Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Whirpool washer, only number on the back is 3357976
I doubt that 3357976 is the model number but when it starts and its time for the agitater to churn and wash, there is a loud humming noise and no movement, U dont see how to get inside the unit to check things out either. Thank u
J
    President:
  • 744 Answers
Sounds like i could be a bad coupling, most whirlpool washers are direct drive so there is not a belt, there is however a linkage between the motor and transmission. Pull the machine out and tilt it back. check on the floor directly beneath the washer for a pile of blck dust (this can be an idication of a bad coupler) make sure you wedge something underneath it so it dont fall on you while working on it. remove the pump by levering off the 2 clips, push the pump aside then remove the 2 screws holding the motor clips...remove the wire harness on the motor and then remove the 2 clips holding the motor in plce with a screw driver. now you should be able to drop the motor out...the coupling is the tripod shaped plastic attached to the motor and another to the transmission, they have a black round rubber linkage with 6 holes...examine this for damage and replace if damaged. re-assemble washer in reverse order.
Posted on Jun 23, 2009
Old GE washer, agitater starts, tubs stats to move
The main seal on the tranny is leaking. This is a cheap and easy fix. This machine is worth the effort to repair it by the way. Here is what you do and it is fairly easy to do although it sounds complicated. Remove the agitator and the tub anti wobble. Then remove the inner tub. Get the tub eal off and then remove the tranny. Flip it over and remove the bottom. Knock out the seal and put a new one using a little oil to lubricate it. Add 2 quarts of motor oil to the tranny and put it back together. Re install the tranny and she will be good as new. Nothing is complicated about this repair and no special tools are needed.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 20, 2009 | Heating & Cooling
WHIRPOOL WASHER LSQ9564MQ0 Started making loud
judging by the description i would say more likely the coupler
its a three peice part that sits between the mototr and transmission, kinda like a clutch,
anyway it is easily repaired
and available on appliancepartspro.com
type in your model number.....
look for motor coupler
Oct 13, 2009 | Washing Machines
Whirpool Duet - Soap not getting into wash cycle
O.K. Is the water draining out properly? If the filter is blocked then your washing will be churning in dirty water as the machine will drain for a maximum time then rinse etc. in the used water.
May 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
WHIRLPOOL WASHER MAKES A LOUD RATCHETING SOUND
CALL YOUR REPAIRMAN AND SEE IF HE CAN FIX YOUR WASHER FOR YOU. IF NOT, THEN IT IS TIME TO BUY A NEW WASHER. GOOD LUCK.
RODNEY
Apr 11, 2009 | Maytag PAV2300 Top Load Washer
Kenmore 90 plus series: heavy duty super capacity won't agitate
this is the site to find out how to fix your washer.
you have a broken drive coupling.
it probably wont agitate or spin, but will fill and drain.
you need to remove 2 screws from the control panel, hinge it back and then remove the 2 brass colored clips that hold the cabinet to the base. once you do then pull the entire cabinet forwards to a 45 degree angle and pull it off the base.
then pull the 2 clips off pump and then 2 more on the motor. that will allow you to get to the drive coupling. you will find it to be broken.
replace it with part number 285753a for about 15-20 bucks.
Jan 31, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
My ge washer wpre6100g clicks during agitation part of cycle...
sounds like the agitater drive is stripped its a plastic piece under tha agitater you just grab the agitater work your fingers under the edges and **** up on it and it snaps off then remove the 5/16 screw put a new block on and snap the agitater back on
Jan 29, 2009 | GE Profile WPRE6100G Top Load Washer
Agitater spins around, water won't drain.
The model number is located under the lid.
Nov 17, 2008 | Roper RAS8445KQ Top Load Washer
Old Fridgidare washer
As there are so many variations on this brand a model number will get you quick results:)
Nov 01, 2008 | Washing Machines
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
370 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
