Question about Locks & Locksmithing
Remove lock cylinder from knobset - Locks & Locksmithing
    New Friend:
  • 132 Answers
With limited information like this all I can recommend is to take to Lowes or a locksmith. They have special tools that releases the lock cylnder from the knob.
Posted on Jun 27, 2009
How to remove ingition housing from steering column
Welcome to Fixya
Thank you for bringing up the problem to our attention. To serve you better, could you please provide me the exact year model of your car.
Your response will be greatly appreciated.
Thank you for using Fixya!
Aug 26, 2011 | Saturn Ion Cars & Trucks
Trying remove the ignition in toyota avalon 2000
TO REMOVE THE IGNITION SWITCH FIRST TURN OFF RADIO.AND DISABLE AIRBAGS BY DISCONNECTING NEGATIVE BATTERY CABLE WAITING 20 MINUTES UNTIL AIRBAGS DISCHARGE.TO REMOVE IGNITION SWITCH PLACE THE IGNITION KEY IN THE ACC POSITION. REMOVE THE STEERING WHEEL AND REMOVE THE STEERING COLUMN COVERS.DISCONNECT THE IGNTION SWITCH ELECTRICAL CONNECTORS.REMOVE THE SWITCH RETAINING SCREWS THEN PULL THE SWITCH FROM THE LOCK CYLINDER HOUSING.IF YOU TRYING TO REMOVE THE LOCK CYLINDER WITH LOCK CYLINDER IN ACC POSITION. USE A SMALL SCREW DRIVER OR PUNCH. DEPRESS THE LOCK CYLINDER RETAINING PIN THEN REMOVE LOCK CYLINDER. TO INSTALL NEW LOCK CYLINDER. DEPRESS THE RETAINING PIN AND GUIDE THE LOCK CYLINDER INTO THE HOUSING UNTIL THE RETAINING PIN EXTENDS ITSELF BACK INTO THE LOCATING HOLE IN THE HOUSING.
Mar 01, 2011 | 2000 Toyota Avalon
How do i replace a ignition switch for a 1992 mercury sable
The ignition switch on Mercury Sable is integrated into the ignition cylinder. When this switch fails, you may need to purchase a special switch from a Ford dealership if the switch used a wireless transponder.
Instructions for NON Functional Cylinder (Cylinder will Not Turn or No Keys ):
1. Disconnect the negative battery cable.
2. Remove the steering wheel.
3. Using locking pliers, twist the cylinder cap until it separates from the lock cylinder.
4. Using a 3/8 in. (10mm) diameter drill bit, drill down the middle of the ignition lock key slot approximately 13/4 in. (44mm) until the lock cylinder releases from its breakaway base. Remove the lock cylinder and drill shavings from the lock cylinder housing.
5. Remove the retainer, washer, ignition switch and actuator. Thoroughly clean all drill shavings and other foreign materials from the casting.
6. Inspect the lock cylinder housing for damage from the removal operation. If the housing is damaged, it must be replaced.
To install:
1. Replace the lock cylinder housing, if damaged.
2. Install the actuator and ignition switch.
3. Install the trim and electrical parts.
4. Install the ignition lock cylinder.
5. Install the steering wheel.
6. Connect the negative battery cable, then check the lock cylinder operation.
Instructions for Functional Cylinder ( Cylinder will Turn with Key):
2. Turn the lock cylinder key to the RUN position.
3. Using a 1/8 in. (3mm) diameter wire pin or a small drift, depress the lock cylinder retaining pin through the access hole in the upper steering column shroud (under the ignition lock cylinder) while pulling out on the lock cylinder. Remove the lock cylinder from the column.
To install:
1. Install the lock cylinder by turning it to the RUN position and depressing the retaining pin. Insert the lock cylinder into its housing. Make sure the cylinder is fully seated and aligned in the interlocking washer before turning the key to the OFF position. This will permit the cylinder retaining pin to extend into the cylinder housing.
