Question about Canon PIXMA MP610 InkJet Printer
I have a severe paper jam from the cassette of my printer. The paper is jammed behind the rollers and I can't figure out how to get to the paper to clear it out. When I turn the machine off and then on, the rollers turn and push the paper out a little bit, but the jam is not clearing. Can any one help
  • chj110437 Jun 22, 2009
    In moving the printer to see how to remove the cover, I found an access panel in the rear. Opened it up and there was the jammed paper. removed it and I was back in business.
    Thanks
    Scholar:
  • 122 Answers
Your best bet is to take the cover off. Once it is off, you will have better access to the paper that is stuck. If you can access the gears on the side, you can turn them manually to help move the jammed paper along, otherwise, a long set of forceps or needle nose pliers may come in handy.
Posted on Jun 22, 2009
Kyocera mita km2530 paper misfeed jam00
This usually means that no paper has been fed from the paper cassette or the machine was turned off when you had a paper jam.
Remove the paper cassette from the machine and ensure that nothing is stopping the paper from feeding.Also look into where the machine locates in the copier to ensure that no paper is jammed behind the cassette.
The paper feed rollers may need cleaning or replacing.
Jan 03, 2012 | Kyocera Mita KM-2530 Laser Printer
Sir! the problem of our kyocera mita fs 3800 is this that it gives us message that the paper is jam please open the cassette 1.and remove the paper. we opened the cassette 1 checked the tray but there is...
Try cleaning the paper feed rollers for that cassette. Sometimes the rollers get dirty causing the paper to slip and not feed from the cassette causing the machine to register a paper jam.
The rollers can be cleaned with rubbing alcohol and a cloth.
Apr 04, 2011 | Kyocera Mita FS 3800 Laser Printer
I have a hp laserjet 4250 printer it had a paper jam in tray 2 i have cleared the jam but it keeps saying i still have the jam in tray 2
There is still paper stuck in the printer. try lifting the printer off of tray 2 to inspect it or here it is straight from the service manual...
Jams in tray 2
Table 7-10 Causes of tray 2 jams
Cause Solution
The feed or separation rollers are dirty, worn, or damaged. Clean the rollers. If they are dirty after cleaning, or if they are
worn or damaged, replace the rollers.
The pickup roller is worn or damaged. Replace the pickup roller.
The tray 2 paper pickup assembly drive gears are damaged
or the assembly is defective.
Check the drive gears in the paper pickup drive assembly.
Replace the pickup drive assembly if the gears are
damaged. See Paper-pickup drive assembly.
The tray 2 pickup solenoid (SL101) is damaged. 1 Disconnect the connector for the tray pickup solenoid
from the dc controller PCA (location J92).
2 Measure the resistance between the cable connectors.
3 If the measured resistance is not approximately
160 ohms for the HP LaserJet 4200/4300, or 110 ohms
for the HP LaserJet 4250/4350, replace the tray 2
pickup solenoid.
The tray 2 lifter-drive assembly or the stack position
sensor (PS107) is defective.
Replace the lifter-drive assembly. See Tray 2 lifter-drive
assembly and/or Printer switches and sensors.
The dc controller PCA is defective. Replace the dc controller PCA. See Dc controller PCA.
Dirty, worn, or deformed pick-up roller, cassette separation
roller, and cassette feed roller.
Clean the rollers if they are dirty. Replace any worn or
deformed rollers. The cassette separation roller and the
cassette feed rollare are to be replaced together.
Damaged gears in the cassette pick-up drive unit. Move the gears in the cassette pick up drive unit. If the
gears are not rotating correctly, or are damaged or worn,
replace the cassette pick-up drive unit.
Dec 25, 2010 | HP LaserJet 4250 Printer
Making loud noise ml1650 printer jam paper feed paper feed problem paper jam
Pull out a paper cassette and under you see paper feed roller (it is rubber), just clean roller with cloth and water or alcohol
Nov 21, 2010 | Samsung ML1650 Printer
Hp laserjet 4520n: Attention indicator is blinking, printer is not printing showing paper jam in tray 2. No jam actually !!!
Look at the feed rollers.
If you pull the paper cassette out and look into the now exposed area, you will see two rollers in the machine, just above where the roller in the front of the paper cassette was positioned.
If these rollers are worn, they will not grab the paper and pull it out of the paper cassette. This will cause the machine to think that there is a paper jam, even though no paper is found in the machine because the machine is looking for the paper via a paper path sensor in the front of the machine, just a few inches up from the paper cassette.
Look closely at these rollers... they should have a "rough" surface. If any of them are smooth, you will have to replace them.
There are two blue hub rollers and one white roller.
Part #'s:
Blue: RM1-0037-000CN (Qty.2)
White: RM1-0036-000CN (Qty.1)
Oct 25, 2010 | Office Equipment & Supplies
Paper jam in cassette 3 whit reciclater paper
just try to clear whit wet cloth or alcohol paper feeding roller or replace it whit new one.
May 11, 2010 | HP LaserJet 3800dtn Printer
Hp 4mv printer paper jam
take out the cable and then press the power button for 1 min
Feb 11, 2010 | Office Equipment & Supplies
Paper jam in HP Laserjet 4V
remove the cassette you can see two or 3 roller down the printer clean that roller and try.....
Oct 07, 2009 | HP LaserJet 4mv Printer
Roller drags several sheets of paper and results in a paper jam
Open your printer and release jam paper then solve problem.
Apr 09, 2009 | Lexmark E322 Laser Printer
Dell 1700 often jams in one spot
Just in case you don't know where the rollers are in the paper cassette...remove the paper cassette drawer and he rollers are at the top of the entrance to the drawer. There are two rollers, grasp one between your fingers and gentle pull the roller down to see the mechanism better. Rotate both rollers and you may find a build up of dirt/grime on either or both. Simple clean them with an appropriate wet cleaner & lint free cloth.
Mar 04, 2007 | Dell 1700n Laser Printer
Canon PIXMA MP610 InkJet Printer Logo
116 people viewed this question
old marine
old marine
