Question about Amana DLE330RAW Electric Dryer
Amana LE7153WM, I need to replace the heating element. how do I removed it
5 Suggested Answers
  • 958 Answers
SOURCE: heating element - amana le8107w2
the heating element is located at the back. you can remove the back cover and access it from there.
Posted on Feb 23, 2008
canbruce75
  • 1776 Answers
SOURCE: My Amana dryer model number LE7153WM does not heating
The thermal fuse and the heating element would be the likely suspects. Both can be checked with an ohm meter. If there is no continuity, it indicates a defective component. Neither is repairable and if either component is bad, it will have to be replaced. Hope this helped. Good luck.
Posted on Jul 16, 2009
  • 1214 Answers
SOURCE: replace electric heat element in Amana dryer
You can find an exploded view of the dryer on searspartsdirect.com. Looks like you access from the rear service panel.
Posted on Dec 11, 2009
SOURCE: getting to heating element/thermal fuse for amana model LED 20AW
I just replaced mine by taking the bottom off, but in hindsight I think I should have been able to do it by just removing the lower front panel. With long arms, you should be able to reach back and loosen the two bolts holding it in place. Good luck!
Posted on Apr 20, 2010
I have the part to replace broken heat element on Amana 6100; where are the screws holding it in place?
Replace Amana NED7200TW Heating Element Heater Coil ...
? 10:43
https://www.youtube.com/watch?v=5469BpQpJZQ
Dec 14, 2014 - Uploaded by Mike Griswold
How to replace the heating element on your Amana NED7200TW Dryer. ... Pulled apart my dryer and ...
Oct 31, 2015 | Amana Kitchen Ranges
How do i remove and replace heating element and where is it located
Here is the element to order.
Here is a video to show you how to replace the element. The model may be a little different but the process is the same.
Feb 14, 2013 | Amana Dryers
LE7153WM- Runs but does not heat. Coil is not "open". what do I check next?
If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 22, 2010 | Amana Dryers
Replace electric heat element in Amana dryer
Dec 11, 2009 | Amana ALE643RB Electric Dryer
Jul 16, 2009 | Dryers
Does not produce heat to dry clothes
The ehating element is relatively easy to replace. You should be able to find a scematic wiring diagram in the owners manual. If you dont have one check on line they may have one on thier web page. While you are doing this go ahaed and check your master thermal fuse. It will be depicted onm the diagram to. The fuse is usually the cause.
Apr 27, 2009 | Dryers
Getting to heating element/thermal fuse for amana model LED 20AW
Apr 05, 2009 | Amana Dryers
No heat coming from Amana Dryer
2 screws at the bottom of front panel if no screws there, then pry top off with wide flat screw driver then look inside toward top of front panel remove two more screws and the front should lift right out then remove screw/s in center of drum and lift out of cabinet there should be your heat element
Jan 17, 2009 | Amana NDE2335AY Electric Dryer
Heating element - amana le8107w2
Feb 22, 2008 | Kenmore 63942 Dryer
HEating element
The heating element is located in the bottom left corner. You will need to remove the drum for access. Once you have the drum out of the way, look for a square box with wires attached. There are 10mm fasteners that hold the heating element to the vent. Rome the screws, mark the wires and positions then remove the heating element. Before replacing the element make sure the thermal fuse and the high limit switches are not faulty.
Jan 10, 2008 | Amana DLE330RAW Electric Dryer
Amana DLE330RAW Electric Dryer Logo
135 people viewed this question
Top Amana Dryers Experts
Tim Whalen
Sal De
Marvin
Marvin
Are you an Amana Dryer Expert? Answer questions, earn points and help others
