Question about Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer
What is the correct fuel mix for the ryobi 790R trimmer?
  • panilling9
    panilling9 May 11, 2010
    you will hear many ratios and many pros and cons
    here is what i use in everything i have that is 2 cycle (except outboard motor)
    40:1 3.2 oz of 2 cycle oil w/ stabilizer to 1 gallon of 89 octane fuel
    Have been using this for years before ethanol and after ethanol 10%
    noticed after ethanol
    had to ritchen carb.some.
    never had a piston burn,ring stick or cylinder wall score,yet
    maybe someone else will chime in and give their suggestion to help you decide
    Problem Solver:
  • 6 Answers
The window ratio should be fine between 40/1 to 50/1.
Reduce oil ratio by increase gas part if some unburned oil can visible from the exhaust.
Someone else could have a better voice on this matter..
Posted on Jun 24, 2009
French owners manual for weed eater ryobi model 790r
On internet go to www.manuals.ryobitools.com and search for 790r. Next scroll down the page looking for the trilingual manual. Download the PDF version and you will have it quickly.
Jul 25, 2016 | Ryobi Garden
Problems 790r
Carby needs overhauling..
Oct 04, 2013 | Ryobi Three Trimmer Combo
What is the mix ratio on the Ryobi 790r?
1 gallon fuel to 3.2 ounces 2-stroke oil.
May 19, 2011 | Garden
Won't start , can not get primer to work even after replacing primer bulb.
If your fuel filter is clean, and none of the fuel lines are pinched, then you probably need to replace the diaphragms, gaskets, and screen in the carb. Some carbs with the primer bulbs mounted on the carb have a check valve in the primer system. This is the least likely problem, but it is possible that the check valve is defective.
May 07, 2011 | Ryobi 30cc 17" String Trimmer Zrry30530...
Need a repair manual for a Ryobi 790r fuel line diagram
Here is a page that will take you to a download of the exploded view of the trimmer ..
http://safemanuals.com/user-guide-instructions-owner-manual/RYOBI/790R-SERIALS-810046371-THRU
on the right side there is a place to select the download .
Jun 02, 2010 | Garden
I have a 790r and the detent pin on the lower
That pin should be the same as other Ryobi trimmers. Find one for one of them and compare. Lee
Sep 15, 2009 | Garden
Ryobi 790r gas trimmer
I can think of three possible causes that would be a good place to start looking:
- clogged tank ventilation, causing vacuum in the tank during use (check for this when opening the gas tank cap, you should hear a "suction sound" and the engine should prime and start afterwards)
- clogged fuel filter
- fuel filter/ fuel hose is not moving freely inside the gas tank causing it to **** air in some operating positions.
May 28, 2009 | Ryobi Garden
Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer Logo
925 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Rexter1
Phil Walker
Phil Walker
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
