Question about E-Machines eMachines Monitor E15T4
Emachine monitor flickers with horizontal lines
Thanksfor your help..this starts and stops every few mintues ..
looksas tho my screen was shaking ..tried connection etc... dont know what else to do thanks
  • 51 Answers
Re: emachine monitor flickers with horizontal lines
If you have another computer handy....hook the monitor up to it to see if the problem remains, if it does not you might want to focus on the video card.
Posted on Dec 07, 2007
0 characters
3 Points
My moniter screen go's dark with a bright horizontal white line in center flickers
the driver board is bad in the monitor. Has it been in a place that is super hot like in a car? If the verticle driver chip disconnects from the matrix driver array, it will all squish into a single line in the middle of the screen like you are describing.. might try opening and blowing where the driver board connects to the LCD matrix (bunch of connectors on a plastic flat cable/bus connecting to the end of the LCD panel.. heating them could allow them to reconnect.. Its worth a try, right? It has worked for me about 60% time.
Feb 03, 2014 | Envision Computer Monitors
Monitor intermittent power problem and horizontal green flickering lines
separate wiring. touching wires creates cross-talk of signals.
Jan 28, 2014 | Computer Monitors
Monitor intermittent power problems. Horizontal green flickering lines
You have to check the ESR in tha caps in power supply with esr meter.
If you dont have one just replace all capacitors in the power section(there are severals of them)This is the simptom of low esr in the capacitors.
Return the monitor in factory settings.
Jan 28, 2014 | Dell Computer Monitors
White horizontal lines flicker and screen goes off.
check the wiring inside the monitor, pull the sceen out and move the wires with the screen on so you can see when it's working. then tape the wires where it works.
Dec 16, 2009 | Proview PL926WBi 19" LCD Monitor
Mugen MC1524D horizontal line shake on upside
Find the button that says DEGAUSS push it...
next try to increase your refresh rate of the monitor which is controlled by the video software in you computer...right click in a blank area go to properties at the bottom click-> on that hit the Settings tab look for ->advanced box towards the bottom right->click on the Monitor tab -> in the middle it will say "Screen refresh rate" use the drop down arrow and select at least 70-75 Hertz.
this just may stop it from jumping about...good luck and hope this help...
Apr 23, 2009 | SAMTRON 55V 15" CRT Monitor
Ghosting, Flickering, Green Sparkeling Lines, Color Washout.
I had a similar problem on a different monitor and fixed the green sparkles by selecting a lower refresh rate.
Aug 15, 2008 | Samsung SyncMaster 204B 20.1" LCD Monitor
Same thing is happening with my emchine as well. Mine is a T6412 series machine. I boought this machine a year and a half ago. Suddenly one morning the monitor started flickering. At first I thought may be some problem with the cables. I tried with different cables. Same problem. then I thought maybe my monitor has gone bad. So I went and bought a new Samsung monitor. Even with this new monitor the problem remained. So, I am assumng now that the problem is with my computer and not the monitor. Can someone please help. I do not usually come to this site. Can you please email me your solutions and help directly to Thank you so much for your help.
Jul 08, 2008 | E-Machines eMachines Monitor E15T4
Horizontal lines
i suggest you change video board .
Apr 19, 2008 | Samsung SyncMaster 152N 15" LCD Monitor
Flickering crispy screen
maybe ur screen was put into a lot of magnetic interference. so check for any magnetic rays emitting devices like speaker adapters etc. a simple check would be to degauss( its in the screen properties). raja
Feb 28, 2007 | LaCie Electron IV 19" CRT Monitor
E-Machines eMachines Monitor E15T4 Logo
446 people viewed this question
Top E-Machines Computer Monitors Experts
buzz flewhart
buzz flewhart
Ricky Ostrom
Ricky Ostrom
Brian Sullivan
Brian Sullivan
Are you an E-Machines Computer Monitor Expert? Answer questions, earn points and help others
