Question about Eljer & Elongated Toilet Bowl
Eljer toliet bowl will not fill up, it does not even fill up the
Throat
    Sergeant:
    Champion:
  • 216 Answers
Check the float,make sure its not binding up on something.
Posted on Jun 22, 2009
When flush my toliet the water level in bowl comeback low how do I fix or adjust.
Depends on the make and model of the fill valve in the tank. There is a hose that goes into a pipe that is in the center of the tank. That pipe is the over flow protection but it also fills the bowl.
Mar 26, 2018 | Home
Eljer 0220 toilet leaks from tank to bowl, then fill valve spurts out water from top and around the edges, and also through the tube that goes to the overflow. Replaced the flapper, but still leaks. Also...
When the tank is full and leaking into the bowl reach in and put slight pressure on the flapper and if the leak stops then you may have the wrong flapper or the flapper is not installed properly. If that is not the case then make sure the flush valve seat is not cracked or that the surface is not warped.
Mar 05, 2011 | Eljer 091-0220-00 White Savoy Two-Piece...
Elijer Diplomat toilet flushes perfectly, but after the water in the bowl takes forever to fill up again. You have to wait 10-15 min. before the water is up to normal level and it will then flush...
Pressure assisted toilets have a stainless steel tank that refills under lid,if your refilling bowl it only needs to fill trap for smell,the pressure assist does the rest,thats part of the water saving of the toilet,you don't have a lot of water in the bowl
Jan 28, 2011 | Eljer Aqua-Saver 12" Two-Piece...
Leaks from tank into bowl and when flush as it
Change the flapper with a generic one that will fit that toilet... the OEM flapper is **** and it does not allow for a good flush either...
heatman101
Aug 03, 2010 | Eljer Toilet Onepiece Canterbury ...
Toliet won't get rid of solids
first shorten the chain from flush lever to the flapper valve by one or two links at a time until flushing properly
second the flapper valve might need a wipedown as well as its seal (top edge of tube where water goes down into bowl) the leaking is because the flapper valve is not seating properly.. you may need to replace the flapper itself.. easy to do, and a common part at hardware store.
Jul 08, 2010 | Toto Drake ADA Compliant Toilet with...
On my eljer toilet, I get continuous running of the water. If I shut valve off and pump the tank, the running stops (but only for a week or so). Suggestions? model 150-403 power flush pf/2
I don't know what you mean by "pumping" the tank. If the toilet runs, then either the fill valve is defective or the seal on the flush valve is defective. First, check to see that when you move the float, the toilet stops running. If it does not, then replace the fill valve. If it does, then inspect/replace the seal on the flush mechanism at the bottom of the tank. If this seal is bad, you can usually see water continuously flowing (slowly) into the bowl. You will see ripples on the surface of the water in the bowl.
Jun 01, 2010 | Eljer Home
Low water level in bowl after flushing
The small black tube that goes into the overflow is used to fill the bowl after flushing. Would check to make sure that water is coming out of that tube at full force or if its coming out at all.
May 11, 2010 | Eljer & Elongated Toilet Bowl
No water in bowl
check the water stopper in the bottom of the tank is it closing all the way.
Apr 25, 2010 | Eljer & Elongated Toilet Bowl
Eljer Flushmate Floor Mount Floor Discharge 1.6gpf rim impaction
try putting KLR or even vinegar down the tubes. also using a stiff brush and klr or vinegar, scrub the jets from inside the bowl to help remove and soften it up. your coat hanger may only be compounding the problem by packing it in harder and tighter. when you get it running again, and it is a good one, make sure and put a bowl cleaner that also softens the water. can't say brand names..... but there are several good ones.
Feb 03, 2010 | Eljer Aqua-Saver 12" Two-Piece...
Describe your Eljer &
I have not heard of any toilet manufacturers offering a lifetime guarantee (except maybe for defects in manufacturing), especially since flappers tend to deteriorate with exposure to chlorinated water, fill valves eventually fail, and toilet seats do break. Pick out a replacement that suits your fancy, unbolt the old one from below, and install the new one. Don't overtighten as the porcelain could break.
Jul 17, 2009 | Eljer & Patriot& Elongated Toilet Bowl
Eljer & Elongated Toilet Bowl  Logo
143 people viewed this question
Top Eljer Home Experts
john h
Mike
Charles T Nevin
Charles T Nevin
Are you an Eljer Home Expert? Answer questions, earn points and help others
