Question about Pioneer AVIC-F700BT Car GPS Receiver
My unit will not turn on when i start my car
When i start my car my pioneer f700bt wont turn on. when i first bought it a few months ago i had this problem but it would eventually turn on after many minutes or shut down while i was driving
    Brigadier General:
  • 4,090 Answers
Change battery, or check charge wire if hard wired. i would think your battery needs complete change. The reason for delay is usually the fact that it has reached the end of its life and takes some time to build enough charge to drive the display. The power pull is greater than the ability to store, so that is why it shuts down
Posted on Jun 22, 2009
Pioneer avic-f700bt wont power on at all.. the battery was changed . How do i reset it ?
it is possible that it was damaged during the battery replacement.
one thing you can still try is to hard-reset it. the reset button is left of the eject button. press it for 30 seconds. if that fails - contact the repair center
Mar 13, 2012 | Pioneer AVIC-F700BT Car GPS Receiver
Who supplies map updates for pioneer avic f700bt
Pioneer. They only drop updates for their NAVs every once and a while though. If the update has dropped for your unit you can order the update CDs from them in most cases (only if they don't drop a model that trumps your unit). You better believe that they are going to tax you for it though. I looked into buying an update CD for an old N2 that I had and Pioneer wanted 250.00 for it. I ended up buying a burned copy off of ebay for 5.00 and it worked fine. Go figure... Check pioneers website to see if they even have the update... If they do then you might be able to download it peer to peer and save yourself a few bucks!!! Check out www.avic411.com as well. That's where I go to get all of the goodies for free...
Good Luck!!!!
Jan 23, 2010 | Pioneer AVIC-F700BT Car GPS Receiver
AVIC-F700BT Destination Menu-Address isn't lit up. Can't input.
It turned out that one of the harnesses wasn't connected...:-) I only noticed when I took the unit out and checked the connections.
Jan 10, 2010 | Pioneer AVIC-F700BT Car GPS Receiver
I have the same problem but i have AVIC F700BT it keeps rebooting
go to the AVIC411.com they can answer a bunch of your questions.
Sep 29, 2009 | Pioneer AVIC-F700BT Car GPS Receiver
AVIC-F700BT won't work after dealer did some work on it
Have you tried updating the firmware? A new version is available from the Pioneer website. You will need a blank, formatted SD card. Unzip the files from the Pioneer download and copy to the SD card. With the key out of the ignition put the SD card into the unit. Put the key in the ignition and turn to position I to turn on the F700BT. The update takes around 10-15 minutes. Ensure that no unnecessary electrical accessories are on in order to save battery life.
If that fails you may wish to check out www.avic411.com.
Jul 10, 2009 | Pioneer AVIC-F700BT Car GPS Receiver
Avic-f700Bt doesn't play DVD's
The AVIC-F700BT was not designed to play DVD's. If you wanted that capability you should have purchased the AVIC-F900BT. You can play video on the AVIC-F700BT from your iPod or USB Drive or SD Card or even from one of the AV inputs (mini jack on front or RCA's on the rear of the unit).
Jul 09, 2009 | Pioneer AVIC-F700BT Car GPS Receiver
Pioneer Avic-F700BT worked perfectly fine for 7 months but....
Hello!
My pos just did this today after I got in a hot car (had windows up for security).
Symptoms:
Briefly displayed the PIONEER default splash screen, LED lighting was the default ... light/bright pink (to match pioneer?).
Then screen goes black, then backlight gets fully dimmed and LED dims to darks white (R,01G,01B01)
Wouldn't really respond to anything... but plays CD in background.
I had a brainstorm while sitting in my car at ACC (ignition) and reading the lame online TS guide.
I turned my car to ON and put the gear shift in REVERSE.
The screen flashed to the password, and flashed black again....
Some how the system stablelized after some time and I resurrected it*.
* After tinkering I found ALL settings except the NAV data/settings had been lost.
In addition I believe corruption has occured in the memory holding the voice data. TTS... that phone thing voice command wont display when i press down on the Multi-nav? dial. Also system crashes when I try to access language settings. Sometimes a Windows CE error message bled thru reporting a fatal application error. Illegal operation request...
Hope this helps. I think my POS is going back to cartoys before my 30days is up.
Pity
Jun 05, 2009 | Pioneer AVIC-F700BT Car GPS Receiver
My stereo is a pioneer avic-f700bt and it wont play my cds anymore it keeps saying code error 15 and code error 12
Try cleaning the Cd player with a cleaning kit? Does the cd have dirt or scratches? Most of your errors are not so uncommon check these things, and rate accordenly pls.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Apr 22, 2009 | Pioneer AVIC-F700BT Car GPS Receiver
Pioneer AVIC-F700BT Car GPS Receiver Logo
299 people viewed this question
Top Pioneer GPS Experts
Marvin
Marvin
David Burbee
David Burbee
Are you a Pioneer GPS Expert? Answer questions, earn points and help others
