Question about Frigidaire GL38LKEC (LP) Grill
Inconsistent lighting but plenty of gas flow
I have a Frigidaire Gallery series 38" gas grill and only 1 of the 3 ignition "forks" light consistently. There is power that gets to the other 2 forks because they spark periodically. It is like the spark in the forks is not hot enough to ignight the burner. There is plenty of gas flow at the location of the defective forks allowing a match to immediately ignight the burner. Is there a place to get replacement "forks" and these forks appear to be hardwired into the lighter system, so if a person was to get a new "fork" how would a person rewire the new part it.
  • jameso469 Jun 22, 2009
    I stated that that there was no issue with the flow of gas only it appears to be in the "heat" of the ignition fork as a match ignights the burner easily. I want to know if new ignition forks are available and how to replace the inconsistently firing ones in my grill.
    My question was a 2 part question and you answered the first in giving me the part number. Now tell me how to wire this new igniter electrode in place.
  • 15,935 Answers
You are looking to replace the igniter electrode.
CLICK HERE for a replacement part.
Frigidaire Part Number: 5304444439
Thanks for using Fixya - if you requier further clarifications - please use the "Continue with this Expert" option so we are connected in the future.
Thanks :D
Posted on Jun 22, 2009
If you notice that your Barbecue is getting hard to light or that the flame isn't as strong as it should be, take the time to check and clean the VENTURIS. In some areas of the country, spiders or small inserts have been known to create "flashback" problems. The spiders spin webs, build nests, and lay eggs in the BARBECUE VENTURI TUBE (s)obstructing the flow of gas to the BURNER. The backed-up gas can ignite in the venturis behind the control panel. This is known as a flashback, and it can damage your Barbecue and even cause injury. To prevent flashbacks and ensure good performance the BARBECUE BURNER and VENTURI assembly should be removed from the grill and cleaned before use whenever the BARBECUE has been idle for an extended period of time.
Also, when you lite the BBQ, make sure that you turn the gas on at the tank, wait a couple of minutes and then turn the knob on and light the burner. This is to make sure that the pressure is regulated and sufficient prior to lighting.
Hope this helps!
We have a 3 week old Webber Q220 and the ignition does not work - plenty of gas but no spark
Sorry bout your luck. I have a webber. Cheaper modek, and it does the same thing. I.leave my lid closed ...turn it on wide open wait 30 seconds and start lighting.
Jan 01, 2014 | Weber Q Grill
Heater is a Dayton 3E-133E used very little. weak spark won't ignite gas
yes they do go bad some times they have a hairline crack in them and the will spark but never light the gas they have drove me nuts many a time , for no reason they will not light , then replaced it and wham it works .
Mar 01, 2017 | Dayton Heating & Cooling
Frigidaire professional series gas stove does not light. When handle is turned the "clicking" sound happens, with the smell of gas but no flame. what could be problem? 3 other burners work...
A few months ago I lost one igniter on the left front burner. It clicks and gas flows but wont ignite.Now when I turn on the left back burner, the gas still flows but I hear clicking on the right side, not from that burner. It wont light either.
Dec 17, 2010 | Frigidaire FEF336BC Electric Kitchen Range
The gas burner is not lighting
You may have an issue with not getting enough gas. Also it could be that the igniters are bad. Have a local repairman check it out, you dont want to mess around with a gas system without knowing what your doing just for safety sake.
Dec 12, 2009 | Frigidaire Gallery Series GLRT83TEK 30"...
How do i light this gas grill, it is a charbroil quantum....it was borrowed from our friend, who is now not picking up the phone...
Checklist:
1-Make sure propane tank has propane in it.
2-Turn regulator (valve attached to propane tank) on.
3-Turn burner dials on, usually there is a "light" or "ignite" position to let the most gas flow to start. If there isn't, just turn it/them to high.
4-Listen for the hissing, if you hear some hissing from the grill, it has gas flow.
5-Turn the dials back off and give 3-5 minutes for gas to clear.
6-Turn dials back on and hit the igniter button.
That should do it! :)
Sep 22, 2009 | Grilling
Gas Dryer blowing cool air and will not heat up.
Look inside door and get the model number for me. Could be igniter, gas solenoids or temp control switch inside. Let me know, Thanks Sea Breeze
Mar 19, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frigidaire Gallery Professional Series - No clock/oven functions
i have an old model of the fridgedare gallery professional series stove. After self cleaning, the ignition sparks for the burners will not come off, they keep clicking and only stops when i pull out the plug. can you help me with this situation?
Nov 01, 2008 | Frigidaire FGB24S5A Gas Single Oven
Ducane 3400042 lighting problems
Good answer... but remember (if you have the regular burners on... The Rotisserie will not light.) 1. Cut all knobs off... Then push and hold in Rotisserie button as you turn to high.
2. Press ignition button, until you hear rotisserie ignite. 3. Keep holding in the rotisserie button until the thermostat realizes the gas is on and burning. (IT must get hot enough to keep gas flowing.) Hope that helps, Dave
Apr 08, 2008 | Ducane 30400040 Stainless Steel Grill
Frigidaire GL38LKEC (LP) Grill Logo
117 people viewed this question
Top Frigidaire Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Marvin
Marvin
Are you a Frigidaire Grilling Expert? Answer questions, earn points and help others
