Question about SanDisk Sansa e250 MP3 Player
Can't put what I recorded onto my computer from device
I am trying to put the songs and files I have recorded onto my sansa e250 and I don't know how. what am I doing wrong
  • 1 more comment
  • stardust_rp Jun 22, 2009
    The things I have recorded off the radio. I can't figure out how to put them onto my computer. And when I connect the device is there a better program that I can download off the net. Other then the windows media player we already have?
    That worked perfectly. Thank you so much! Now I am also having another silly problem. I can't delete the songs that were downloaded onto my player. I went into the computer and the songs don't show up on a file name when I click on the sansa in the computer menu
  • Raymond Ramirez
    Raymond Ramirez May 11, 2010
    how are you putting them onto the sansa. does windows see it a a MTP device ie..through windows media player or through windows explorer
  • 331 Answers
Ok. when you use windows explore.......ie...My Computer. you should see your hard drive and cd rom and other periferials.... do you see your Sansa on the bottom? if so you can double click on it and you should see the different folders
Posted on Jun 22, 2009
  • Raymond Ramirez
    Raymond Ramirez Jun 22, 2009
    can not be managed through windows. can you delete them from the sansa menu key.
How do I delete certain files from my Sansa?
try going to "my computer" then scroll down until you see an icon that says Sansa e250 click on that then search through both files(2 folders should come up one says data and another says media) try finding the source in here
May 06, 2008 | SanDisk Sansa e250 MP3 Player
Help me!!
mormontazzy, plug in your sansa e200 then go to "my computer" on your computer find an icon that says sansa e 200(it might say sansa e250) click on it and go to a file that appears that says media then click on the songs file after that get all of your songs from itunes and drop them into this file if tat doesn't work then take all of your songs from itunes and dropping them into widows media player
Apr 26, 2008 | SanDisk Sansa e200 MP3 Player
Adding Music To My Sansa e250
I never use Windows Media to add music to my sansa... If you want all music to show up click on my computer and then click on the icon for your sansa. there may be a folder that says music but if not it is a hidden folder. if this is so you must go to tools, then folder options, and then the tab that says view. under this will be an option that says hidden files and folders and click show hiden fles and folders and OK. this should allow you to see the music folder. from here on you can just copy and paste all files.
Feb 10, 2008 | SanDisk Sansa E280 MP3 Player
Mp3 format??? HELP, PLEASE!
I don't know about converting the MP3s to WMAs, but I had the same problem with "corrupt files."
What fixed that for me was instead of dragging and dropping files onto the Sansa, I synchronized them using Windows Media player, but only do 10-20 songs at a time, because if you try to do too many, they probably won't show up. I know it's tedious and annoying, but that's what did it for mine :) I hope this helps.
Dec 30, 2007 | SanDisk Sansa e250 MP3 Player
Sansa mp3 player e200 version
Try this;
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted.
http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe
You need to put the device into "recovery mode" before you run the tool.
- Turn the device off (hold power for 20 seconds)
- Slide the hold switch into "hold" position.
- Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer.
Then run the recovery tool. Select format when prompted.
Best of Luck.
Oct 28, 2007 | SanDisk Sansa e250 MP3 Player
I cant find the songs to delete and it the refresh database fails everytime
If you cant see it in MTP mode, the MTP drivers may not be installed on your computer.
Its easier to do this than explain the other solution.
Follow these instructions and you will be back in business.
Best of Luck.
Oct 14, 2007 | SanDisk Sansa e250 MP3 Player
Deleting files from Sansa e250
The only way I know to delete music files or voice or FM recordings, is straight from the User's manual on the CD: 1. Set the e250 to MSC mode. 2. Plug it in to your computer with the USB connector. 3. Open the Sansa e250 drive in My Computer and browse to the MUSIC folder (or RECORD folder)and delete the files there. (That's where you also add music files, by dragging from other explorer windows.) To delete (or add) photo and video files, you have to use the Media Converter, which you install from the disk that came with the e250.
Feb 18, 2007 | SanDisk Sansa e250 MP3 Player
I can't put songs on my Sansa Sandisk e250....
Hey to get music onto the Sansa e250R you have to plug the Sansa into the computer. Next go to mycomputer. Then onen ethier sansa or Removable Disk(F:). Then take the songs you want and drag them on to the white space under photos and vidos and all that other files. DO NOT PUT IT IN A FILE.
Jan 27, 2007 | SanDisk Sansa e250 MP3 Player
Wont upload music onto device!
hey, the same thing just started happening to mine. Let me know if u find a solution.
Jan 17, 2007 | SanDisk Sansa e250 MP3 Player
My Sansa skips the songs I put on it, what can should I do
I restored settings to default factory settings and has been working and not skipping the songs. Restoring to factory settings does not delete any of your data/songs
-Raj
Nov 27, 2006 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
50 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
