Question about GE (PSS26MSRSS) Side by Side Refrigerator
GE Refrigerator - how do I take grill off?
I want to take the faceplate (kick plate? grlll?) at the bottom of the refrigerator off...........there is a little arm on either side of the grill.......have tried squeezing those and pulling grill off.........grill wont come off. I want to vacuum the coils and check the drip pan. How do I get the grill offr?
    New Friend:
  • 4 Answers
It should just pull right off. Try downloading a manual from the makers website.
Posted on Dec 15, 2017
SOURCE:
  • 65 Answers
SOURCE: Water Leaking from the bottom of the Refrigerator
is the floor of the freezer a sheet of ice? if so the defrost drain hole is clogged.
Posted on Feb 16, 2008
mikedurland
  • 481 Answers
SOURCE: GE GSS 25QF Side by side Refrigerator
Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Posted on Jul 14, 2008
SOURCE: red glow (from defrost heater?) at bottom of rear panel in freezer
This is from the GE Appliance "Knowledge Database" Web site:
Refrigerator - Explanation Of Red Glow
In a no frost refrigerator, the defrost timer activates defrost heaters in the evaporator section (rear of freezer) which heat up and melt the frost off the evaporator coils. This process lasts for approximately 25-45 minutes and usually happens up to twice a day.
During this time, there will be no running sounds, no fan noise, and you may hear water dripping or sizzling as it hits the heaters. On side by side models, you may even be able to see an orange glow at the bottom of the freezer.
This is normal.
Posted on Sep 10, 2008
SOURCE: refrigerator keeps running
I have the same problem. I called a service rep for G.E. and he said that there are 3 thermodisc
sensors behind the white evaporator cover. He gave me a price to repair that was completly out
of range for the problem. I paid him for his service call and sent him on his way. I then decided to
to order the parts from a factory online parts center at less then half the cost of my estimate not
to mention that when I was ordering the part the Factory emailed me a complete parts breakdown showing the Thermodisc and that my unit only has 1 thermodisc not three installed from the factory.
I ordered 2 one for a backup just in case. I deiced the buildup and installed the disc after 24 hours the refrigerator was working normal for about 4-months. Once again the refrigerator iced up and stopped cooling so I called the factory tech support and they told that it is normal to have some ice on the cover of the evaporator and the thermodisc is at that point supposed to open the cooling circuit to let the unit go into defrost mode and then close again. The Tech said that I had a bad
Thermodisc again so I put the spare one that I ordered in and it also worked for about 3 months
now I have the same problem ????????
Brad
Posted on Sep 14, 2008
Sea Breeze
  • 4655 Answers
SOURCE: GE Side by Side Refrigerator no longer cooling.
If not cooling or signs of not defrosting we will need to check the compressor start components, fan mortors and motherboard. Let me know and I can guide you through this. Sea Breeze
Posted on Apr 05, 2010
Testimonial: "Hi Sea Breez. I have ordered and replace the defrost heating element. I'll check the coils in a day or two. Thanks for providing the service manual!"
Where is the defrost timer on #PSC23NSTDSS GE side-by-side refrigerator
It is usually in the bottom behind the plastic vent /grille plate.
Apr 03, 2018 | GE Refrigerators
Is the filter behind the kick plate on the Kitchen Aid Superba made in 1998?
Hi, the filter should be on the bottom kick plate and should have a cap of the same color as the kick plate.
Hope this helps
I’m happy to help further over the phone at https://www.6ya.com/expert/roger_e8672cfe67bf61a1
May 23, 2014 | KitchenAid Superba Architect KSCS25INSS...
Do i need to clean coils?
you dont new unit are sealed, some have a filter in front at the bottom vent.
Sep 23, 2012 | Maytag MSD2651 HE Side by Side...
