Question about Konica Minolta Magicolor 2530 DL Laser Printer
Konika Minolta 2430 DL won't let me print
I have plenty of black toner that I would like to use on an important print. But my printer tells me that because it is low on yellow toner, it will not print. Is there a way to bypass this annoying feature of my printer so I can print?
Look through the menus on the printer for a setting for "Low Toner" -- the choices of what to do are usually either "continue" or "stop" or something similar (my 2430DL has this option setting) -- set this option to "Continue".
My 15 year old HPs also have a similar setting. However, this will keep it printing when the black runs out, so you will need to check your print production run visually as you go along to make sure the quality is what you need
Posted on Nov 08, 2009
    President:
  • 3,085 Answers
No. sorry. Your printer mixes all colors for all prints.
Posted on Jun 22, 2009
  • 210 Answers
Contrary to the previous solution, laser printers do not mix colors. However, the answer is still no. If you are pressed, there are two things you can do temporarily.
First, to squeeze out just a little more life from the yellow toner you can resettle the toner. Remove the yellow toner cartridge, hold it horizontally, and shake end-to-end. This might even rectify a false reading of low toner for the cartridge. It does this by loosening any possible clumps in the remaining toner and reactivating the static charge between the particles.
Second, add black toner to the yellow toner cartridge. This will obviously mess up any colored print consisting of any mixture of yellow while the black toner is in there. But, it will allow you to print until you can replace or empty and properly refill the yellow toner cartridge.
Posted on Aug 31, 2009
Konica Minolta 2430 DL has Smudges or dots on page
Not an expert on this brand of printers but it looks like dirty feeder rollers to me. Try cleaning them and Print a Blank document and see if the marks show up
Jan 24, 2014 | Konica Minolta magicolor 2430 DL Laser...
Have a Konica Minolta 2430 DL and it ask me to install blk toner after install toner it has error line 2408. can you help me?
2408 means that the toner cartridge you are trying to rotate to is already in the top position or you need to install another toner cartridge before you can rotate to the color you want to replace.
To fix the toner not installed message clean the three contacts on green chip on the right side of the toner cartridge. You may see black lines on them. Use an eraser or rubbing alcohol.
Nov 11, 2010 | Konica Minolta magicolor 2430 DL Laser...
I am unable to remove the black ink cartridge from my Konika Minolta Magicolor 2430.
I got someone else in the office to do it that wasn't as worried about "breaking" something!
Sep 29, 2009 | Konica Minolta magicolor 2430 DL Laser...
Konica minolta 2530 dl Replaced black cartridge now says others not installed and "cannot rotate cartridges"
Clean toner chip reader, remove OPC drum and all toners, under the toner rack there is a 3 pin chip reader, use pressure air to clean it.
Jul 21, 2009 | Konica Minolta magicolor 2430 DL Laser...
After replacing black toner cartridge printer displays Drum Low
The drum and the black printer cartridge are two separate items. You will have to purchase a new drum for it. I just had to do the same thing and it ran me $150.00 at Staples.
May 19, 2009 | Konica Minolta magicolor 2430 DL Laser...
White vertical stripe on color images when they're printed
You may have some dust on the imaging window (printer head). Remove the toner cartridges and clean it with some tissues.
Apr 28, 2009 | Konica Minolta magicolor 2430 DL Laser...
2430 DL Kon/Min laser, b&w only
Hey
in printer menu you have to look up some setting and tell the printer to continue printing when toner emty, you'll find it in gualiti menu or engie menu, i dont remember exactly.
second i think you still need to have all toners installed, if C is installed but shows no toner, then you have to clean chip reader under the toner rack.
Sep 11, 2008 | Konica Minolta magicolor 2430 DL Laser...
Magicolor 2430 DL vertical white blank stripes
remove PC drum and under that you can see laser glass, clean it and reinstall.
Aug 28, 2008 | Konica Minolta magicolor 2430 DL Laser...
Toner Cartage
Really Magicolor 2430DL is a very worst printer in this world.
within 2 months drum cartridge finish - no other printer like this type of option - like black, color & durm cartridge.
I will recommend - not to go for the thirdclass cartridge. go for only HP.
thanks
anil - dubai
Feb 20, 2008 | Konica Minolta magicolor 2430 DL Laser...
Konica minolta magiccolor 2430 dl
Under Quality Tab you have the option for B/W printing.
Nov 29, 2007 | Konica Minolta magicolor 2430 DL Laser...
Konica Minolta Magicolor 2530 DL Laser Printer Logo
615 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
