Question about Samsung HLR5064W DLP Projection TV
Why does my Samsung DLP tv turn off by itself, sometimes after 1-2 minutes?
    Champion:
  • 205 Answers
Either the lamp is aging or the vents are blocked causing the thermal sensor to over heat.
Posted on Jun 28, 2009
    Guru:
  • 114 Answers
It looks like is the tv lamp..
lets try to clean your tv grave a compressed can air and remove all the dust that your tv haves.
and if it still docent work then it is the tv lamp.
http://www.discounttvlamps.com/default.asp
Posted on Feb 09, 2010
2 Suggested Answers
savenabuck
SOURCE: Problem with tv turning off by itself.
I had a friend with the same problem. He had to clean the components and fans in the set. The accumulated dust had caused the set to run hot and a safety switch was the tv off. He purchased a few cans of compressed air and, as he blew the components and fans out, used a vacuum to capture the blown dust. Good luck.
Posted on Dec 27, 2007
I have a Samsung HL-R5678W DLP TV that is acting up. When I first turn it on everything works, after 5 minutes it shuts itself off. After 2 minutes it will come back on without sound. It will do this a...
U turn tv on hear any squiling,grinding or motor noises?Picture show up before it shut down picture have flashes of black&white within the picture?Yes,to all of these,this tv have a colors wheel and it dead,require the colors wheel replacing.No,none of these problems.The tv projection lamp,if in this tv like a 1 1/2 or 2 years,tv ben on an watches like 4 or 5 hours a day?The "LAMP" LED light indication lite up or flahes,the projection lamp life is over.Require a new projection lamp.
Oct 22, 2010 | Samsung DLP HL-P5663W 56" TV
Tv shuts off and on by itself dlp 5064 tv only seems to do it when the tv is on for a long period also when the power is on the standby/lamp is illuminated
Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. I
Jul 26, 2010 | Samsung DLP HL-P4663W 46" Rear Projection...
Why is my 42" dlp tv turns itself off after awhile?
the power supply is not working fine. your tv needs preventive service so that semiconductor, diodes and capacitors are changed on the power supply before it switches off completely on its own.
do it fast
okay
Jan 05, 2010 | Samsung DLP HL-P5663W 56" TV
I have a 50" DLP Samsung that keeps turning off by itself
There can be several causes for this, few of which you can do anything about. However, a few things to try:
1) Replace the batteries on your remote control.
2) Try resetting the logic functions on your tv by unplugging it for a minute, then plugging it back in.
3) Try covering up the infra-red receptor on the front of your TV to see if you're getting unwanted signals from the receptor. taping a piece of foil over that area is perfect. If it doesn't stop after doing these two things you'll probably need to take it to a shop.
4) If this does stop it, then look for unexpected signal sources. Have you added a remote control extender? Added a new device to your audio-video system? Changed to a new remote?
I hope this helps. Joe
Dec 09, 2009 | Samsung LN-S4692D 46 in. LCD HDTV
I HAVE A DLP SAMSUNG 52" T.V. IT TURNS OFF BY ITSELF EVERY THIRTY MINUTES. CAN YOU TELL ME WHAT THE PROBLEM IS?
Has it been getting loader lately? (fan noise)
if so check link it could be the common fault described below
Samsung Color Wheel
http://www.jangro.com/electronics/samsung-dlp-replace-color-wheel/
Nov 24, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung dlp HL56A65 turns off and on by itself
It looks power board problem.
You need to get service from Samsung.
Mar 04, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung TV will turn on and off several times, then stay on.
First, need to check the power bar(if you use).
then. if don't use power bar, need to check the power board.
Dec 12, 2008 | Samsung HL-R7178W 71" HDTV
Samsung HLR5064W DLP Projection TV Logo
1,973 people viewed this question
Jerry Greenberg
Jerry Greenberg
