Question about Miele W2240 Front Load Washer
Check drain and check inlet both red lights are showing
Wont work properly water coming from the bottom of the machine , we have cleaned all the pipes and cleaded them
SOURCE:
  • 183 Answers
SOURCE: The washing machine wont start
This indicates either a faulty inlet valve, afaulty pump or a blocked filter Regards Engineer
Posted on Jul 30, 2007
SOURCE: miele novotronic w/m fault light flashing
We had the same problem on a Premier 500 and solved it by tilting the machine forward. Some more water ran out and the lights went off.
Posted on Jan 05, 2008
SOURCE: miele W830
I have exactly the same problem - what was the answer ?
Posted on Apr 05, 2008
Mark Harmer
  • 8 Answers
SOURCE: Inlet blockage red light flashing
Try turning the machine on its side, undo the bottom and check that the polystyrene float (attached to a switch) is not somehow jammed. This float cuts off the water if the machine leaks internally, and produces the symptoms you describe. It's a really good machine so don't throw it away!!
If that still doesn't help then it might also be the motor brushes, which produce similar symptoms - if your machine starts to fill but then flashes and just drains again, it's almost certainly the brushes. This might be the case after you check the float problem.
Posted on Sep 21, 2009
  • 70 Answers
SOURCE: Both red lights flashing for check inlet and
The flood protection device has activated. This is caused by a leak in the machine. It can also be caused if you are not careful when checking the drain pump,water may have gone back into appliance and activated flood protection device. If this is the case Tip machine forward,water in base of appliance will run out, and appliance will work.
Posted on Mar 28, 2010
Hotpoint fdw85 does not drain
sounds like the pump is not working
Jun 11, 2017 | Dishwashers
My miele dishwasher model no G643V1 is not cleaning properly. Inlet/Outlet, Salt or Rinse aid lights not red. Contents all have gritty substance at bottom. Please help!
The problem is most likely that there is still water residue at the bottom of your machine. If the machine is not fully drained it picks up some of the residue and sprays that onto the dishes during the final rinse, leaving an unhealthy and unsightly film on everything.
Remove the bottom strainers plates and make sure that the outlet pipe is not kinked, that there is nothing obstructing the pipe or the pump or selector valve. If possible back flush through the outlet pipe and try draining the machine again before using it again.
Apr 08, 2011 | Miele 24 in. Incognito G843SCVi Built-In...
Wont drain
Following will be the causes
There is a motor/Pump which operates to to drain the water check whether that motor is working.
Check filter and clean it
Check the drain pipeline whether it clear
Check the inlet valve of the machine Sometimes the drain works properly but the inlet solenoid valve will not hold and the water keeps coming in and fills the drum
Thank You
Sep 02, 2010 | Samsung WF337AAL Front Load Washer
E1 error code on my kenwood dishwasher [kwd243a
Hi
The E1error code indicates a water inlet error.
To access test mode: press and hold Normal+Eco, and press Power. Release buttons. Then press Start(display n:01).Press Start again (display shows water level frequency-not important). Press Start again-(display n:03-motor will be running). Press Start again (display n:04-drain pump will run). Press Start again (display n:05-inlet valve will come on and machine should fill with water). You have now tested major components are working-if you keep pressing start you will scroll thru and test other functions, like heater, dispensor etc, but not needed for your fault.
If Machine didn't fill with water in test mode, you probably have a faulty inlet valve (test resistence should be approx 3.7-4 k ohm).
If inlet valve has tested OK ie machine filled with water in test mode then:
Disconnect from power.
Remove side panels (need to remove top, and bottom front panel to then be able to remove sides)
- Check no water in base of machine-water in base will indicate machine has leaked and activated the safety device which shuts off inlet valve.
- If OK, you probably have a faulty flow meter(measures water intake). Located left hand side of machine, large plastic compartment, which has a sensor at the bottom with 3 wires (red,white,black) that go up to control board. Replace entire flow meter assy-relatively inexpensive part.
- If you still have problem, then control board is faulty, it is much more likely to be flow meter .
Thanks for contacting fixya.com
Sep 10, 2009 | Dishwashers
ASKO D3432XLB keeps running, draining but hasn't gone into the wash cycle yet. won't turn off even when I turn the power button off.
Water on lower bottom. Leakage or blocked drain pipe. Is common error. The machine will act like this so that water wont get on your kitchen floor, in case of fault on inlet valve. The machine indicates overflow. Dry out water on bottom, and than the machine will work normaly. But check for leakage. Just in case.
Jul 18, 2009 | Asko Dishwashers
Inlet/ drain light keeps flashing
You have a leak and the bottom pan is full of water. You can remove the cover at the bottom front of the dishwasher and see if the bottom pan is filled with water.
Jul 12, 2008 | Miele 24 in. G665 Built-in Dishwasher
DD601ver2
check for restriction in sump. ie remove rotor, push pipe cleaner or similar from filter sump into rotor sump
Jun 21, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Washer takes in water and immediately drains it out
See that there is enought pressure from your inlet pipe into the machine, maybe someone closed the wall valve. Plug off the wall socket. Check the filters on both sides of this pipe, clean out. Also clean the inlet into machine.
You said the washer will not fill, but is it coming in, the water that is. If this is the case, your outlet pipe from the bottom of the machine is at the wrong height, it should be at about 3 feet above the ground level; your pump pumps this waste water OVER this height. Check these out.
Nov 25, 2007 | Maytag MAH2400A Front Load Washer
Dishwasher not working
Hi Frazzledmum, Miele have a safety float switch in the bottom of the machine. (The float is a polystyrene disc). If the machine leaks for any reason, then the water sits in the bottom tray raises the float switch & all your dishwasher will do is activate the drain pump and flash those red lights at you. The reason is that somewhere under the machine there is a leak that needs to be investigated & repaired so in this instance I'm affraid that you will have to call a serviceman. Kind regards
Jul 22, 2007 | Miele 24 in. G638 Plus Free-standing...
Erroe code F H
jse, most of the time when I run into this problem it's because of the flow meter. This is a reed device that sits in line with the water inlet valve and monitors the water coming into the machine. Things to check; make sure both water valves are on and that the inlet valve screens are clean. (You get to them by removing the hoses to the washer). The drain pump filter is clean. (Remove the bottom panel and unscrew the pump filter and clean out). The inlet valves are actually working. That the drain hose is not too far down the standpipe causing a siphon. All the harness connecting to the inlet valves, pressure switch, drain pump, flow meter and main control are seated properly. You will have to remove the top to get a look at these. Three screws on the top backside and it slides of toward the back. If all these things check out. Then I would suspect the flow meter itself. Easy job. Catriver..
Jun 07, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Miele W2240 Front Load Washer Logo
65 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Marvin
Marvin
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
