Question about Dynex 32 in. LCD Flat-Panel HDTV
Auto Scan doesn't pick up any channels.
Got all the channels on HD antenna after Auto Scan until change to digital. Now can't get any channels after Auto Scan. Anybody - please advise.
-wseeker
  • 3 more comments
  • Anonymous Mar 18, 2014
    please run channel auto scan
  • Anonymous Mar 26, 2014
    My tv is telling me to press channel auto scan and I can't figure out how to do that?
    can you walk me through the steps to scan for channels via antenna? When i hit menu it skips the 3rd option "CH"...i have an indoor antenna connected to antenna port
  • Anonymous Mar 27, 2014
    will not recieve any channels after scans
  • Anonymous Mar 29, 2014
    connected rca jacks and says to run channel auto scan
  • 11,896 Answers
In the main settings, there should be an option for AIR or CATV, air is for non-cable and CATV is for cable tv. This has to be on the correct setting before you autoscan
Posted on Jun 22, 2009
Do I need an hd convert box to get free channels
If you have a digital tv then no. Go to menu, click on input, click tuner or tv, click antenna, run auto scan for channels. Make sure antenna is hooked up. Digital antenna is preferred but not mandatory. If you're not getting channels move antenna re-scan for channels. Hope this helps!
Jan 29, 2016 | Televison & Video
19" Element HD Digital LED TV Model ELEFW195 Does not scan Digital Channels just Analog Channels.
Auto-channel search can't find digital channels - Community ...
community.insigniaproducts.com/...channel...can...digital-channels/.../13...
Aug 6, 2010 - When I ran the auto-channel search it could only find 4 analog ... Notgetting Digital Channels on NS-26L450A11 ... I've plugged the cable from the wall into the TV, and preformed the auto channel scan, with "cable" selected.
Troubleshooting Guide for Digital-to-Analog Converter Boxes
https://www.fcc.gov/.../troubleshoo...
Federal Communications CommissionIf you aren't receiving digital signals on your analog TV, you can purchase a ...antennas are designed only for reception of either VHF or UHF signals (but not both). ...The channel scan will automatically search for digital broadcast channels ...
Antennas and Digital Television ' Federal Communication
Jan 13, 2016 | Televison & Video
I just purchased an indoor antenna for to view local stations. Can i use an indoor antenna for my olevia 232-t11 lcd-hdtv? If I can, what steps do I need to follow?
Yes you can use an indoor antenna. Just make sure it is an HD antenna to get the digital channels clearly. You will have to do a scan to pick up local channels. In the TV menu, it will ask you if you want to scan for "cable" channels or "antenna" channels. You want to choose antenna.
Feb 11, 2013 | Olevia LT42HVi 42 in. LCD Television
How do I add the HD channels picked up my HD antenna to the master channel list on my Visio TV?
Hello, with the set on, press the menu button, move the cursor down till the "Tuner" section is hi-lighted, click on it. Then the first selection is "Tuner Mode" click on it, the choose "Antenna" click on it. Then move to the "Auto Channel Scan" and click on it, and let it set all your channels. when done, just exit menu and change channels as desired. you can go to page 39 in your manual for these instructions: Tuner Mode
Select Cable or Antenna depending
upon which equipment you have
attached to the DTV / TV Input.
Auto Channel Search
Automatically search for TV channels
that are available in your area. Be
sure to first select the correct tuner
mode above. The TV will search for
analog and digital channels. When the
search is done, press EXIT to begin
watching your programs. thanks, Terry
Oct 09, 2012 | Vizio M220NV 22 in. LCD TV
Cable in my area has switched to digital cable. I own a Hitachi HDTV about four years old. When I scan my channels it will only scan analog channels...the digital channels are an option but I don't...
Unfortunately, you need a set-top box. The Hitachi 65F59 has an ATSC (digital OTA) and NTSC (analog) tuner. It doesn't have a clear-QAM (unencrypted digital cable) tuner.
There are a few DVR set-top boxes with QAM tuners that you can buy separately. (You will need to make sure a given model is compatible with your service. FIOS uses a different option on the Cable Card than other providers.) Alternatively, you can get a cable box from your company.
