Laminator Laminate pouch stuck in laminator. Worst laminator I ever purchased as a royal. DO NOT BUY!
    Sergeant:
  • 199 Answers
Ok we think again
Posted on Jun 22, 2009
Do I insert the printed paper into clear pouch & just put these 2 items into Smith Corona Laminator LX900? Do I need a heavy paper protector to surround these 2 items? How do I order a protector?
use what is called laminating pouches
you put what you want laminated in the pouch, centre it so that the edges all have the same space, wait until the green light on the laminator appears and enter the pouch with the folded end in first.
It will slowly move through and seal off as it goes
make sure that the pouch is entered square to the rollers or it will crease the finished product or jam the laminator
there is no need for any additional equipment
Jan 08, 2017 | Office Equipment & Supplies
How do I get something out of that the laminator ate?
You can't do any more laminating until you do. Some laminators have to be used with a document carrier and some don't. It sounds like yours does need one. This happened to me once. You have to remove the screws on the bottom, lift off the top and you will find your document and laminate pouch wrapped around the roller. Using a sharp paring knife or nail scissors, cut the pouch along one side making sure not to damage the ceramic roller. I have a recollection that I cut the pouch away on both sides. I used a chef's boning knife as this was at work in an airport business class lounge.
Oct 12, 2016 | Apache Al18p 18 Professional Laminator
Reassemble after having to take apart?
did you get it fixed, I had the same problem but with a different part , I know where your part go's
1st without screw holes go's in the Rear where the laminate comes out and the next one goes on top email me if you didnt fix it yet , I can open mine and get pictures Email me here
scolt@tampabay.rr.com Subject Laminator APL-330U
Oct 22, 2014 | Royal Sovereign 13" APL-330U Hot & Cold...
Fellowes laminator
Plz try the "Jam free" lever located on the top LEFT of the laminator. You ca try to feed another film in....hoping it will force the pouch out. Otherwise, you will have to take the cover off and unroll the pouch from the inside rollers. Good luck!
Aug 20, 2014 | Fellowes Saturn2 125 Laminator
Laminator will not stop beeping
We just brought home a new Royal Sovereign Laminator. Plugged it in and turned it on. It will not stop the loud, annoying beep and is stuck on reverse. It's going right back to the store for a refund. Will not ask for another Royal. If you can't make it right, don't try to sell it!
Apr 02, 2014 | Royal Sovereign 13" APL-330U Hot & Cold...
LAM901 Laminator has no reverse. Have a pouch wrapped around the rollers.
carefully remove the pouch by cutting it into pieces with a sharp box cutter (be carefull not to cut the rollers) then pull out the pieces from the rollers then rethread the laminate rolls into the machine as you always have
Sep 30, 2013 | Office Equipment & Supplies
Pouch stuck in laminator
Firstly switch off the laminating machine and plug out. Turning off the machine will prevent the motor from burning out. As the motor is not burnt, there is no need to repair or substitute the machine.
* When the machine gets turn off look for the damage instantly, if any. If any huge item was inserted to laminate, it might have happened that the item had stuck in the machine. First of all, try to pull out the item gently from the machine. Also, remember that thick and three dimensional items should not be laminated in the laminating machine.
Hotmail Support ' Aol Support
Apr 09, 2013 | Office Equipment & Supplies
Some one at work tried to laminate a card. when it did not come out she put in another sleeve thinking it would push the other out. smart uh! how do we get the 2 pages out?
If you were using GBC brand laminating pouches they don't need a carrier, if you were using another brand of laminating pouches, then a carrier is needed (something they don't clearly specify) and that's why the laminating pouch got stuck.
If you have had the laminator under a year, it should be under warranty, and you can call the company, and they will send a replacement, and they will probably then inform you of the above listed laminating pouch issue.
You may also want to try using the reverse button, but many times the pouches will get stuck between several rollers, and you risk destruction of the entire machine by attempting to take them out manually.
May 31, 2011 | Gbc HeatSeal H425 Laminator
I was given a laminator but it does not have instruction booklet, how does it work?
the main way they work is that you have the laminate pouch into which you slide your paper then make sure that the pouch is put between the guides closed side first the machine will take a while to warm up after you have plugged it in when the green light is on push the pouch in slowly the motor should turn and feed the pouch in automatically.. the important thing is to make sutre the pouch is correct for the type of machine you have and that when feeeding in the pouch it goes in closed end first otherwise it could open and jam.. Good luck A>>
Jul 27, 2009 | Office Equipment & Supplies
359 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
