Question about Asko 1375 Dishwasher
The drain pump motor on my ASKO model 1375 dishwasher wont stop running
    Problem Solver:
  • 7 Answers
Had a similar scenario on my Asko 1325. I simply removed the unit in preparation to chuck it, but once outside decided to check the inside of the pump/impeller and the electrical connections. Found plastic debris in the pump, and wiggled every electrical connector of its attachment and then re-attached it. Tried the Asko-fiasko outside and it worked.
BTW be prepared for an electrical failure/ meltdown as per the following two photos:The drain pump motor on my ASKO model 1375 - e4b01cd.jpg47ce737.jpg
Posted on Sep 01, 2009
Front top panel broken on ASKO model 1375 where can i get a replacement
Parts of that type might be hard to get for this model.
Try this site and select the part based on your dishwasher finish.
http://www.repairclinic.com/Shop-For-Parts/a9b126d610738/Model-1375-Asko-Dishwasher-Parts
Apr 01, 2014 | Asko 1375 Dishwasher
Asko 1375
May be the drainpump that has something stuck into it. Check that
Jun 08, 2008 | Asko 1375 Dishwasher
Asko 1375 not running right, turn it on hear humming only no water running
It is likely the inlet valve is faulty provided the tap under kitchen sink is open and there is water supply to the dishwasher.
Jan 12, 2013 | Asko 1375 Dishwasher
I have a 1776 Asko model & it doesn't finish its cycle-code mesage f-2 keeps appearing. Can you help me out.
Hi
F2 is a drain error and dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Sep 18, 2011 | Asko 1375 Dishwasher
My ASKO 1375 seems to wash fine but will not drain. We checked the pump, filters and drain hose. All seem to be fine. Suggestions?
It is easy to have insoluble items clog underneath the lower spinner. Take it off and clean the holes thoroughly. Check for bits of glass. If this is not the problem, it could be that the pump is broken.
Dec 30, 2010 | Asko 1375 Dishwasher
Dishwasher begins to fill then stops with no further progress.
Welcome to FixYa.
Based on hoe you`ve described the issue with your Asko, initially it sounds like a faulty inlet/water fill valve...
But, I`d like to clarify the symptom first. Does the unit complete the fill cycle and then do nothing, or it just energizes the fill momentarily then does nothing ?
Also I will ask to verify the model is an Asko 1375 ?
I`l watch for your reply.
Regards,
Macmarkus :)
Sep 02, 2010 | Asko 1375 Dishwasher
ASKO 1605
Hi Guys
My dishwasher this morning has desided to not work correctly.
Its a ASKO 1302 about 20 years old. It has been a very good machine.
Over the last couple of weeks during the washing cycle, the dishwasher has been making a loader noise than usual.
1. Today, the dishwasher timer, travels all the way through its cycle, but very little washing take place.
2. Soap power is still there, plates not clean!!!!
3. Water is hot
4. At the end of the cycle, there is no water in the dishwasher.
5. I'm thinking the problem could be the pump needs replacing.
What do you think?
Greg
Sep 05, 2008 | Asko 1375 Dishwasher
Dishwasher does not drain after cycle
Check the drain pump and/or drain hose. It may be clogged woth something.
Jan 26, 2008 | Asko 1375 Dishwasher
Asko 1375
May be the drainpump that has something stuck into it. Check that:)
Nov 23, 2007 | Asko 1375 Dishwasher
Asko 1375 Dishwasher Logo
1,073 people viewed this question
Top Asko Dishwashers Experts
John Tripp
John Tripp
Jose Pino
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
