Question about Kodak EasyShare DX4330 Digital Camera
Camera dock does'nt work
The camera dock does not work
the indicator lights is off
it seems like it doen't charge the battery... although it's a new one
what should i do? pls! help......
  • Jr Lomiteng
    Jr Lomiteng Jun 23, 2009
    thanks a lot...but do you think the camera dock need the spcific battery?
    where can i buy those battery?
    maybe i will buy a rpid charger..that's the best thing i can do....tnx...tnx...tnx....
  • Jr Lomiteng
    Jr Lomiteng Jun 26, 2009
    is there a difference between KAA2HR to other rechargeable batteries
    like sanyo model battery,etc...
    because i already bought a pair of battery..they were rechargeable battery right?
  • 34 Answers
If the light indicating the charging status is off, remove the batteries from the camera and make sure that you are using the Kodak Ni-MH Rechargeable Battery Pack KAA2HR. THis is the only battery that will charge on the dock. If you are using the correct battery and it still does work, better to get a rapid charger instead.
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-locale=en_US&pq-path=13978
Item # 1717610
Posted on Jun 22, 2009
  • Sol Ocampo Jun 23, 2009
    Yes.
    For the model of your camera, the only battery that will charge on the dock is the Kodak Ni-MH REchargeable battery pack.
    If you will buy a rapid charger, you can use any kind/brand as long as it is NiMH.
    Alkaline batteries may not last long. Plus in the future, it will be more economical to buy rechargeables
Kodak dx7590 camera dock will not light up
Although you did not mention what Dock you are using, I assume it is the Camera Dock 6000. Is the Dock connected with the power supply? Because only connected to the PC with a USB cable will not be enough. Also the LiIon battery in the camera, should be charged at least once. If the battery is completely empty the dock will have trouble to. The dock can be used to charge your camera. Then the lights should indicate the state of the battery. And the Dock can be used to transfer pictures to the PC. But before that will work correct you have to install the software that came with the camera. (Easy Share software)
Jan 12, 2014 | Kodak EasyShare DX7590 Digital Camera
Charge batteries while camera is docked
what is the model of your camera and what specific battery are you using( what is on the label of the battery?)
when the camera is docked on the printer, you should get a little light indicating the charging status. Once it is fully charged, all 3 green lights would come on.
But, we need to know what is the model of your camera and what type of batteries are being used in order to determine if they are compatible or not.
Apr 10, 2009 | Kodak Easyshare G600 (1633379) Dock /...
Red flashing light on battery indicator on the loading dock.
My Z760 does the same thing. When that happens I run the battery completely down by taking pictures until it shuts down. Then when I put it on the dock it charges properly. Don't leave your camera on the dock all the time and don't try to always keep the battery fully charged--instead it will develop memory and think it needs to be fully charged to run and will give you a low battery signal earlier than it should. Wait until you actually get a low battery signal before charging and it should help, but mine will still give me the red light sometimes. Then I run the battery out like I said before. I hope this information helps. :-)
Mar 14, 2009 | Kodak EasyShare Z760 Digital Camera
Camera dock can not charge camera battery
It sounds like defective batteries if the printer unit works otherwise,
Feb 16, 2009 | Kodak Dock Series 3 Laser Photo Printer
Kodak EasyShare Z760 won't charge.
The problem might be that the battery has developed memory and won't charge further. My first battery used to do that, but then I read that you shouldn't leave the camera on the dock all the time nor keep the battery fully charged all the time because of the problem of developing memory. You might try running the battery completely down by taking pictures until it shuts down. Sometimes when my battery is low the dock won't charge (but goes straight to the red light), but when I run it completely down when I put it on the dock it charges properly. I hope this information helps. :-)
Jan 30, 2009 | Kodak EasyShare Z760 Digital Camera
Charging...Red Light
This happened to me. The cause was the battery did not fit into the case, This led to poor connection of the battery. After I fixed the loose battery , it worked perfectly till today.
Oct 05, 2008 | Kodak EasyShare Z760 Digital Camera
Dock charger
Although I have no solution to this problem, my camera appears to be doing the same thing. Please let me know if you find a solution!
Jackson
May 27, 2008 | Casio Exilim EX-V7 Digital Camera
No power
Not sure if this is related, but our's won't start-up either, and it seems to indicate that the batteries are weak/dead prematurely. There must be some sort of power level controller that could be the root problem. Our experts can add some useful content to both these threads....
Aug 08, 2007 | Kodak EasyShare DX6440 Digital Camera
Casio ex-s600
Hello Gery, Try with the new battery. Best regards, Arpad
Jan 10, 2007 | Casio Exilim EX-S600 Digital Camera
Kodak EasyShare DX4330 Digital Camera Logo
176 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
