Question about Mitsubishi WS-65613 65" Rear Projection HDTV
Screen goes black...slight wavy lines..green light is still on
While watching tv, the screen will go black, and wavy lines will faintly show. The green power light is still on. I turn the tv off and then back on..and it will work for about 10 minutes..then do the same thing...now it's getting to where it does it almost every 5 minutes. Does anyone have a solution?
  • micrene27 Jun 22, 2009
    Can you tell me the average cost to repair this board? Is it a fixable problem and worth doing? And will this problem cause the DVD player or any other component to lose signal? When I'm watching a dvd movie. the tv does a similar thing of blacking out..but it turns blue, like the signal is lost but I can still hear the sound through my audio receiver.
    I've had the tv since 2003 so I think it will be worth fixing. Is the y convergence board the same as a DM board? I've been looking at other sites and several people with the same tv/problem mention this DM board and how they replaced the caps and it fixed the issue.
    Have you heard of this?
  • 744 Answers
Hi..
I think without looking at a diagram it could cost you more work and expense for nothing . It would be easier to just say yes replace boards 1 or 2 for example but it would be failing you if u do it on ur own so .
I think it has to be an engineers task to help you actually looking at the set ...
u can go for a replacement for sure..
thank u
hope my solution is useful to u
Posted on Jun 22, 2009
  • 11,896 Answers
It is most likely a failing main board, or a "Y" convergance board.
  • Nate Stansfield
    Nate Stansfield Jun 22, 2009
    It is an average of $250. I believe a tv is worth fixing if it isn't over 5 years old. The problem will effect any video feed.
My LCD TV has a vertical line on the right side of the screen. What causes that?
Search Results
    how to fix horizontal or vertical lines on lcd tv - YouTube
    ? 4:52
    https://www.youtube.com/watch?v=k2QpYJp6MU8
    Apr 12, 2014 - Uploaded by cr4zyw3ld3r
    how to fix horizontal or vertical lines on lcd tv ... Bad T-Con/Mainboard(causes vertical/horizontal lines or half of thescreen is black)
    How to fix / repair vertical lines on half of LCD tv screen ...
    ? 5:23
    https://www.youtube.com/watch?v=8P_i-JIsrYA
    Jan 27, 2012 - Uploaded by chipotletv
    It shows how I fixed the vertical lines on the right half of a Samsung LCD screen tv. Music on video "Crazy ...
    how to fix led tv vertical lines on screen 55 ... - YouTube
    ? 9:47
    https://www.youtube.com/watch?v=zE0eqB4Ppjw
    Nov 11, 2012 - Uploaded by LUFERQUINT
    HOW TO FIX LED TV VERTICAL LINES ON SCREEN 55" MODEL LG ... YOU MAY HAVE, GIVE IT A TRY BUT DO IT ON YOUR OWN RISK!
Jan 26, 2016 | Televison & Video
Toshiba Model 51h84
The wavy when cold is a issue with a board in the set--Hyper board--the warmup until it begins to work will gradually get longer and longer.
The blue: look at set on a unused video input--if see faint curved blue lines with some blue visable on the screen the blue screen control needs to be adjusted just slightly down until the blue and curved lines are not seen.
May 15, 2012 | Toshiba 51H84 51" Rear Projection...
Mitsubishi rearTV has intermittent wavy lines running throughout
Do you have anything to test it in 1080i? Does it do it on all connections or just one? I had a similar problem with my TV that turned out to be a bad input board. Mine would only display 1080i through the Component connections. All others would show pink and green wavy lines. It cost me around 500 to fix it. Unplug the TV. Remove the back cover for the TV. Using a NON-metal object, or gloves, wiggle the input board (that has all the video connections on it) slowly back and forth and see if the problem comes and goes. You will have to have someone watching for you. If something is loose on that board, the problem should show itself. Narrowing down the problem will probably save you money on repair bills.
May 13, 2010 | Mitsubishi WS-65809 65" Rear Projection...
Black screen, red and green line at top of screen, no sound
That is usually caused by a vertical dflection issue if the lines are single and running across the top of the screen. slightly wavy.
Jan 23, 2010 | Televison & Video
We have a samsung rear projection tv with the same problem of fine wavy lines across the whole screen,more visible with light and dark colours, its like watching the tv with fine rain, sometimes the...
Your convergence ICs could be going Bad if so TV will shut down if the one that starts it goes out first STKs big black ICs also 2 resistors l;ow ohm 2.7 ohms near ICs.
Aug 14, 2009 | Samsung Televison & Video
Faint Vertical lines on Samsung LCD TV
Your correct, LCD's don't burn. This sounds like a defective main control module. I would take it in as soon as possible to have it looked at.
May 03, 2009 | Samsung LN-S3251D 32 in. LCD HDTV
Wavy green lines when picture is black
Check out this site. These TV's are known for the CRT's going bad. This site shows how to make adjustments that could help extend the life of your set. Take a look at the first picture, if the lines look like the ones in the picture this site "should" help. The picture shows a problem with the red but don't worry about the color, look at the lines. I hope this helps.
Mar 22, 2009 | Sony KP-57HW40 57" Rear Projection...
Hitachi Projection Color Lines
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 29, 2008 | RCA P52937 52" Rear Projection Television
Green screen crash
i have a projection tv. It is a a Samsung HDTV 55" widescreen. There is a green curvey lines at top of screen. Can you help?
Jan 20, 2008 | Televison & Video
Mitsubishi WS-65613 65" Rear Projection HDTV Logo
89 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
