Question about Cyberhome CH-DVD 300 DVD Player
Orbitron dvd3119 stuck in pscan. I have to turn unit on manuelly
0 characters
1 Points
How can I get ride of the pscan split screen view on my memerex vcr-dvd player without the remote control and no manual
I'm not sure what is model number of your VCR-DVD combo so providing you general info to turn off pscan.
Put disc in player, press play to have distorted picture then press stop button to stop playback.
Now press and hold Stop button on unit for 6 seconds that will turn off pscan mode.
Or let me know exact model number of your player to find out solution.
May 28, 2010 | Memorex MVD-2045 DVD Player
Devide the tv screen in 2 and have PSCAN written
Pscan is progressive scan, go into the menu and turn PSCAN off
Mar 21, 2010 | DVD & Blu-Ray Players
My memorex dvd shows a split yellow pscan sing
On most of the Models there is a Pscan button on the back of the unit in the middle. just turn that off and you should be good to go.
Aug 22, 2009 | Memorex MVD4544 DVD Recorder/VCR
Stuck in pscan, no book, help
By "pscan", I'll assume you mean progressive scan mode?
disconnect unit from A/C power. Hold in power button, plug unit into wall whilst holding in power button for 10-15 seconds.
If that doesn't reset unit, then simply hold power button in for 30 seconds whilst power is already applied to the unit. That not work?
Toss unit into the garbage.
Feb 21, 2009 | Coby DVD-224 DVD Player
Split screen with pscan warning on
I had the exact same problem and I consulted the manual. All you have to do is turn the PSCAN swtich off. It is located on the back of the dvd player. Then turn the dvd player back on and your problem should be fixed.
Jun 07, 2008 | Memorex MVD2022 DVD Player
Stuck on P-Scan
Most DVD players has a P-Scan on/off button in the remote control. On the other hand, Memorex in some of its models have the P Scan switch at the rear of the unit. It is a slide switch.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Apr 25, 2008 | Memorex Progressive Scan DVD Player...
pscan showed up on my dvd player and I shut the switch off on the back...all good! thanks for the inpu!
Mar 08, 2008 | Memorex MVD2042 DVD Player
Hi ! There is a switch at the back of the DVD which controls the pscan. just turn it off.
Feb 16, 2008 | Philips Recorder DVD-R72
Make sure the player is off (Standby). Turn off the PScan switch located on the back. Turn it on and give it a try.
Dec 27, 2007 | Memorex MVD2022 DVD Player
Cyberhome CH-DVD 300 DVD Player Logo
32 people viewed this question
Top Cyberhome DVD & Blu-Ray Players Experts
Level 1 Expert
Are you a Cyberhome DVD and Blu-Ray Player Expert? Answer questions, earn points and help others
