Question about Xerox Phaser 8560N Laser Printer
Xerox Phaser 8560
It's my first day of a new job and I want to look like I know what I'm doing! Have installed new maintenance kit but printer still not working properly. Do I need a reset code for this? Could someone please assist?
Cheers,
Cath
  • 2 more comments
  • furioza Jun 22, 2009
    Hello and thank you for your assistance. It doesn't want to print. Installed the maintenance kit correctly according to the manual. I remember other Xerox machine needing reset codes. Would this also apply to this maintenance kit on the Phaser 8560?
    If I can't get this going, I am going to look like a real ditz on my first day...not a great impression to give a new employer!
    Cheers,
    Cath
    No error message/code is displayed. All appears to be inserted correctly. Simply prompts for replacement of Maintenance Kit.
    Door is closed properly. I've tried talking very sweetly to it, but it just sits there looking smug, while I look like a mug!
    Cheers,
    Cath
  • mnguy7764 May 11, 2010
    Yes, I know exactly what you mean! :-) When you restart the printer, does the printer itself have any error messages on the screen? Will it print a test page? I have seen with these, there is that refuse tray, I think it is called, take it out, put it back in and that will fix a lot of the error issues. There is a little sensor under the tray and sometimes it does not contact right, slide it back in place so it is contacting and then it may work.
    What exactly is it doing?
  • 212 Answers
You could also try rebooting the machine. i've seen it happen that the new maintenance kit was recognised as new after a reboot. choose the standard shutdown method...
Posted on Jun 22, 2009
Xerox 8560 displays replace incorrect maintenance kit
Was this a new maintenance kit? If it was new, try putting the old one back in, if it reports the same message, the pivot plate will more than likely need replacing. If it displays the original message i.e, replace maintenance kit, then the fault is with the new maintenance kit. Do check you have been sent the correct maintenance kit for your machine, part number should be 108R00675 for standard and 108R00676 for the extended Phaser 8560 printer and Phaser 8560MFP kit.
If it is the original maintenance kit and the error just appeared, as I am assuming you will have already tried re-seating it, the problem is likely to be the pivot plate again.
Hope this helps.
Jan 22, 2011 | Xerox WorkCentre C2424DN All-In-One Laser...
Phaser 8560 warns to replace the maintenance kit
Call Xerox. If they can't reset it, They will sent you a new Mtc kit. Thay will want that count sheet. Plus, They will not warrenty any kits over 6 months.
Sep 26, 2009 | Xerox Phaser 8560MFP Laser Printer
8560 DN Replace Maintenance Kit
the maintenance kit keeps your melted crayons from sticking to the roller. You know the smell... and no you need a new one.
Sep 15, 2009 | Xerox Phaser 8500/DN Printer
RESET INSTRUCTONS FOR XEROX 8560 MAINTENANCE KIT
There is no reset. Xerox never designed a supply reset for this machine.
If you installed a new one, either 1) you've got a bad one (get it replaced under warranty) 2)
the chip is not being read (due to drum maintenance camshaft cracked and out of position
Jun 03, 2009 | Xerox Phaser 8560MFP Laser Printer
XEROX Phaser 8560 - Maintenance Kit
They sell a lot of maintenance kits that way.I worked for a major Tampa are copier company for 10 years and they used every part until it just quit.However, you should line up a maintenance kit at the ready.Sometimes a counter will shut down the copier when it gets to the point where they want it to stop.
Apr 07, 2009 | Xerox Phaser 8560MFP Laser Printer
The maint kit resets the counter when it is installed. You may have gotten a bad maint kit or the black plasstic part that the roller slides into is bad. That is where the connection is to reset the counter.
Harry
Mar 18, 2009 | Xerox Phaser 8560MFP Laser Printer
Phaser 8400/8500/8560 maintenance kit
No, it will not work because the chip (CRUM) is not compatable.
Jan 13, 2009 | Xerox Phaser 8400 Laser Printer
Xerox Phaser 8560 Will Not Power On
The 8560 has a one year warranty. Call 1-800-835-6100 and they will come out and fix it.
Aug 07, 2008 | Xerox Phaser 8560MFP Laser Printer
Xerox Phaser  8560N Laser Printer Logo
508 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
