Question about McCall DT1-102001E Stainless Steel
What type of refrigerant do i use in a 1999 ford escort se
  • 11,896 Answers
Any vehicle that is newer than 1995 uses R134
Posted on Jun 22, 2009
Were is the fuel filter located for a Ford escort
One of two places. either under the drivers door inside the frame or tucked up by the front end of the gas tank on the passenger side.
Aug 31, 2014 | 1999 Ford Escort
Will a 1998 escort se transmission fit in a 2000 escort se
Yes it will work.----
For car repair help and all types of solved problem.Click the link below:------
http://technoanswers.blogspot.in/2012/03/car-repair-guide.html
Thanks.
Jun 26, 2012 | Ford Escort Cars & Trucks
Does lower pulley bolt come off clockwise or counterclockwise fo 1999 ford escort se
anticlockwise ,lock the socket up with a nice bar into the chassis and crank the starter motoer this will loosen it for you
Sep 28, 2011 | 1999 Ford Escort
Where are the spark plugs hidden on a 1999 ford escort
You should be able to follow the spark plug wires from the coil to the plugs.
41566138.jpg ^ ^ ^ ^
Hope this picture helps. This is the engine from a 1999 ford escort se not a gt.
Jun 30, 2011 | 1999 Ford Escort
I can't find where to add freon to my 1999 Ford Escort SE Sport....
Open the hood, the low pressure charging port is located close to the firewall on the passenger side of the engine compartment, there is a plastic cap on it. Remove the plastic cap from the port by turning it counterclockwise with your fingers.
Apr 18, 2011 | 1999 Ford Escort
Cuando acelero mi escort guayin 1999 automatica a mas de 2300rpm el motor como q se quiere apagar dejo de acelerar y se estabiliza
hello how are you to change spark plugs do one at a time be careful let car cool before you change plugs changeing plugs saves on gas
Dec 21, 2010 | 1999 Ford Escort
Does the 1999 Ford Escort se manual transmission fit the 2000 escort zx2 manual?
The 4 door transmission will fit, but some of the bolt holes will not line up.
Dec 07, 2010 | 2001 Ford Escort ZX2
Front wheel alignment specifications what should it be on a 1999 ford escort se sedan 4 door. and should it be the same as a 1999 ford escort zx2
Lost track of the number of turns on the tie rods so from 0-to what? how many turns dose it take to put it back to factory toe
Aug 27, 2010 | 1999 Ford Escort
Where is the throttle position sensor located on a 1999 ford escort se?
located on the throttle body,its a flat sensor with usually two small screws holding it on.
Apr 21, 2010 | 1999 Ford Escort
McCall DT1-102001E Stainless Steel Logo
70 people viewed this question
Top McCall Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
Are you a McCall Refrigerator Expert? Answer questions, earn points and help others