Water paddle is not depressed still aater is keep running through water line
First onplug your refrigerator. Second Turn off you water supply before it reaches refrigerator. This will prevent shock, water damage, and possible electrical shorting behind and at bottom of the rear panel of your refrigerator. You are going to need examine the=> Dual Outlet Water Valve WR57X10051=> and test the==> Part Number WR23X10224 Dispenser Switch Unplugging power at top or bottom and sometimes hidden by kick plate or the top freezer door hinge cover plate there will be a plug that can be carefully disconnected. Doing this eliminates the long way of finding a multi problem solution. Here is your models Service manual=> PSS26MSRSS Service Manual to follow and disconnecting the plug under the cover of freezer door hindge will eleminate both dispenser pressure switch and the Click Here=> WR55X10415 Interface or HERE Click Here=> GE ARTICA PROFILE TECHNICAL INFORMATION I will be here should you have more questions, Thanks for using Fixya... Sea Breeze
Aug 06, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker stopped working?
First you should know your machine has the ice bucket in the door, witch means you have a electronic eye that checks to makes sure the ice bin can recive more ice, this device is in the freezer on the right side with the red light. this light can give you a idea of whats rong. first you should open both of your refrigerator doors and remove the bottom kick plate and look in the kick plate grill for the tech sheet. this sheet should ave all the error codes for your ice maker emiter board and should give you some tests to preform for your model.
May 24, 2010 | Whirlpool GS6NHAXVS Stainless Steel Side...
The water dispenser is displaced on my Whirlpool refrigerator ED5RHAX NO00. I am trying to remove the face plate but am afraid to crack it. Any suggestions?
I eventually managed to remove the faceplate, using a screwdriver in the bottom slots of the faceplate and prying it loose, sliding it up to remove it from the slots at the top of the faceplate.
Aug 31, 2009 | Whirlpool GS6NBEXR Side by Side...
Vacuum condenser light of sub zero 650 is on - how to clean it
We recommend vacuuming your condenser every 3 - 6 months. Cleaning the condenser is important for the overall operations of the unit including cooling functions. A dirty condenser may lead to warm temperatures in the refrigerator and freezer. It may also cause the unit to run excessively. It may contribute to condensation or frost inside of the compartments. If the condenser is not cleaned properly it may even cause premature failure of mechanical components in the unit. Condenser Cleaning - All Models Before cleaning the unit, shut the electricity off at the control panel. When you clean the condenser, wear gloves to avoid injury from the sharp condenser fins. Use a soft bristle brush and vacuum to remove dust and lint from the condenser. To avoid bending the condenser fins, be sure to vacuum in the direction of the fins, up and down. Clean the condenser every three to six months or sooner if you have pets. 600 Series Framed and Stainless Steel louvered grilles: First remove the grille screws located at the bottom of the grille. Tilt the top of the grille forward and release the springs from behind the grille, then lift off. Overlay Panel Grille: To remove, lift up then pull out at the bottom and down to release from its mounting bracket. Remove the two black screws in the lowest louver of the grille. Tilt the bottom of the grille out and away. It will release from the top of the grille. Model 601RG Stainless Steel Grille: Remove in a similar fashion as the overlay grille panel. 700 Series All Units: At the bottom of the unit, remove the four screws holding the kick plate/grille in place. It will then slide forward, giving you access to the condenser area. 400 Series 424/424FS At the bottom of the unit, remove the screws holding the kick plate. The condenser is located behind. 427/427R: Remove the four screws holding the kick plate/grille in place. It will then slide forward, giving you access to the condenser area. 430: First remove the screws located at the bottom of the grille. NOTE: These screws (Phillips head) are accessed with the door open. Tilt the top of the grille forward and release the springs from behind the grille, then lift off. 200 Series 245, 249, 315W Remove the kick plate at the bottom of the unit, giving you access to the condenser area.
May 30, 2009 | Sub-Zero 650 / O Bottom Freezer...
Wheel adjustment on a ge fridge
if you take the front kick plate off by pulling on it. once the front kick plate at the bottom of refrig. is off bend down and you will see 1 bolt head that looks bigger than the rest of them. 1 on each side of the refrig. now if you need to lower the refrig turn to the left. to raise turn to the right. this do it for you. thanks eddy
Jan 03, 2009 | GE PSS26SHRSS Side by Side Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
75 people viewed this question
Top Refrigerators Experts
Brad Goodale
Peter Taylor
Matt Sicignano
Level 1 Expert
