Question about Magic Chef CTF2125 Top Freezer Refrigerator
Freezer not Freezing
I have a Top Freezer not Freezing. The dial is at max and there is ice in the top of the fridge, but contents aren't freezing. Is there perhaps a blower fan not working? Actual number on Magic Chef- RV191T but can't find info on it. Thanks
  • 57 Answers
The air flow is blocked betwen fridge and frezer or even the small fan is burnt out
Posted on Jun 22, 2009
Top of freezer not freezing
your cooling matchine get damaged,there having a cooling matchine.
Mar 25, 2013 | Daewoo FRSU20IA Freezer
Freezer is causing fridge contents to freeze..... cont.
Do you see any ice buildup on the back wall of the freezer?
Oct 21, 2012 | Maytag PTB1954GR Top Freezer Refrigerator
The problem is with my magic chef top/bottom fridge/freezer. the freezer is working fine, but the refrigerator is freezing its contents.
Either defrost problem or clogged drain... Is there snowy frosty ice on back wall in fridge? If so, hire a professional. If not - you can take back wall off in the freezer and defrost the drain.
Please rate us 4 thumbs up!!!! Tips Provided by: GOFAR Services, LLC - Refrigerator repair Houston, Katy, Spring and Woodlands, TX!
Aug 29, 2011 | Magic Chef CTB1521 Top Freezer...
Maytag Performa fridge has stopped making ice -- I changed the water filter to make sure that wasn't the problem. The water in the door works fine and there is plenty of pressure in the water line but the...
First, I'm not a Maytag tech.
Check your warranty. You should call Maytag/Sears for service.
*** The following is for information only.**
* I've had this problem a lot with my old fridge. Water line works but no ice.
* Check if the "Ice Full" leaver is in the down (no ice) position. Some ice makers will lock the leaver (a stiff wire) in the full position to manually shut off ice maker. Make sure it swings up and down when ice tray is empty.
* Sometimes when the tray is left full of ice for a week or more then the tube feeding water will freeze up. Defrosting the freezer on a regular basis will help. A quick fix is to pour warm water in the ice maker section (where the ice is formed). This will help melt the clogged pipe and also make some ice while your waiting. You may have to do this several times. But at least you have ice.
* This (freezing up) may also be caused by the freezer set too cold. The temperature dial should be in the middle. But turning it colder and colder over time will cause ice to build up and prevent foods from freezing properly (thus turning the dial down colder.) Once your maxed out on the dial. You will find the freezer gets warm and things get covered in frost crystals.
* Transfer food to another refrigerator and perform a complete defrost by leaving it unplugged and the door open (freezer section).
* Frequently check and dump water at bottom of fridge. Clean the dust on coils while down there.
* A fan blowing into the freezer section helps. (Do NOT use a heated fan as it will warp the plastic and overpressure the refrigerate.)
* Once defrosted (+4 hours). Power up the freezer and set the temperature dial to mid point and the freezer diverter to middle or normal setting. Don't put the food back in yet. Wait till the freezer gets down to normal freeze temp (about 0 to 10F)
* Move freezer back in place (if you moved it to access plug) then slowly put back the food. Try not to cram stuff in. Leave space for air to flow freely around items.
* Final, Call for service anyway and have them perform yearly service. Check your warranty.
Aloha, ukeboy57
Feb 20, 2018 | Maytag MTB1504A Top Freezer Refrigerator
Top of freezer not freezing, bottom of fridge is?
Could be the evaporator fan motor is not working. This is what circulates the air from the freezer to the refrigerator section.
Aug 24, 2009 | Refrigerators
Not cooling or freezing
bimetal switch not working. change it.
Aug 02, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Fridge works only on the max setting
needs a defrost heater, keeps it from freezing up. my friends did the same thing, she changed defrost heater and works fine now.
Oct 29, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Refrigerator not that cold and freezer not freezing well
between the door and freezer is very hot, and the refrigerator is not that cold and the freezing is freezing but not that well, ice cream is soft but meat freeze and ice is not melting. Also behind the fridge at the bottom is very hot.
Jun 05, 2008 | Kenmore 64802 Top Freezer Refrigerator
Fridge of Fridge/Freezer keeps freezing contents.
all the food going to ice temperture at 2
Oct 24, 2007 | Refrigerators
Magic Chef CTF2125 Top Freezer Refrigerator Logo
404 people viewed this question
Top Magic Chef Refrigerators Experts
evans_lloyd
Level 1 Expert
John Tripp
John Tripp
vince
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
