Use warm / hot water in your machine unless the fabric you are washing requires cold.
4. Use the correct amount of fabric softener.
5. If your laundry room is damp, use a dehumidifier.
6. Clean the door seal of visible residue.
Posted on Sep 10, 2009
The smell that comes from this machine is terrible. My clothes also smell bad. I wipe out the seals rubber around door and leave the door open for at least 30 min. After each wash. I also take clothes out...
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hope your filter is clean. Don’t wait for the machine to jam to look into your filter.
You can use Affresh to clean your front loader. Deposits of soap and other such things can be stuck around the inside tub of your washer. Try this product, it works great on all front loaders. Use very hot water with the Affresh pellet with no clothes and run the machine through a cycle. Also helps with any stagnant water smells. Put the Affresh pellet inside the machine, not in the soap dispenser.
You can give me a ‘very helpful’ rating for the free help, can't you. Thanks.
Jun 19, 2010 | Samsung WF337AA Front Load Washer
The waqshing machine smells inside
All front loader have this problem. Use concentrated lemon juice to clean the boot and then you will have to leave the door ajar just a bit every time you finish washing. Sorry but this the nature of having a front loader. Also using powdered soap products will also almost completly do away with this problem.
Jan 31, 2010 | Kenmore 44921 Front Load Washer
Terrible smell during washing cycle!
I am not a repair professional. I am just a 78 year old
man who has been making his own repairs for about
50 years. Therefore the washer ID doesn't mean
much to me. It's been about 55 years since I had
experience with front load washers. However I can
suggest you go to www.applianceaid.com where
they have very good trouble shooting and repair
information on front loaders. I think you'll find what
you need there. Good luck with it.
Nov 27, 2009 | Kenmore Elite 45986 Front Load Washer
FTF530FS Front Load washing machine. Clothes smell.
all front load washers have the problem. Mold and a build up or dirt and soap and fabric softner cause s old musty smell. The low water use makes the machine dirty and build up inside. Run a few Hot water washes with out clothing, Run it empty ,(run your hot water neer your washer to get the cold water out of the house pipes) hot water and pour bleach in side, 2 or more cups. Keep doing it. When your not using washer leave the door open so air can get inside. Hot wash,es with bleach will keep it clean, also dont use fab softner.
Nov 11, 2009 | Frigidaire FTF530FS Front Load Washer
Smell in Washer
The best suggestion I can givefor this is to use a tablet called Affresh.
http://www.affresh.com/
This is a great cleaner for all HE washers. I hope this helps.
Good Luck!
Feb 16, 2009 | Maytag Neptune MAH5500B Front Load Washer
Clothes have a musty smell if left in the washer
Make shure to do a cleaning cycle. As well, wipe out the inside, the rubber gasket and the door when done washing for the day. We also have found that
leaving the door "Open" for several hours, when finnished, eliminates any future
smells.
Jan 10, 2009 | Kenmore Elite 45986 Front Load Washer
Laundry smells like mildew after washing
Front load washers retain water that you cant see or get to. There are cleaners for washing machines available. I clean mine every month with alot of bleach , try pouring a half gallon of bleach in the soap insert on a normal wash cycle and an extra rinse would not hurt no clothes of course.
Dec 28, 2008 | Kenmore 24032\24036 Top Load Washer
Zanussi fjs1225w nasty smell around door seal and inside machine
Are yo;u susing front loading detergent? My smell went away when i switched.
May 14, 2008 | Zanussi FJS1225W Front Load Washer
Bad Smell
this is caused by a build up of old detergent and limescale.there are some industrial strength descalers around.wpro descaler is one.add the sachet to the drum with no wash load.pour in a kettle of hot water(not boiling)and leave for thirty minutes.then put washing machine on a 60 degree cycle and allow to run right through.you will need to repeat approximately every three months
Nov 16, 2007 | Hotpoint Aquarius WMA42 Front Load Washer
Daewoo DW500M Top Load Washer Logo
338 people viewed this question
Top Daewoo Washing Machines Experts
Marvin
Marvin
Paul Bade
Are you a Daewoo Washing Machine Expert? Answer questions, earn points and help others
