Question about Bose Lifestyle 12 System
Bose Lifestyle 12 system control unplugged and plugged back in
Now I have no sound except the occasional pop in all the speakers when I turn the system back on. The jack was plugged back into the proper port. I am in the middle of my 30 minute window where I unplugged the entire system and am waiting to plug it back in. Can unplugging the system control jack and plugging it back in blow the speakers or the receiver itself? I have never heard of this. Thanks in advance for your advice.
    Sergeant:
    Champion:
  • 208 Answers
It could be a bad wire or circuit boaed for the speakers sound but seeing i'm not looking at the item in question it's really hard to say what it could possibly be
Posted on Jun 22, 2009
Hello, We have Bose Lifestyle 12 system. It has been working great until now for 10 years. We moved homes locally with in town. Now when I tried to hook up my system, there is no sound coming out of the...
Please check if the AC cord of Acoustimass module has a good connection to AC outlet, also check all the connections specially the cable that goes to the system control unit jack, for your reference in the link below you can see and download the manual of your Bose system:
http://www.bose.co.uk/GB/en/images/Lifestyle%2012%20Series%20II%20Home%20Theater%20System_tcm6-4071.pdf
Mar 04, 2011 | Bose Lifestyle 12 System
My base module doesn't work anymore , can i replace it with another brand or amplifier
There's a base unit on eBay for bid, currently around $90, expiring tonight at 15:45 PST
http://cgi.ebay.com/Bose-Lifestyle-12-control-system-new-box-w-o-cord-/170595656943?pt=LH_DefaultDomain_0&hash=item27b84b24ef
another $210 Buy-It-Now
http://cgi.ebay.com/BOSE-LIFESTYLE-5-8-12-EXCELLENT-EXTRAS-AND-REMOTE-/260731188231?pt=LH_DefaultDomain_0&hash=item3cb4ca3407
$204 BIN...
http://cgi.ebay.com/Bose-Lifestyle-5-8-12-Music-Center-Near-Mint-/180620466103?pt=Receivers_Tuners&hash=item2a0dd197b7
Bose products are highly proprietary. If they have non-standard connectors from the amp or in the speakers I'd take that as a clue they're NOT compatible with other manufacturers' products.
Feb 02, 2011 | Bose Lifestyle 12 System
My Bose Lifestyle 12 - No Sound
What sound are you putting into the system? Have you checked that the audio you're putting into the system works into some other device? Have you checked that you have the correct input device selected?
If you have checked that the audio going into the system is working properly and you have the correct input device selected then yes, audio in but nothing out = something is broken inside.
Nov 01, 2017 | Bose Lifestyle 12 System
No power
Sounds like the internal 1.6 amp fuse has blown. Its quit easy to change, check the replies I've sent to get access to the unit and the internal fuse.
Oct 04, 2009 | Bose Lifestyle 12 System
Haow do we take apart the woofer lifestyle 12
There is a gap all the way round the rear of the sub woofer between the plastic rear cover and the main body. The top gap in the center you will see what looks like a cog wheel, use a flat head screw driver to turn this untill a flat section sticks up. Make sure it sticks out all the way. Undo the 2 screws on the bottom of the unit just above where all the cables plug in. Slide the rear cover donwards and lift away.
Oct 01, 2009 | Bose Lifestyle 12 System
Can't get video to work so bose works with tv sound
We fixed it. We had everything hooked up right, but - stupid us - we didn't turn the sound off on the TV. Once I turned the TV's sound setting to off, I flipped the speaker switch a few times on the Bose remote, then turned up the volume on the Bose and it worked.
Sep 19, 2009 | Bose LifeStyle 5 Series-III CD Shelf...
No surround sound
It sounds like the speaker wires are mixed up or maybe a setting on the reciever is wrong. Verify your speakers are properly connected. you test speakers using a 9 volt battery or smaller.
Jun 19, 2009 | Bose Lifestyle 12 System
Error code 10 during sound calibration
Please ensure that you have turned on the Accoustimass module, this can cause communication errors when calibrating. Also check that all connections are correctly plugged in as if one is not quite sat right this may give the error, just try unplugging them and plug them back in.
May 31, 2009 | Bose Lifestyle 35 Series II System
Bose surround sound system cuts off
Hi when you turn on check all your speakers work check connections make sure the wire has no stray strands touching the fault could be in the sub unit this is possible / or your speakers one or more could have gone short circuit due to exessive volume thats if you play loud. Had a party lately .Just joking .Regards kirk
Dec 10, 2008 | Bose (321GS) System
Bose - Custom EQ Error: 10
Hi, I have just had the same problem and the advice from BOSE was to turn everything off and disconnect the sub from the main unit, wait 10 mins and turn everything back on, making sure to turn the sub on first.
As it happens i then noticed I had connected the sub via the BOSE link speakers plug to the main unit rather than the correct "MAIN" socket. - so if you are reading this you know I am a fool! But the sound now works.
Basically BOSE confirmed the reason for error 10 is that the main unit is not detecting the sub and speakers.
Anyway, I hope my foolish mistake, helps save time and blushes for anyone reading this link.
J.
Sep 01, 2008 | Bose Lifestyle 28 System
Bose Lifestyle 12 System Logo
375 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
