Question about Maytag MZD2766GES Side by Side Refrigerator
MAYTAG SIDE-BY-SIDE WON'T COOL SUFFICIENTLY
We just had the recall work done on ours as well, and the problem seems to have gotten worse. I pulled out the back panels and defrosted the coil. Worked better for a few days but now it's bad again. Went to defrost the coil again just now, but it wasn't iced up very much, so don't think it's the coil blocking airflow. Fan is working...what's next? Thanks.
    Problem Solver:
  • 9 Answers
MZD 2766GESide by Wide Unit problems
Be sure if you get into the refrigerator disconnect the power!
I posted this earlier below for another problem. you need to make sure anytime you fix a problem like this in any refrig you defrost all ice. I found just stting there the ice will remain for 10 hours in the box. Why I don't know but I saw it happen.
The control could still be the problem if you did not replace the whole bboard. There is a way to check the heater with a meter but I don't remember the value. It has to have Ohms if not it is broken.
I had the same problem and I knew it was the refrigerator. You have to order the control board that controls the fan assy in the freezer. It has an inherent problem with others I see. But don't attempt to change it yourself. There is tricks to it and if you don't do it right you will break more things. I saw the tech broke some tabs and it is stupid way to design something unless you plan to get more business this method.
The control board sits in front of the water filter in the refrigerator. Inside the Temperature control housing cover.
Additionally, you have to take all the frozen food out and defrost manually the fan area and the subsequent ducts to clear it all out. Otherwise, you will have the same problem again. If it breaks and it will. It causes the ice to build up to point you will not get fan movement or airflow. This flow keeps the Icebox from freezing up and causes the air to flow to the refrigerator side.
They make these things so it is harder for DIY to do it.
But they are really simple! At least most of it.
Contrary to popular belief Ice is a good insulator. Once it builds up, no heat transfer takes place because of the inefficiencies it blocks the airflow and etc.
It is my opinion and I stand by it.
I bought many Maytag items and it suppose to have a great reputation. I have now started to look at other providers.
I find these companies are getting cheaper and instead the quality is going down.
So buyer beware not all have across the board quality it depends on the series, the price and the manufacturer.
Oh well another lesson learned.
Here is another problem when using a ice maker unit do not always use the ice crusher. I found that out. The motor that drives the ice crusher is matted with metal to plastic then metal again in the Ice Holder unit.
Guess what, it jams sometimes and it puts great pressure on the ice maker holder unit.
Where the metal meets the plastic is the weakness. It breaks because of in my opinion weak design
The two plastic nibs meeting with the metal motor drive square "U" connector breaks the plastic and eventually you have to get the plastic replaced. I think if I have to order that little part will end up buying the whole Ice holder assembly.
One direction for crushed ice the other direction it turns for solid ice cubes.
I guess I will use the solid Ice cube method until I figure what to do.
Any parts for it replacing the plastic hookup out there?
Good Luck!
Posted on Jul 27, 2009
    Problem Solver:
  • 4 Answers
We turned ours off for 24 hours like you because we had an ice build up....although it is supposed to be a self defroster. This seems to have done the trick for now, I am certain it has something to do with the recall, perhaps a call in to maytag
Posted on Jun 22, 2009
    Problem Solver:
  • 5 Answers
For those who had the control board replaced or are experiencing thefrig side warming while the freezer side continues freezing; Theproblem may (still) be a faulty control board. I fixed the issue byreplacing a $1.00 capacitor on the board. I'm not a techy and it wasn'ttoo difficult to solder. More info on what to do here; DIY Chatroom
Posted on Aug 09, 2009
I have had the same Recall work done on 7/22/2009, Repair man found that the Refrigerator side blower motor fan was not working. My refrigerator has not been cooling properly for a while now. I noticed that the door seal to the fridge side was hotter than normal, this what is causing to not cool properly. Due to the blower fan being out.
Posted on Jul 22, 2009
  • 4 Answers
This seems to be a common problem with these refrigerators. I had the same problem a while back. Sounds like your defrost board is dead. part number is 12002104. You can find it at searspartsdirect.com
Posted on Jun 28, 2009
My 2008 Mazda5 is twisting from side to side when I accelerate, then let off the gas a bit.
Pulling hard seems to me that a bearing may be freezing up/going bad or a brake is not consistently releasing. Is this more noticeable as you break or is there any grinding?
Nov 09, 2012 | Suspension & Steering for Mazda MAZDA5
Our machine Model is SAV205DAWW,, Serial #14701673GJ. Our machine is approximately 5 years old in in above average shape. we are a family of two so the amount we use it is small compared to a large...
your most likely problem maybe the drive pulley and the Helix. you may also replace the drive belt with it. ask the tech and let me know tomorrow.
Feb 08, 2011 | Maytag Washing Machines
My whirlpool vents ice up and won,t cool what part
This is probably not your problem this time, but it could become one in the future. The start device on some models of refridgerator for maytag and whirlpool have been recalled. If your appliance was manufactured in the last 5-10 years you may be having an issue with this component. Mine recently caught on fire at this device that is located near the compressor. If you would like to be a part of the petition for a recall on this appliance contact me at jboooor@hotmail.com
Jun 09, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Side-by-side Maytag lost it's cool
Is there frost on the back wall of the freezer about 1 foot from the bottom ? If so , then a defrost problem . Either a bad adaptive timer (electronic board in control section ) , a bad bimetal (locatod on top of the freezer coils. A small cylinder with 2 wires on it ) or a bad defrost heater . Usually , the adaptive timer is the problem .
Jul 22, 2009 | Refrigerators
Maytag Bottom Freezer MBB2256GES not cooling
you must change out the relay to find out if the compressor is locked , but before this is done let the compressor cool to room temp. then try again.
Phil
Jun 10, 2009 | Maytag MBB2256GES Bottom Freezer...
Maytag, side by side refrigerator stopped working
Check the thermostat which is located in the top left hand coner of the refrigerator. Also check the relay on the compressor to make sure it is not staying open all the time. Also there has been a huge recall on Maytag side by side refridgerators made between 2001 and 2005. I would also try calling Maytag and get the problem fixed by them by recall
Apr 13, 2009 | Maytag MSD2756G Side by Side Refrigerator
Maytag MSD2356AEW Side by Side Fridge not Cooling enough
Deforster not kicking in. There is a chip that is supposoed to kick in thte Auto Deforst on the frezzer side. It fails and the system freezes up and can not circulate cold air form the freezer side to the Fridge side. Simple repair, but yo will needed a service tech for this.
Jul 20, 2008 | Refrigerators
Doesn't cool fresh food
It´s probably overloaded. Any refrigerator has a specific cooling capacity eg x Kg/24hours. you must check that capacity and charge acording to that.
Jun 30, 2008 | GE Refrigerators
Maytag MZD2766GES Side by Side Refrigerator Logo
858 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