Retrevo has the manual for this Hitachi TV here: http://www.retrevo.com/support/Hitachi-65F59-TVs-manual/id/371ci977/t/2/ . You will need to enter a code to access the PDF.
If you want OTA HD, you will need to determine the correct antenna for your area and the direction to the transmitters. (External antennas pick up more stations. In some areas amplification may be needed to get a good signal.) See antennaweb.org or tvfool.com for searches on the appropriate antenna to get a signal and where to point the antenna. Antennaweb assumes an external antenna but is very conservative in the received channel list. You would need to set the TV signal input to Air and rescan for channels if you choose to go with the OTA signal.
I wish that I had better news for you.
Sep 06, 2011 | Hitachi 65F59 65" HDTV
Hi, I live in a flat in London with a shared rooftop aerial (no idea of spec). I have a Sony KDL-46X2000. The built-in freeview tuner doesn't seem to recieve any HD channels. Is the built-in tuner the...
Make sure you have a good connection from antenna to TV. Check antenna and cable and cable connection to TV. Select DIGITAL button on TV remote when wanting HD channels. Remember HD channels are always digital. Also, any given TV station may not be broadcasting in HD at a given time. They can broadcast in digital but in standard definition sometimes. Your TV has a built-in DVB-T tuner. Try executing a channel scan to pick up all available channels. On-screen menus go to Digital Setup, then Digital Tuning, you can auto-tune or manual tune channels. The TV should take a few min. to scan thru available channels and store the channels its finds. Check with anyone in your area to see if they get HD channels (it is possible to be outside of the range of some TV stations) Your TV is a 2006 model and should still be compatible with local digital TV broadcasts but keep in mind digital signals could change in the near future (DVB-T2) and you may need a tuner/converter box to make the TV compatible.
May 01, 2011 | Sony Bravia KDL-46X2000 46 in. HD-Ready...
Dynex 32 Inch Installation Problem
Hi I Just Bought A Dynex 32 Inch HDTV. I Did A Auto Scan And It Didnt Pick Up Any Digital Channels? Am I Suppose To Have An Antenna Or Digital Box? How Do I Get Th Channels To Come In?
Nov 28, 2009 | Televison & Video
VIORE PLC7V95 7'' portable TV, cant get channels when scan
I notice that on mine, the positioning of the included tv antenna is very, very, very finicky. I also don't know how to "add" a new channel other than to hook it to the big house antenna and pick "re-scan" (or auto-scan or whatever it's called).
So I think your best bet is to pick a better antenna or know that even the tiniest fiddling with the antenna makes a diff. Sometimes, I even have the antenna horizontal (using the magnet) to get the good reception on a given channel. Seems like a hassle except that what should I expect from a tiny antenna....
Jun 15, 2009 | Televison & Video
Have a vizio lcd tv . can not get any channels today with the switch over to digital. i use an antenna
Your TV probably does not have a digital tuner connected to the DTV/ANT input. Mine didn't. I had to connect the digital antenna to a digital converter box THEN go to the DTV/ANT input. Only then would it activate the DTV menu and allow me to scan for channels. If your TV worked fine with Cable TV connected to the input, it was because your signal was coming from the digital tuner in your DVR, or your cable provider was sending you an unscrambled digital signal (not likely).
I used a digital converter box I had purchased with the government $40 coupon back in 2009 but the resolution is only 480 and looks like a Monet or Renoir. Now I am shopping for a high quality tuner.
Jun 13, 2009 | Vizio L32 32 in. LCD HDTV
How to get the dell 4200 ed to pick up digital channels
there are 2 coaxial inputs on the back of your tv. plug the antenna into the digital coax. with your remote, do a fac reset: menu, setup, fac reset, all settings, passcode 3355. after the reset, hit input, select digital tv. perfprm a chan scan: menu, setup, channel scan, antenna. this should solve the problem.
Feb 09, 2009 | Dell W4200 42 in. HD-Ready Plasma...
Dynex 32 in. LCD Flat-Panel HDTV Logo
2,436 people viewed this question
Top Dynex Televison & Video Experts
Jaime Hernandez
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
