Question about Compaq Presario 5BW284 (202493-003) PC Desktop
How do you get the front cover off the 5bW284
I need to change the CD player and I can't figure out how to get it out.
Re: How do you get the front cover off the 5bW284
How about a small breakdown of it.
First of all, look on the back of the case, there is either screws bordering the outside of the case or 1-2 large ones on the side panel. remove these.
Now the Large panel (most of the time on the left side) should easily slde back and reveal the inside of your computer,
Look for the CD Drive you need to remove, it should be held in a slightly concealed case near the top front of the computer, just pull all the cords out of the back and set them aside (do not remove from the board as this makes it easier)
right next to the drive that your going to be removed on the outside of the harness is 2 screws, remove those, and remove the other side to ensure there are no screws on the opposite side. the drive at this point should slide out, if not, like most cases, give it a good push towards the outside.
To install the new drive, look on your old cd drive and look on the back of it, there should be a small area with 8 pins, 2 of them being covered, keep a mental note of those 2 that are covered,(if your drive does not have this, disregard the next step)
place the small peice of plastic that comes with the drive over the same 2 pins that were covered on your older drive.
now insert the CD drive the same way you removed the other one, place the screws into the side and close up the case.
Congrats, after putting the case back together, you have successfully modded your computer.
Posted on Jan 13, 2008
  • 170 Answers
I think for this one you have to remove the outer case of cpu.then , you yourself will find out easier to remove the cd player,there are just a few number of screws to be removed.......
Posted on Nov 04, 2007
0 characters
3 Points
Drive D in my dell computer CD/DVD Drive will not eject
Switch off the pc .Open your pc cover ,Plug the power cable to cd/dvd drive again tightly.
Also you will be plug sata or pata cable again tightly or can change the cable new if you have a spare.
If the problrm is same please change the rubber belt from the cd player,it is located behind front cover
Follow the bellow link.
Good by
Jan 07, 2011 | Dell XPS 400 PC Desktop
How remove DVD From desktop Compaq Presario
have to be a little more clear with the question depends on where you want them removed if the computer oh intalar system for a non-dvd if the system goes to control panel and look for oction says oh add remove program
if you want to put a DVD without need only to plug the computer and remove the cable and put the other one wants to
Oct 17, 2010 | HP Compaq Presario Media Center SR1750NX...
Install dvd rom and remove one of the cd rom's
hi! replacing cd room,open your cpu cover by two quick lock bolt at back side of your pc right side,show on figure w/ arrow where the quick lock bolt.c1c13bc.gifthen pull out cover and you'll cd rack inside your cpu as shown on figureba392e9.jpg release 2 lock screw,and pull out i.d.e cable on cd room terminal also the audio cable next to leftside if have one,next the front cover of cpu thats locking your cd room theres a cliff lock on side opposit of the fron cover lift it by flat screw driver slowly and careful it might broke,after cover was detouched,don't remove any wire connection on front cover,pull out your cd room replace by dvd rom and connect all what has been disconnect on cd room put back front cover,and connect pwer,audio and ide cable again then try to switch on your dvd rom is a plug and play you can install your dvd installer and follow wizard instruction and click finish...regards
Mar 27, 2009 | Dell Dimension 2350 PC Desktop
I recieved the power surge exceeded limits message
might be a compatibility problem with Compaq Presario 5BW284, try using your thumb drive on another computer to check if its still working
Nov 24, 2008 | Compaq Presario 5BW284 (202493-003) PC...
Front cover
Ca you please tell me what type of PC you have? Compaq, HP, Dell?
Jun 13, 2008 | Compaq Presario 5BW284 (202493-003) PC...
Need a new Ethernet Card After Installing XP
big issue with compaq is that not all slot cards are compatible..
this is something that can be handled with a Shared Screen session, if you like.
send a note to my email on profile.
Feb 21, 2008 | Compaq Presario 5BW284 (202493-003) PC...
Removing the faceplate
Hi, I can help you with this. Are you trying to remove the cd-rom drive bay plate or the front panel of the tower?
Sep 16, 2007 | Compaq Presario 5000 PC Desktop
Compaq Presario 5BW284 (202493-003) PC Desktop Logo
75 people viewed this question
Top Compaq PC Desktops Experts
Michael Thomas
Michael Thomas
Brian Sullivan
Brian Sullivan
Are you a Compaq PC Desktop Expert? Answer questions, earn points and help others
