Question about Ruud UBHC Air Conditioner
My air conditioner is not blowing out real cold air
My rheeme air conditioner doesn't seem to get cold enough
    Sergeant:
  • 340 Answers
Have it cleaned sounds like symptoms are like a dirty unit .
Posted on Jun 22, 2009
The blower starts before its warm and it blows cold air for about 30 sec when its shutting down .
When any unit 1st come's on, you'll always have some cold air that's in the ducts that will blow out before you get warm air. If your duct work is uninsulated in a cold basement or crawl space then it will be even more noticeable. When the unit is heating from the Heat Pump mode, it takes a little longer for the gases to get warm enough so you'll fell heat. When it gets cold enough for the unit to switch from heat pump to the gas or electric heat source, you'll get warm air faster. If you have gas heat, some Thermostats have an anticipator setting for the gas valve. If it's set wrong it will effect the on/off cycle of the gas valve.
All duct work in non heated and a/c spaces, including inside walls,above dropped ceilings, in attics and crawl spaces, must be sealed & taped at the seams and joints and then insulated and taped.
Most new construction has solved that problem with insulated duct board, flexible insulated supply's and special tape.
Dec 12, 2013 | Rheem 13PJL30A01-RHLLHM3617JA 2.5 Ton 14...
My air conditioning united seems to be blowing cold air, but its not cooling down my room? Plus the temperature reading never lowers. Thank you in advance.
Sounds like the rear coil may be stopped up with dirt, etc. If it is, the unit will not cool properly. You may just be able to unplug it and wash it out with a hose and sprayer from the back of the unit. If its real dirty, you will have to pull the unit out of the window, take the case off and clean it real good. If you wash it out from the back, be sure you can do it when you can leave the unit off for an hour to dry. Let me know if I can help you any more of if this doesn't work. Stay cool. mark
Jul 10, 2011 | Haier HWR05XC7 Wall/Window Air Conditioner
Hi, I have an amana ap125hd portable air conditioner and for some reason is doesn't produce cold air anymore. Then fan blows and the compressor kicks in, but to no avail, no cold air. I took the unit...
replace it,most likely the freon leaked out,if the compressor is running and the fan is blowing but not getting cold most likely you have a leak in the sealed system.
Jul 09, 2011 | Kitchen Ranges
The system does not blow cold air. The liquid line near the furnace does not gets real cold (mildly cold only)
The liquid line will not be cold, but the suction line should be getting cold...sounds like you may have a leak...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
Air Conditioner Trouble - Review the Possibilities
heatman101
May 12, 2011 | Carrier 38CKC024 Air Conditioner
Heater blows cold air when it is 30 degrees out side
heat pumps don't work as effient at that temp thats why they have 2nd stage supplemtial heat
Jan 09, 2009 | Heating & Cooling
(HVAC) Furnace Not Igniting Quickly
Make sure a back draft in the flue is not happening. Wind can blow it out until the flue heats up. The flame sensor may not be close enough to the burner flame. It may be weak and need to be replaced or if its an optical one it may be dirty and not see the flame very well. Its not wasting much gas but it puts extra wear and tear on the gas controls, is noisy, and, as you said, blows cold drafty air. A gas control system that has issues of any kind is not real safe. It needs to get fixed.
Jan 08, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Ruud UBHC Air Conditioner Logo
1,022 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