2. Rotate the lock cylinder using the lock cylinder key, to ensure correct mechanical operation in all positions.
3. Connect the negative battery cable.
Door Lock:
When a lock cylinder must be replaced, replace both sides as a set to avoid carrying an extra set of keys.
1. Remove the door trim panel and watershield.
2. Remove the clip attaching the lock cylinder rod to the lock cylinder.
3. Pry the lock cylinder out of the slot in the door.
To install:
1. Work the lock cylinder assembly into the outer door panel.
2. Install the cylinder retainer into the slot and push the retainer onto the lock cylinder.
3. Connect the lock cylinder rod to the lock cylinder and install the clip. Lock and unlock the door to check for proper operation.
4. Install the watershield and door trim panel
Hope this helps.
Feb 15, 2011 | 1992 Mercury Sable
Trying to get the ignition tumbler unit out of a 1993 Ford Taurus at the junkyard. worked at it most of two days but no luck yet so I must be missing something having never tried this before.
Ignition Lock Cylinder REMOVAL & INSTALLATION Functional Lock The following procedure applies to vehicles that have functional lock cylinders. Such cylinders either have a key available or known key numbers from which a key can be made.
  3. Using a 1?8 in. (3mm) diameter wire pin or a small drift, depress the lock cylinder retaining pin through the access hole in the upper steering column shroud (under the ignition lock cylinder) while pulling out on the lock cylinder. Remove the lock cylinder from the column. Fig. 1: Using the key, turn the ignition lock cylinder to the RUN position, then depress the retaining pin using a wire pin or small drift 86878085.gif
    To install:
  4. Install the lock cylinder by turning it to the RUN position and depressing the retaining pin. Insert the lock cylinder into its housing. Make sure the cylinder is fully seated and aligned in the interlocking washer before turning the key to the OFF position. This will permit the cylinder retaining pin to extend into the cylinder housing.
  5. Rotate the lock cylinder using the lock cylinder key, to ensure correct mechanical operation in all positions.
  6. Connect the negative battery cable.
Non-Functional Lock The following procedure applies to vehicles in which the ignition lock is inoperative and the lock cylinder cannot be rotated due to a lost or broken key, unknown key number or a lock cylinder cap that has been damaged and/or broken to the extent that the lock cylinder cannot be rotated. 1986-90 VEHICLES
  2. Remove the steering wheel. For details, please refer to the procedure located earlier in this section.
  3. Remove the two trim shroud halves after removing the three attaching screws.
  4. Disengage the electrical connector from the key warning switch.
  5. Using a 1?8 in. (3mm) diameter drill, carefully drill out the retaining pin, being careful not to drill deeper than 1?2 in. (13mm).
  6. Place a suitable chisel at the base of the ignition lock cylinder cap, then, using a suitable hammer, strike the chisel with sharp blows to break the cap away from the lock cylinder.
  7. Using a 3?8 in. (10mm) diameter drill, carefully drill down the middle of the ignition key slot approximately 1 3?4 in. (44mm) until the lock cylinder breaks loose from its breakaway base. Remove the lock cylinder and drill shavings from the lock cylinder housing.
  8. Remove the retainer, washer, ignition switch and actuator. Thoroughly clean all the drill shavings from the casting.
  9. Inspect the lock cylinder housing for damage from the removal operation. To install:
  10. Replace the lock cylinder housing if it was damaged.
  11. Install the actuator and ignition switch.
  12. Install the trim and electrical parts.
  13. Install a new ignition lock cylinder.
  14. Install the steering wheel. For details, please refer to the procedure located earlier in this section.
  15. Connect the negative battery cable.
  16. Check the lock cylinder operation.
1991-95 VEHICLES
  4. Using a 3?8 in. (10mm) diameter drill bit, drill down the middle of the ignition lock key slot approximately 1 3?4 in. (44mm) until the lock cylinder releases from its breakaway base. Remove the lock cylinder and drill shavings from the lock cylinder housing.
