Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
Water is building up at the bottom of the freezer and freezes. Ice is being fine but there appears to be a water leak at some point and going to the bottom.
  • 57 Answers
Drin tube at the back of fridge is blocked and needs to be cleaned
Posted on Jun 22, 2009
  • 1462 Answers
SOURCE: Ice build up on bottom of freezer
remove back panel inside freezer. you will see drain tray at bottom with a drain hole in the middle - this is blocked usually with ice. melt off with a hairdryer and follow up with hot water till water flows away freely
Posted on Sep 25, 2008
Sea Breeze
  • 4655 Answers
SOURCE: Ice build up on bottom of freezer. Water leaks out.
Your problem is possibly one of two things. The ice maker is leaking or the defrost tray behind the rear panel inside freezer back wall is clogged with ice or something else. If you know its not the ice maker unplug the refrigerator and remove the back panel to see if the drain is blocked there, Let me know, Sea Breeze
Posted on May 21, 2009
  • 358 Answers
SOURCE: Leaking water and ice build-up in freezer
There's a drain hole in the freezer side behind the bottom drawer in the back wall that must be clogh ; put hot water into it untill melted the ice and keep pouring water to clean the drain (don't worry , the water goes to an evaporative tray) .Keep the drain clean by putting every 3/4 months half a cup of clorox or bleach.
Posted on Sep 28, 2009
  • 44 Answers
SOURCE: water freezing on bottom of freezer
The defrost drain pan is plugged and not allowing the water to drain into the pan under the refrig. Remove the cover on the back wall of the freezer and clear the drain by flushing with hot water.
Posted on Mar 25, 2010
  • 3 Answers
SOURCE: samsung twin door fridge water leaking onto floor
I have a Samsung side by side - model RS253BAWW.
Water was leaking onto floor from main refrigerator, not freezer. It was determined to be a blocked defrost drain.
The repair technician removed the trays and food from fridge, remove the screws from the panel at back, disconnected everything and remove panel.
The stainless tray at bottom of fridge as well as panel itself had solid ice blockage.
He placed panel in sink and used something similar to a blow dryer with narrow hose on it to defrost both the panel and drain in fridge. Took him maybe 15 minutes and charged $99 total for the visit.
In future I will do this myself now that I know how but thought it may be useful information to others who are having similar problems.
Posted on Sep 08, 2010
Leaking water on floor
Remove contents from bottom of freezer. Turn ref/freezer off. Use the handle end of a screwdriver and carefully break up the ice build up from the bottom of the freezer. Find the condensate drain and remove ice build up. Find the condensate drain and remove ice or any kind of restriction from the drain line.
Or you can turn the refrigerator off for a day , mop up the water and blow out the condensate drain
Jan 18, 2016 | Maytag Refrigerators
NO ICE OR WATER
Whenever the water lingers inside the freezer, it freezes. If the valve has a slow leak, or the final outlet tube is scratched, ice can build up and eventually block entry.
A hair drier on the area where water enters the freezer might clear up the problem. I'm not sure that's a prescribed method to melt the ice though. Defrosting the freezer could thaw it out, but where do you put the frozen items?
Dec 17, 2017 | KitchenAid KBFS25EVMS Stainless Steel...
Ice Maker leaks water inside the freezer
I see you said you looked and the water valve is off but the only that I know of this happening is a defective water control valve. Like a dripping faucet that when off slowly drips until the ice forms and then one the ice maker dumps ice and tries to refill the water goes in every direction. Unplug water valve to confirm what I am saying, Tell me if it continues to leak. Sea Breeze
Apr 19, 2010 | GE 21.7 Cu. Ft. Top-Mount Refrigerator...
Water pools at bottom of freezer, freezes and water leaks out
Hello, this sounds like you have a blockage in the drain tube, remove bottom shelf from fridge and remove the styrofoam..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the Freezer is because the water has been leaking into the freezer instead of running into the drain hole...Please feel free to comment again if you need any further assistance. Mike
Aug 31, 2009 | Freezers
Water building up on the bottom inside the freezer side
the drain in the freezer is clog make sure the drain from the freezer is clean all the way to the pan next to the compressor . you need to open the back wall of your freezer for that ( the inside wall) clean with buster (water pump)the drain is in the bottom middle of the freezer.
Apr 19, 2009 | Frigidaire Gallery Series GLRT83TEK 30"...
Water accumulating in bottom of freezer and leaking onto floor
Yes the drain is clogged and the water that supouse to go through became ice so it make it worse.Put hot water in the drain hole until it runs through,it'll go to an evaporative pan on top of the compresor to keep it warm and vaporize the water.
Apr 04, 2009 | GE GSL25JFPBS Side by Side Refrigerator
Water inside bottom of freezer.
Water accumulation in the freezer more commonly points to the ice maker. Over a period of time, water entering the ice maker can slowly freeze to the point it provides a small restriction and prevents a portion of the water from entering the ice maker. The plastic spout/tube could also have either cracked or shifted and is allowing a small amount of water to leak into the freezer.
Feb 24, 2009 | GE GSS25SGPSS Side by Side Refrigerator
Sep 25, 2008 | Maytag MSD2732GR Side by Side Refrigerator
Amana refrigerator top freezer going out; water under crispers
you are right about the cause of water in the fridge - blockage in the drain. i'v never met this caused by ice but it is possible.
with the freezer, the cause of the fault is the fan not working - probably jammed with ice. take back panel off inside freezer and check for ice build up. if loads of ice thgen defrost system has failed. you can do a temporary repair by melting the ice off with a hairdryer
Sep 24, 2008 | Refrigerators
Ice build up in my frost free upright freezer
I looked at the BACK at the bottom underneath of my Sears Kenmore frost free upright freezer and what was causing the ice buildup was very simple. At the factory, the assembler looped the little hose too high and when the water went into the hose it could not get out due to being too high in one spot! An ice dam will form, blocking ALL water coming through
and freezing up any more water coming down giving you a HUGE wad of ice that is scary!!! I just removed the screw holding the loop that holds the hose and put a bit of warm water down the little hole on the INSIDE (Behind the grate) to melt the remaining ice in the tube.You need to take out 4 screws and remove the grate to see this. I could not believe that this was the problem! I haven't had any ice build up since.Now don't tear your freezer apart before you try this trying to fix the compressor, thermostat etc. It may be the only thing wrong with it!
Nov 11, 2006 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
125 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
