Question about Eiki EIP-2500 Multimedia Projector
No power to Eiki EIP-2500 projector
I've lost all power to my Eiki EIP-2500 projector. I replaced the bulb but still nothing. Is there a reset switch or a fuse i need to replace inside the unit??
Look for buldging capacitors, or capacitors with black on the tops of them (like they got hot). Bad caps have left me dead in the water. Also look at all of your transistors (the ones with 3 prongs at the bottome (emitter collector base) look to see if some of them look burt or melted. Some transistors will have only 2 connected or maybe even one clipped off. Power transistors commonly have a screw at the top and screw into a "heat sink" or an aluminum block to help with heat. Hands down.... capacitors 9 out of 10 times have left me dead in the water. Heads up, capacitor manufactuers are manufacturing caps so that it's hard to see when the go bad, (buldge or blacken at the top). Looks like the old meausure voltage in parrallel and amperage in series will have to apply for these fixes. Get a schematic, change caps, check fuses for continuity. on my Eiki EIP-200 i notice a little buldging on C727 on my main power board (the board withthe Giant capacitor on it). Anything hot looking or burn marks, usually a replacment part is in store.
Posted on May 12, 2012
  • 2,237 Answers
There is a fuse on the power supply. if the fuse is good, you'll need to replace the power supply.
Posted on Nov 18, 2009
Where can I find a service manual for the Eiki EIP-2500?
difficult to find online, try comparable model of SHARP XG-MB55X
May 24, 2012 | Eiki EIP-2500 Multimedia Projector
How to remove top cover of Eiki EIP-2500 projector
loosen all the screws from the bottom ( one is in the middle) and two at the back ( edge)
press the grill on exhaust fans side near the heat warning mark.Lift carefully the rear and turn towards the lens side, BUT BE CAREFULL that some points of the upper cover will not scrape of some smd parts from the mainboard !!
Eiki EIP 1600T projector will not power on. Projector was running when power went off for just a few seconds. Will not power back up now. I have power to projector.
inside there is a thermal fuse, that might be activated, because the cooling of the lamp did not happen after the power surge.
You need to remove the upper cabinet to reach, but do this very carefully !!
May 22, 2011 | Eiki EIP-1600T DLP Projector
Is it possible to connect a projector and a flat-screen tv and control both with a laptop computer? (the flat screen would be used instead of a projection screen)
when connected at the same time, you need an active signal splitter, or
connect the flat screen to the monitor out terminal of the EIP-2500.
Apr 03, 2011 | Eiki EIP-2500 Multimedia Projector
I had a bulb burn replaced both bulbs worked for a couple of days but now it wont power up only lamp1 light blinking. I have tried taking bulbs out and putting them back in still nothing, also the lamp...
the lamp units should be properly aligned with the 2 very tiny switches
between them. If not lamp led will blink.
If lamp led is continuously on, lamp timer has to be reset, according instructions that come with new units.
Original lamp modules are AH-45001 and AH-45002, two different
units needen for 1 projector, reset procedure is different for each lamp !!
Dec 21, 2010 | Eiki EIP-4500 DLP Projector Multimedia...
Need a new remote control for a EIKI EIP1. How do I order one? I am in Perth Western Australia
Hello, I couldn't find any remotes available for this projector.
Try contacting Eiki directly with the form on the page below
Click here:http://www.eiki.com/ContactForm.aspx
Sep 20, 2010 | Eiki EIP-2500 Multimedia Projector
Remote won't turn on Eiki EIP-2500 projector
Try cleaning the IR port on the projector (and the remote itself). These can get enough of a dust layer build up that they can't "see" the infrared signal being sent.
Feb 08, 2010 | Eiki EIP-2500 Multimedia Projector
I thought my light went out on my Eiki projector, it is a eip 2500. I replaced the lamp, but it still will not power up. I tried a different plug and still no power.
if there are no leds on the top, replace the power supply. if the leds are on and the fans are running, it may be the colorwheel or the ballast.
Jan 06, 2010 | Office Equipment & Supplies
Eiki EIP-2500 Multimedia Projector Logo
576 people viewed this question
Top Eiki Office Equipment & Supplies Experts
jasbo
jasbo
neOen
Level 1 Expert
Jaime Hernandez
Are you an Eiki Office Equipment and Supply Expert? Answer questions, earn points and help others