  6. Inspect the lock cylinder housing for damage from the removal operation. If the housing is damaged, it must be replaced. To install:
  7. Replace the lock cylinder housing, if damaged.
  8. Install the actuator and ignition switch.
  9. Install the trim and electrical parts.
  10. Install the ignition lock cylinder.
  11. Install the steering wheel.
  12. Connect the negative battery cable, then check the lock cylinder operation.
Nov 05, 2010 | 1993 Ford Taurus
How do you replace the ignition key switch for a '96 chevy diesel 1 ton 4wd pickup truck?
Ignition Switch Removal & Installation To Remove:
  1. Remove the steering column trim covers.
  2. Remove the wire harness from the retainers as needed.
  3. Slide the 2 connectors of the multifunction switch assembly out from the bulk head connector.
  4. Detach the key alarm connector from the lock assembly.
  5. Remove the ignition switch mounting screws and the ignition switch from the steering column.
Ignition switch removal/installation gm-08-00-1141.gif
To Install:
  1. Install the ignition switch on the lock module.
    • Tighten the screws to 42 lb in (4.7 Nm).
  2. Install the key alarm connector on the lock module.
  3. Slide the turn signal and multifunction switch connectors into the bulkhead connector.
  4. Install the harness in the original retainers.
  5. Install the steering column trim covers.
Ignition Lock Cylinder Removal & Installation To Remove:
  1. Disconnect the negative cable from the battery.
  2. Disable the supplemental inflatable restraint (SIR) system.
  3. Remove the steering column trim covers.
  4. Turn the ignition lock cylinder to the run position.
  5. Using an awl with a bent tip, insert the tip into the access hole of the ignition lock cylinder.
  6. Turn the lock cylinder to start and push down and hold the lock cylinder retaining pin.
  7. Release the lock cylinder to the run position and withdraw the cylinder from the steering column.
To Install:
  1. Align the slot in the steering column to the tab on the lock cylinder and install the lock cylinder until it locks in place.
  2. Install the steering column trim covers
  3. Connect the negative cable to the battery
  4. Check for correct operation
Oct 08, 2010 | Chevrolet 3500 Cars & Trucks
How to change 1999 VW cabrio ignition lock cylinder. How do I get the cylinder out of the aluminum housing?
autozone.com has a free repair guide, see below
1990-94 Cabriolet,1990-93 Fox, 1990-92 Golf and Jetta
Fig. Lock cylinder drill point.
  2. Remove the steering wheel, then remove the steering column covers.
  3. Remove the turn signal and wiper switches.
  4. Disconnect the ignition switch wiring.
  5. On some models, the hole in the lock body for removing the ignition lock cylinder was not drilled by Volkswagen. To make the hole, use the following measurements in conjunction with the illustrations. Drill the hole where "a" and "b" intersect on the lock body. The hole should be drilled 0.19 inch (3mm) deep
  6. Remove the lock cylinder by pushing a small drill bit or piece of wire into the hole and pulling the cylinder out. It might be easier to insert the ignition key, turn it to the right a little and pull on it.
To install:
  1. Insert the lock cylinder into the housing with the key in the cylinder.
  2. While gently turning the key side-to-side, press the cylinder in to the stop. It should click into place.
  3. Temporarily fit the steering wheel onto the splines, then make sure the column locks and unlocks smoothly.
  4. Install the switches, column covers, wiring and the steering wheel.
  5. Connect the battery cable.
1995-99 Cabrio, 1993-99 Golf and Jetta
  2. Center the steering wheel.
  3. Remove the air bag.
  4. Remove the steering column switches.
  5. If the vehicle is equipped with an automatic transmission, detach the shift lock cable from the lock cylinder housing.
