Question about Eljer Home
Installing whirlpool tub
I have Eljer Whirlpool tub I am about to install...I have questions about how to seal the rim to the tile suround???
  • sawdust780 Jun 23, 2009
    I am starting from scratch, I am building a surround for the tub and will be tiling the top of the surround....then will set tub in but Menards did not mention anything about "tile flange" nor did Eljer mention and flange kit on their website!!!! Where would I get an flange kit that will fit my tub????
  • scot doolittle May 11, 2010
    Are you starting from scratch? If so you should buy a tile flange kit that either self aheres to the tub deck or needs to be siliconed in place with wall treatment overlaping thids flange.
If it is a five foot tub, home depot usually carries them, if not any plumbing supply store will have them.
Posted on Jun 23, 2009
Need reviews on Eljer Whirlpool Triangle Tubs. Eljer a Good Tub to Buy?
Eljer is owned by Jacuzzi Whirlpool. Very nice tub. Eljer is one of the bigger Bathtub Mfg out there.
Not sure why he has not heard of them. Lowes is probably the biggest seller of that brand.
Rod
US Parts Center
Feb 07, 2013 | Eljer Triangle WP 60x60 LH 10JT
I purchased an Eljer "Emblem"
Congratulations.
Is this a fix question?
Dec 20, 2017 | Eljer Whirlpool In-Line Heater-...
I just installed a new whirlpool jacuzzi tub with an Eljer inline heater. The pump in the tub is shooting water out all the jets I even blew the jets out with air to make sure they were clear. The first...
if the light on the heater is not coming on when the tub is full of water and the pump is on then the heater is not working.
check the circuit breaker to make sure it is on.
the heater and the pump cannot be on the same circuit. They have to be on separate circuits.
Make sure they are on separate circuits.
Check to make sure you have the heater installed in the correct place.
there is a pressure heater that mounts anywhere after the discharge of the pump.
there is a vacuum heater that mounts in front of the pump in the suction line.
if you put on or the other in the wrong place it will never come on.
Jan 17, 2011 | Whirlpool Home
I have an aqualux whirlpool tub w/ cracked jet housing
yes i can do it call me 301 659 9968 rick
Oct 15, 2009 | Home
My tub surrounding is about a half a inch wide
You may want to try to find some thin ceramic tile beading and gluing it in place and caulking the remaining gap. Use a waterproof construction glue. This is most likely to be something you customize to fit. Often you can rent a ceramic wet saw and cut tiling to fit the need. Use proper safety gear, and be particularly careful if ripping thin pieces less you gain the nickname stubby.
Oct 07, 2009 | Whirlpool Safety Bath Walk In Bathtub -...
EMBLEM, ELJER TUB. DO I CEMENT THE NEW TUB INTO THE FLOOR? HOW MUCH CEMENT AND WHAT KIND?
The tub should just sit on the floor, and caulked around to seal out any water. If it as a fiberglass tub, you might want to put some grout under the bottom to help support it.
Apr 29, 2009 | Home
Installation of our whirlpool tub
Your sheet rock will go to the top of the lip of the tub and then your tile will overlap this lip. If it isn't done right, your grout will crack if you are tiling.
Mar 22, 2009 | Home
Jets not working
i have seen this in the past, a ground fault electrical outlet on the inside of a roman tub,if you have a 2 story house look for access panel on or by tub. otherwise you have to remove tile or other to access motor, you probably need a step too anyways
Mar 12, 2009 | Eljer San Antonio Acrylic Whirlpool -...
Home Logo
672 people viewed this question
Top Eljer Home Experts
john h
Mike
Charles T Nevin
Charles T Nevin
Are you an Eljer Home Expert? Answer questions, earn points and help others
