Question about Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft. Front-Loading Washer
Whirlpool Duet HT Blinking Lights at any cycle and won't work
There flashing lights at any of the cycles at the beginning but none of them will actually start. Please help.
  • cathiem129 Jun 22, 2009
    Is there any way to reset the machine?
    It was previously working when we did a drain cycle. We took off the front panel below and after that, it did not start. Does that tie in in any way to the problem.
    Sergeant:
    Champion:
  • 208 Answers
Get a repairman to look at them most likely the moters have either drawn moisture or stopped working period
Posted on Jun 22, 2009
  • jrnbudd Jun 22, 2009
    yes very possible
Whirlpool duet sport, fabric softener is not working
you probably have a clogged tube from some old softener that dryed up inside it
Feb 25, 2015 | Whirlpool Duet Sport HT WFW8400TE Washer
Why do the Automatic cycles on my Whirlpool Duet Electric Dryer not always work?
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.htmlGOD IS So GOOD !!!! AND THAT'S WHY MY ADVICE IS FREE
Jul 30, 2014 | Whirlpool Dryers
The light on my whirlpool duet dryer keeps blinking on all settings, won't start
push power button on push any cycle button hold down 3-5 seconds release push 4-5 times . if that don't fix it unplug for 30 min try that. let me know if it works might check lint trap also
Mar 18, 2013 | Dryers
Door won't open on whirlpool duet washer frontload
Press the cancel button twice to cancel the error code. There should be an error code flashing -- for example 'F02'.
Nov 10, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have a Whrilpool model LHW0050PQ4. Lights are blinking nonstop.
UR MAIN CONTROLLER NEEDS REPLACING. IT HAS A COMMUNICATION ERROR
May 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet washing machine will not start a cycle.
sounds as if its a door latch/lock issue, not recognizing the door closed will simply beep 3 times when the start button is depressed. try unplugging and replugging after 2 min.
Nov 17, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Flashing time lights...pressed cxl button...not working
Flashed f ...time light flash...pump starts to work...doesn't spin...doesn't cycle...
Oct 16, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft. Front-Loading Washer Logo
791 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