  6. Remove the adapter sleeve from the steering column.
  7. Remove the spring and horn contact ring from the steering column assembly.
  8. Detach the sheer bolt.
  9. Insert the ignition key and unlock the cylinder, then detach the wiring connectors.
  10. Once all wiring has been detached, slide the housing off the steering column.
  11. Mark and drill the lock cylinder as shown and described in the above procedure.
  12. Compress the stop spring and pull the lock cylinder out of the steering column housing.
  13. Put the new lock cylinder into the steering lock housing.
  14. Insert the key into the lock cylinder.
  15. While you gently turn the key, insert the lock cylinder fully into the housing.
  16. The rest of the installation procedure is the reverse of removal.
NOTE Always use a new shear pin when installing the lock cylinder.
Oct 08, 2010 | 1999 Volkswagen Cabrio
I CANT HERE OR PUT OUT I NDONT KNOW WERE THE NOBS SHOULD BE
Big Knob settings from left to right...
First knobset...inner turn "volume" fully clockwise
... outer "squelch" fully counterclockwise
Second knobset...both inner and outer knobs fully clockwise
Third knob...chose which mode you want to use...Am or Fm (If your radio has been modified to TX/RX CB frequencies, chose AM)
Fourth knob...chose your band (If your radio has been modified to TX/RX CB frequencies, chose band D/A)
The only other knob that is important is the high/low power switch. It selects the band from the pair chosen by the band knob. I don't know if band D corresponds to high or low, so try both settings until one works.
If you can't TX or RX with these settings either there is no one talking at that time or your radio, antenna, or cable might be defective. You should get a copy of the owners manual to fully learn how to chose bands and adjust the settings. I've given you a starting point that should work but may not be optimum for all conditions.
Aug 28, 2009 | Connex CX-4300HP CB Radio
Ignition switch replacment
Ignition Switch REMOVAL & INSTALLATION The ignition switch is located at the bottom of the ignition key cylinder body. To remove the ignition switch, first remove the ignition lock cylinder.
1993–99 Golf and Jetta
  16. The rest of the installation procedure is the reverse of removal. NOTE: Always use a new shear pin when installing the lock cylinder.
Jun 25, 2009 | 1998 Volkswagen Jetta
1990 Jeep Cherokee Ignition key replacement
Without Air Bag
See Figures 1, 2, 3 and 4
  1. Remove the turn signal switch.
  2. Insert the key in the lock cylinder and turn it to the ON position.
0900c152800a9f7f.jpgFig. 1: Using a pair of needle nose pliers, remove the key warning buzzer switch and contacts from the steering column
  1. Remove the key warning buzzer switch and contacts AS AN ASSEMBLY using needle-nosed pliers, or a paper clip with a 90° bend.
0900c152800a9f80.jpgFig. 2: Lock cylinder retaining screwSome steering columns may have a retaining screw holding the lock cylinder in the column. When servicing this type, simply remove the retaining screw and remove the lock cylinder.
0900c152800a9f81.jpgFig. 3: Using a small thin bladed tool, press in the ignition lock clinder retaining tab ... 0900c152800a9f82.jpgFig. 4: ... then pull out the lock cylinder from the steering column
  1. With the ignition switch still in the ON position, insert a thin screwdriver into the slot adjacent to the switch attaching screw boss (right-hand slot). Depress the spring latch located at the bottom of the slot to release the lock cylinder.
  2. Remove the lock cylinder.
To install:
  1. To install the lock cylinder, turn the key to the LOCK position. Insert the lock cylinder in to the housing far enough to contact the drive tang. Force it inward and move the ignition switch actuator rod up and down to align the components. When the components align, the cylinder will move inward and the spring-loaded retainer will snap into place locking the lock cylinder in the housing.
If the lock cylinder is retained by a screw, tighten the screw to 40 inch lbs. (5 Nm).
  1. Install the key warning buzzer switch.
  2. Follow the ignition switch installation procedures to adjust the ignition switch.
  3. Install the turn signal switch.
With Air Bag
Please refer to the ignition switch removal and installation procedure.50c573d.jpg73cc55f.jpgb9448d0.jpg278f367.jpg
Oct 22, 2008 | 1990 Jeep Cherokee Limited
Locks & Locksmithing Logo
190 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Tom Chichester
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
