Question about D-Link DP 301U (DP-301U) Print Server
Usb light does not light up and printer does not work
  • Raymond Ramirez
    Raymond Ramirez May 11, 2010
    try a different cable? then let me know
    Problem Solver:
  • 5 Answers
USB light only comes on when the server is transferring data or talking to the printer. It is not supposed to be on all the time.
Posted on Jul 31, 2009
Usb light link
HP LaserJet 1022 is a "host-based" printer so it must be connected to a PC. Load the driver on PC first and connect the USB cable when software tells you to do so.
Will not work on a Linksys print server.
LaserJet 1022N & LaserJet 1022NW have "special" HP print servers that can support HP host based printers.
Nov 27, 2013 | Linksys Wireless-G WPS54GU2 Print Server
Hi, The power cord is connected. The green light inicates that the printer is on. Pressing the button at the green light and the printer will print a page. However when we try to send print jobs from out...
If the printer is printing a test page (by pressing the button on the printer) it means printer is fine. There are only two things that could be having any issues. 1. The printer drivers and 2. the USB Cable. So, I suggest that uninstall the printer and reinstall the printer drivers (It should print the Test Page after driver installation). I have come accross such issues with USB printer and replacing the USB cable has always fixed the problem.
Good Luck!
Hope this helps!
CreativeTECH
Dec 13, 2010 | HP LaserJet 1300 Printer
Printer connected but not printing
If your printer has a network port you should be using the network adapter.
Otherwise you want to make sure you connect the printer with a USB cable to the appropriate port on the D-Link.
Once the USB cable is connected you should be able to add the printer from your computer as a shared printer.
You will not normally see any activity lights on your router for the USB connection because it does not send or receive information the same way the LAN cables will.
I do recommend a LAN cable though as it works much better with routers. If your printer does not have one I would look into getting a network printer.
Thanks,
Pat
May 12, 2010 | D-Link DP 300U (DP-300U) Print Server
Light is blinking, doesnt print, it prints before but now it doesnt. appears online and ready on the computer.
If the port had been changed to LPT1 the printer will not work.
LPT1 is the large parallel port, while you are using USB on this printer.
the red light came on probably because of a jam , or because of one of the documents in the printer cue.
The easiest thing to do is
Unplug printer usb.
Go to control panel>installed printer.
Delete all the instances of this printer from there and chose to delete drivers if asked.
Reistall the printer using the printer disk, plug in printer data cable only when asked by setup wizard.
If you have a different USB cable, also use it, just in case.
If that does not fix the problem , then there is an internal fault in the printer.
Regards.
Jun 01, 2009 | HP DeskJet D1460 InkJet Printer
Resume light coming on but printer won't work
Normal 0 Probably has corrupt driver.
Try disconnecting the Camera from the USB port and reinstall the software program. When the program asks you to connect the camera to the USB port, do so and it should work.
Hope this helps. Bud
Jan 03, 2009 | Office Equipment & Supplies
Canon Pixma iP2000: yellow power light blinks-reset doesn't work
Normal 0 Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Jan 02, 2009 | Canon PIXMA iP2000 InkJet Printer
Edimax 6215 - Printserver doesn't work
if your usb light is not lit-there's a chance that your usb led is busted, usb cable is defective or printserver is defective itself.
if your going to connect your printer directly to your pc using the same usb cable and if it works that way. then it could be that your printserver is not working fine.
Dec 05, 2008 | Edimax 4 Port Wireless AP Broadband Router...
Pixma 160
Chances are you reconnected the printer to a different USB port and your default is still set up for the other port...
Look at your printer settings and chances are it set up the printer again for the new port.
Either change your default printer or move the cable back to the original port.
Jan 18, 2008 | Canon PIXMA MP160 All-In-One InkJet...
D-Link DP 301U (DP-301U) Print Server Logo
843 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
