Question about Dishwashers
Dishwasher won't run.
Is there a reset button underneath the dishwasher? is there a reset button
  • 4 more comments
  • Anonymous Nov 10, 2007
    dishwasher has light flashing in it
  • JacknJuls Nov 13, 2007
    Dishwasher won't run- our power went out and since it's come back up, the dishwasher won't power up.
  • dmgsls Dec 16, 2007
    dishwasher quit mid cycle now has no lights on, and won't run
    is plugged in, no problem with outlet
  • Anonymous Dec 06, 2008
    Just stopped. Filled with water. Power to the line, but the dishwasher is as dead as a door nail.
  • leonalarue Jan 19, 2009
    yep... same problem. got up one morning went to run it, and NOTHING. no lights, NOTHING.
  • carrielynn68 Apr 02, 2009
    Breaker tripped and when I reset it the dishwasher never came back on. No power at all...dead as can be. Im thinking is there a reset button? It has never given me trouble before
Buy a new one!
Posted on Mar 01, 2008
Kenmore elite dishwasher model 630 Smart Wash light is flashing
You may want to try:
Press a series of four buttons in quick succession. Press "Heated Dry," "Normal Wash," "Heated Dry" and "Normal Wash" to instruct your Kenmore dishwasher to run a short diagnostic test.
Wait for two minutes while your Kenmore dishwasher runs its diagnostic test.
Press the "Cancel/Drain" button once your dishwasher has completed its diagnostic test. This should reset your dishwasher control panel.
Check to make sure that there's no standing water in the bottom of your dishwasher. Standing water in your dishwasher may indicate that your dishwasher has stopped mid-cycle. You will need to press the "Cancel/Drain" button before you can reset your dishwasher control panel.
Dec 18, 2013 | Dishwashers
Bosch dishwasher model shu43c05uc diagnostic code C1 at start then P0. what does this mean?
You seem to have inadvertently put it into the test sequence. Try pressing the two reset button simultaneously (usually the reset buttons are 1st and 3rd from left each with a dot underneath, if this does not work, press the button between the two resets (2nd button) P1 should come on then press the right reset button. The unit should run through a test cycle for approx 20mins and eventually reset the module, this is indicated by 0 in the display. Please repost if further assistance required.
Feb 28, 2013 | Bosch 24 in. SHU43 Built-in Dishwasher
I have a Bosch SHU9955US/14 (Integra) dishwasher. There is currently a 0 with and asterisk showing on the display and the unit will not run.
see this causes and fix it. God bless you
Thermal Fuse If the dishwasher won't start the thermal fuse might have blown. The thermal fuse helps to prevent damage to the dishwasher by turning off power so that it doesn't overheat. Once blown, the thermal fuse will have to be replaced for the dishwasher to work.
Door Switch The door switch, or switches, are sometimes called interlock switches. The door switch prevents the dishwasher from running while the door is open. If the dishwasher won't start, the switch or switches might be defective. To access the door switches, remove the control panel or inside door panel - depending on the model. They can be tested for continuity.
Main Control Board The main control board provides power to nearly every component of the dishwasher. If the dishwasher won't start the main control board might be defective. YOU should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
Touchpad and Control Panel If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced. On some models the touchpad and control panel are sold together and will need to be replaced at the same time.
Touchpad If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced.
Timer The timer allows power to flow to the proper parts at the proper times. If the dishwasher won't start, the timer might be defective. Keep in mind that timers are often misdiagnosed as the cause of a problem. Check other components first before replacing the timer.
Sep 29, 2012 | Bosch Dishwashers
Blinking light on Kenmore Pro 13873K dishwasher: won't run
May be the drain pump is jammed. Try to clean the area and after that try to reset the panel. Download the user manual and there must be the reset sequence.
Nov 18, 2017 | Kenmore 13873 Stainless Steel Built-in...
Whirlpool quiet partner 1 won't drain all the way suddenly
Hello.
HERE ARE TOOLS NEEDED AND INSTRUCTIONS ON HOW TO SOLVE THE DRAINING PROBLEM BELOW.
(A) Clean cloth(s)
(B) Wrench (if necessary)
Whirlpool brand dishwashers come in black, brown, stainless steel or white finishes and a variety of sizes as well. Most Whirlpool dishwashers are energy efficient, and many have features such as a sanitizing rinse, enhanced sound effects, large capacity tubs and adjustable shelves and racks. However, none of these features will help users much if the dishwasher is not draining. While this issue may require professional repair, some troubleshooting steps may help determine if there is a relatively simple cause for the problem.
1 Verify that the Whirlpool dishwasher has not lost power due to a power failure or motor overload. Wait a few minutes to see if the motor automatically resets and resumes operation. Reset the circuit breaker or fuse if necessary.
2 Press or select "Start" to resume the cycle if the dishwasher was stopped mid-cycle. Choose a new drain cycle if necessary to remove excess water from the unit.
3 Turn off the dishwasher and unplug it from power. Examine the connection between the dishwasher and the garbage disposer, usually located underneath the kitchen sink. Make sure the disposer knockout plug was taken out between the two.
4 Run the garbage disposer in the kitchen sink to remove potential blockages.
5 Remove objects that may be blocking the drain on the dishwasher. Clean out the drain hose at the rear of the dishwasher.
Thanks.
Nov 06, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
My SHY56A05UC Basch dishwasher runs and dose not shut off
The dishwasher is stuck in drain mode because there is water in a catch leak area underneath, it may have been caused by soap suds over flow or disposal backup. Remove bottom kick plate and vacuum out any water, then run dishwasher again and look for water leaks.
May 21, 2009 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Frigadaire Dishwasher PADLOCK Icon lit, dishwasher won;t run
I have an FDB1502RGB0 model but had the same problem. I reset the circuit breaker and its working fine now. I'm not sure what caused the problem but it seems to be fine now.
Jan 04, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
I have a Whirlpool dishwasher model ADP951. the green light is continually flashing and will not run, help with this would be most appreciated.
Have a look underneath dishwasher by removing front bottom access panel, the one touching the floor. Look for a round plastic disc about size of 4 jam lids together, centre front of dishwasher. Inside of it is a foam disc that will float up off the base of the dishwasher if water causes it to do so. This floating up will trip a switch. Clean base of dishwasher of water and maybe test the switch with multimeter. Reset fault by holding down start button.
Apr 26, 2008 | Whirlpool Dishwashers
Brandt dishwasher
The lights on my dishwasher are working but It doesn't do anything when I hit start.
Dec 05, 2007 | Dishwashers
Dishwashers Logo
328 people viewed this question
Top Dishwashers Experts
