Question about Maytag MZD2766GES Side by Side Refrigerator
Jennair JCD2389GEQ Sim montha ago had problem with keeping freezer cold enough. Had Defrost board replaced and problem disappeared. Then had Maytag recall done last month. Now having similar symptoms as last time. Freezer temp setting turned to maximum.....gets colder overnight but won't go below -10 degrees...and then warms up to + 20 degrees for most of day... I checked the coils for icing..but they are not iced up. Any suggestions???
    Problem Solver:
  • 4 Answers
Turn it off for 24 hours it has an ice build up
Posted on Jun 22, 2009
Maytag performa fridge model# ptb1753grw freezer freezing up and the fridge not getting cool. i defrost freezer remove the ice then the bottom fridge gets cold again. but it keeps freezing up again.
You have one or more of your defrost components that are bad. Defrost heater, defrost thermostat, and defrost timer or board depending on model are the 3 components.
Nov 02, 2017 | Maytag Refrigerators
Have a ge model # GTH21KBXAWW. The freezer works fine. The bottom half does not keep cold.
Freezer is cold but refrigerator is warm
  1. Evaporator coils are frosted over
If your issue is that the freezer is cold but the refrigerator is not as cold as it should be, the first step is to check the defrost system for problems. A key indicator in determining if perhaps you have a refrigeration defrost problem is visible frost on the evaporator coils. If your unit has frost you will need to check your defrost heater assembly, the defrost control, and the evaporator fan motor for a malfunction. Replace any erroneous parts as necessary.
  1. Damper
If your issue is that the freezer is cold but the refrigerator is not as cold as it should be, the damper door could be broken or jammed. The damper is a door that opens and closes to allow cool air to flow from the freezer into the refrigerator unit, and if it fails to operate correctly, not enough cold air will enter the refrigerator to keep it cold. The damper can be replaced if it is no longer operating properly.
  1. Thermistor
If your issue is that the freezer is cold but the refrigerator is not as cold as it should be, the thermistor connected to the control board might be defective. The thermistor is a sensor that examines the temperature inside the unit. If the part is defective, the refrigerator could not cool properly.
  1. Temperature control board
If your issue is that the freezer is cold but the refrigerator is not as cold as it should be, the temperature control board could be at fault. The temperature control board distributes voltage to the fan motors and compressor to keep them functioning. This board is very often misdiagnosed as the culpable cause and it is recommended to proceed with the troubleshooting process of elimination prior to replacing this part.
  1. Defrost thermostat
Another issue that can cause your freezer to be cold while the refrigerator is not as cold as it should be is the defrost thermostat. In order for the defrost heater to activate to melt away any excessive frosting on the evaporator coils, the defrost thermostat must sense that the temperature is cold enough to activate the defrost heater. Without this continuous cycle, the frost will excessively build up on the coils and prevent proper air flow inside the unit. The defrost thermostat can be checked for continuity with an ohm meter; if it's not present, the thermostat will need to be replaced.
  1. Main control board
A possible cause for a freezer that's cold but refrigerator that's not as cold as it should be is the main control board. The main control board acts as a "brain" for the unit, controlling the defrost cycle, compressor, and run time. However, it is an uncommon cause for this issue. This board is very often misdiagnosed as the culpable cause and it is recommended to proceed with the troubleshooting process of elimination prior to replacing this part.
Feb 25, 2015 | GE Refrigerators
Maytag fridge (model MBB2256GES) freezer cold but fridge warm
Sounds like one or more of ofvyour 3 defrost components have failed which are defrost heater , defrost thermostat, and defrost timer or board
Nov 06, 2017 | Maytag MBB2256GES Bottom Freezer...
Refrigerator not keeping cool enough. Freezer staying cold.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 26, 2011 | Maytag MTB2656G Top Freezer Refrigerator
MSD2756GEB maytag. freezer is working properly.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Jun 21, 2010 | Refrigerators
Fridge side not cold enough but freezer ok.
It is possible that your adaptive defrost assembly found inside the fresh food section and behind the control panel is defective. If not we need to check the defrost heater and the defrost thermostat. Sea Breeze
61005988 Adaptive Defrost Assembly
Jul 25, 2009 | Refrigerators
MAYTAG REFRIGERATOR ICE MAKER NOT WORKING, AND REFRIGERATOR ONLY COOL WHEN TURNED UP TO HIGHEST LEVEL. FREEZER IS COLD
Is the freezer cold enough to make ice maker operate. 10 degrees or less.
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp .
Jul 03, 2009 | Refrigerators
Refrigerator not cold
Very usual issue - defected defrost control unit - replace it and keep warranty paperwork from part supplier. :))
Jul 22, 2008 | Maytag MSD2456G Side by Side Refrigerator
Warm fridge, cold freezer
If frost in back wall of freezer it's not defrosting. This will keep cold air from getting to refig,. section. It may require a main board replacement. Or a defrost control replacement.
Oct 24, 2007 | Maytag MFD2560HES Bottom Freezer French...
Maytag MZD2766GES Side by Side Refrigerator Logo
151 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
