Question about Toshiba Satellite A25-S279 Notebook
Screen has a vertical flicker - Toshiba Satellite A25-S279 Notebook
    Scholar:
  • 155 Answers
Check you standby battery of your laptop. If it doesn't store power from the power supply then it must be replaced. That might cause flicker in your desktop since the battery can't supply power to the unit and it is depending much on the power from the adopter.
Or if you are fun of logging off computer without proper log off process then it will destroy your battery and even the unit. Extra care must be given attention to your PC notebook because once you have problem with PC laptop, there are just two ways you can do, either fix it or throw it away. Others though, they have to sell it. Still others give that to Humanitarian organizations that needed it :)
Posted on Jun 22, 2009
Lg55lv4400-va 55" flatscreen tv has developed a wide flickering vertical flickering stripe down the screen. Has been fine . Goes away once in a while. An Ideas what is wrong ?
Main power supply regulator board can cause this. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Nov 03, 2014 | Televison & Video
Lg55lv4400-va 55" flatscreen tv has developed a wide flickering vertical flickering stripe down the screen. any Ideas ?
Vertical lines showing up after being on for awhile
Eh, I can't be too sure, but it sounds like it's either a heat issue, a signal issue, or a backlight issue. Either way, if it's still under warranty I'd send it in.
May 06, 2013 | Sharp LC60LE835U AQUOS Quattron 60" 3D...
My Toshiba M55 Laptop has a vertical 'ribbon' of flickering. Is it fixable?
Maybe your screen is going bad or the video card inside the computer is going bad. Try connecting another monitor to the computer to isolate the problem. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the computer. If the Borrowed monitor displays ok without the vertical ribbon then your lcd screen is bad and your video card is good. If the Borrowed monitor displays the same vertical ribbon as your lcd screen then your video card inside the computer has an issue.
The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
May 31, 2012 | Toshiba Satellite M55-S329 Notebook
Sony Trinitron Colour TV Stopped showing and switch light flicker
The vertical output IC has failed/Power to the vertical IC is out/ or there is bad solder on the pins of the vertical output IC.
Dec 01, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Flickering multi-colored line in the middle of the screen.
You have a failure in the vertical deflection circuit. This could be either a bad vertical chip, the power supply that runs the chip or a bad capacitor in that circuit. This is usually a repair best left to a professional. There is a small possibility that it could be bad solder connections. If genlty tapping the unit temporarily solves the issue you can try and resolder the pins on the vertical chip LA7841 is the part number. There is also a resistor 1 ohm 1 watt. If that resistor is open you can assume the IC is bad
Oct 26, 2008 | Sanyo DS27800 27" TV
Flickers and Lines
you have the vertical circuit "closed" you have to repair it checking
transistors and capacitors . if you can  it this work may be at low cost - few dollars
Mar 21, 2008 | Dell UltraSharp 2000FP 20.1" Flat Panel...
TV Flickers up and down and screen is shifted to the right w/ red color dominating the screen.
Hi
The most likely problem is the auto focus module.
A costly repair.
If you are going to fix it ask for a rebuilt one.
Part# CS00022 R
Feb 29, 2008 | Hitachi 50UX58B 50" Rear Projection...
Toshiba Satellite A25-S279 Notebook Logo
96 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
