Question about Microsoft Xbox 360 Console
I have similar problem
My disk won't play at all unless i remove my hard drive, but if my hard drive is removed it won't let me get past the first screen...so im kinda stuck
My console has stopped reading discs. It accepts a disc into the console but then nothing happens. It says its reading the disc but then says "open tray". We have tried a variety of discs brand new and used but still no improvement. What shall I do next?
Posted on Aug 18, 2009
  • 21 Answers
You'd better send it to the official center to repair.
http://www.gameyeeeah.com
Stuck disk
I assume you are refering to a CD/DVD rather than a hard drive or USB drive. If so, have a look on the front of the drive you should see a small hole. Get a paperclip or similar and push it into the hole, this will manually eject the drive for you.
Hope this helps
Leon
Feb 09, 2013 | Computers & Internet
Pavillion P6000 won't recognize any drives
If you are trying to install Windows XP then -
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP.The FIX.Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.
Jun 15, 2012 | HP Computers & Internet
I have a Dell Latitude D600 laptop. Every time I turn it on, it says that the primary hard disk cannot be found. It is long past its warranty. Solutions?
There's no way you can fix a hard drive unless you're a professional who deals with at on the regular .... Other then that ...what you need is a new hard drive....
Apr 04, 2011 | Dell Latitude D600 Notebook
Hi i made a partition on my hard drive and when i turned my laptop back on i get this message, non system disk or disk error replace and strike any key when ready can you help please thanks ross
if you create a new partition on your hard drive with anything but partition magic or something similar, the process of creating the partition will wipe all data from the entire hard drive to resize the partition. you will probably need to re-install Windows fresh unless the utility you used just happens to have an undo (not very likely) playing with partition sizes of used drives is not advisable.
Mar 21, 2011 | HP Compaq tc4400 Notebook
Need to remove hard drive
his document provides instructions for the removal and replacement of the hard drive for the R3000, R3100, R3200, R3300, ZV5000 and ZV5200 series notebook PCs.
Use the video as a guide while following the written instructions below.
To view the video press the Play button on the player control bar below the video.
To stop the video press the Pause button on the player control bar below the video.
To restart the video press the Rewind button on the player control bar below the video.
NOTE:Flash Player from Macromedia is required to view this video. Visit the Macromedia website (in English) to download and install Flash Player.
Step 1 - Remove the battery
Slide and hold the battery release latch to the unlock position.
Use your finger to lift the battery up and out.
Step 2 - Remove the hard disk drive
Remove the two Phillips-head screws that secure the hard disk drive to the base enclosure.
Lift the inside edge of the hard disk drive to unseat the hard disk drive connector from the system board.
Remove the four Phillips-head screws that secure the hard disk drive to the hard disk drive bracket.
Remove the hard disk drive from the hard disk drive bracket.
Pull the hard disk drive out of the bay.
Place the hard disk drive in a static dissipative bag.
Dec 05, 2010 | HP Pavilion ze4300 Notebook
How do I remove the hard drive in Toshiba SatellitePro A10 EN? (Removing the plastic cover exposes only the end of the hard drive. I'm reluctant to just start pulling on it!
  • The original Toshiba Satellite Pro A10 HDD is fitted into a Toshiba Satellite Pro A10 Hard Disk Drive cradle - Toshiba Satellite Pro A10 HDD caddy.
      • Gently remove the cradle from the laptop, yes pull on it
      • Unscrew the original Toshiba Satellite Pro A10 Hard Disk Drive & remove it from the cradle.
      • Screw the new Toshiba Satellite Pro A10 Hard Disk Drive into the cradle & refit the cradle into the laptop.
      • Re-install XP or Vista
          Aug 21, 2010 | Toshiba Satellite A10 Notebook
          No manual for 320 GB desk top hard drive
          its a plug and play just connect to the sys and start working on it
          but be careful that u connect the power to the Ext.HDD first and then after that connect it to the USB port
          similarly safe remove from the Sys and remove it only after u see the msg It is safe to remove the USB drive disconnect the USB cable from the Sys wait for 20-30 secs ten power off the HDD for better performence of the Ext HDD
          Jul 27, 2009 | Electronics - Others
          June 22, 2009 Dear Person, I have an HP-Compaq laptop computer, business model nx9010, s/n CNF3520KL4, with a failed hard drive. I am unable to remove the drive. I have removed the three (3) visible screws...
          http://www.karlin.mff.cuni.cz/~motl/hp-keyboard/manual4700.pdf
          PAGE 39
          1. Unplug the AC adapter, if present, and then remove the battery.
          2. On the bottom of the notebook, remove the hard disk drive rubber screw plugs and
          M2.5×6.0mm screws. (The number of plugs and screws varies by model).
          3. Carefully pull the hard disk drive out of the notebook.
          4. Remove the four M3.0×4.0mm screws from the hard disk drive and hard disk drive tray,
          and then lift the drive out of the tray.
          5. Remove the connector bar from the hard disk drive.
          The manual does have little picture to help you. The link above is to download the service manual.
          Jun 23, 2009 | HP Compaq Business Notebook NX9010
          Hdd password ,how 2 retervie
          There are no backdoor passwords available. The password cannot be removed from the hard disk unless you know the original password to get into the hard disk and you can then remove the password.
          Hard drive password is set to protect data stored on the hard drive from unauthorized access. Removing the hard drive and inserting it into another computer still will not allow access without the password.
          If you cannot remember the password, your only options is to replace the hard drive with a new one and install Windows, the device drivers and your programs etc. to get a fully functioning computer again.
          Jun 03, 2009 | Acer TravelMate 5720-6462 Notebook
          Olympus Voice Recorder WS100
          The recorder is not provided with any installation software. It is considered a plug and play device and should connect to Windows XP or Windows Vista and display as a removable disk drive. You can then copy and paste the files from that drive to your hard drive. The files will play using Winodws Media Player.
          Mar 11, 2009 | Olympus WS-100 Digital Voice Recorder
          Microsoft Xbox 360 Console Logo
          67 people viewed this question
          Top Microsoft Video Game Consoles & Games Experts
          Stormi  Paulk
          Stormi Paulk
          Stu Morris K
          shaun taylor
          Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
