Question about HTC Touch Pro Smartphone
Hod do i align my screen
How do i align my screen
    Problem Solver:
  • 7 Answers
Go to settings, then go to system and scrool down until u see aligh screen or you can do the g-sensor. They both fix screen problems.
Posted on Jun 24, 2009
How do I fix my Laptop's screen?
If it is physically broken, it must be replaced. You may have to dissemble the top cover to get a part number to order a replacement. There are often some screws under removable plastic or rubber covers. Then the front bezel must be gently pried around the perimeter to release the plastic clips that hod it in place.
If you look at it in a bright light, and see that the LCD is still working, the inverter for the back light may have failed.
You should be able to connect an external monitor to confirm that the remainder of the laptop is still working well.
May 06, 2016 | Computers & Internet
How do I delete texts I have sent and received
This assumes an android system (though ios does it very similalry)
long press (press and hod down for about 1 sec) from the main messaging screen (where you can see all of the messages, not inside the thread) delete should be an option
From inside the thread (where you can see messages from one preson) you can hit the menu key (the 3 lines) and delete should be an option here as well
Feb 03, 2015 | Cell Phones
Sole f63 error codes
Make sure the safety key is clean and not corroded . Check connections on lower board.
Aug 07, 2014 | Sole Fitness F63 Treadmill
The parental lock is set on my proscan 42la45h and I do not remember password and the default 0000 won't work
Shut down with the off button.Restart and hod the F2 button on keyboard.BIOS screne will show,move between screens with arrows on bottom right of keyboaed to find the password page,set them to "Blank",use F10 to shut out of setup and now you won't need a password.
Apr 15, 2014 | Televison & Video
Hod do i reset the password of my phone MY PHONE A618 TV DUO?
Hello::::"::":":
defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Jan 19, 2013 | T-Mobile My Touch Cell Phone
I recently fell on my blackberry curve 9300 3g and the screens has now turned white, hod do i resolve this problem?
Switch off the phone, remove the battery for few seconds then refit it. Now start the phone. If it works fine then ok otherwise the LCD seems to be damaged which can be replaced at auth. Blackberry service station, contact them.
May 11, 2011 | Cell Phones
How to align screen e755 pocket pc
To align your screen
select Settings, System, Align Screen to ajust the touch screen,
If the screen alignment loses calibration it may not be possible to adjust alignment useing the above method.
In that case the align screen command can be executed by simultaneously pressing the power button and scroll button.
useing the stylus when comanded touch the cross hairs and the Pocket PC will align the screen
Feb 24, 2011 | Toshiba e755 Pocket PC
Hod do I align the sensor lights?
Your problem is not with the safety eyes. You have a stripped gear inside the opener. Take off the cover and you will have white shavings in the bottom of the cover. You can repair this with a liftmaster gear and sprocket kit.
Mar 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
In window vista show black screen with cursor
I have a dell inspiron 1525 ..the screen blacks out leaving the cursor only... hod do I remedy?
Nov 29, 2008 | Computers & Internet
Unit frozen to white screen - cannot cold reset it
If you hod the unit towards you wuth the sd card uppermost, you should see a small hole (set in a notch) slightly to the left and towards the circuit board of the unit. Pop a pin in there and it should reset itself.
Nov 16, 2007 | Tomtom GO 510 GPS Receiver
HTC Touch Pro Smartphone Logo
97 people viewed this question
Top HTC Cell Phones Experts
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
ChuckyMo
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
