Question about Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE4T washer
I have code FH flashing. This happens no matter what cycle I put it on, hot/cold/rinse only. HELP!!!
Thanks
  • 2 more comments
  • steverusnack Nov 06, 2007
    i have an he3t and i am getting a "fh" code. 1 minute into the start of the wash this happens and it beeps, then the wash setting button light blinks.????
  • jhaddad Dec 17, 2007
    Got the same problem in the middle of a cicle it appears a H an F
  • Anonymous Mar 27, 2014
    doesnt matter which operation we put the washer it, it won't perform any cycle
  • Anonymous Mar 30, 2014
    goes through the cycle, ndoes not rinse flashing f02
Get the same code 2 minutes into cicle. F H
Posted on Dec 23, 2007
My Whirlpool Duet ht Washer starts washing fine, it drains then it starts flashing FH and wont take in water for the rinse cycle. It does this for every cycle, it will wash fine but after it drains and is...
The first thing I would check is shut off the cold water valve at the wall and remove the hose at the washer.carefully pry out the little screen in the inlet and clean well,reconnect hose and turn water back on FH is a water inlet issue I am hoping that what is happening is that when the washer starts its wash cycle it is probably filling with warm (hot) and cold water at the same time even though it might be mostly hot,but when it comes time to rinse (cold water ) there is not enough to make the computer happy and you get your FH error.. Hope this Helps,,If not your probley looking at a new fill valve assy
Sep 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Error code FH on my AWM, what does it mean?
"FH" is a No Water Detect error.It is an indication that you either have no water coming into the washer, or very little water at all. Check whether the water taps are turned on sufficiently, the inlet hoses are not kinked, the water inlet valve is not clogged, you don't have a siphoning issue, and/or the drain pump is working.
Thank you !!
Jul 12, 2010 | Whirlpool AWM8163 Front Load Washer
Stop frequently on spin and rinse cycle F6 code
I have a Kenmore Elite he4t front load washer that was working fine and then we moved and now it stops washing midstream and flashes an F and a H. I have to pause and restart then it will stop washing again after a few minutes and flash the same codes again. I reset again and then it stops with 1 minute left and will not drain.
Apr 06, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite quietpak9 HE4T washer FH error code
take the lid off attached to the inlet valve to the dispenserr you will see a little white mechanisim in line with them. this is called your flowmeter take it off and blow through it is should sound like a cazoo. put it back on and try to do a wash cycle. if this doesn't help you need a new flowmeter. also if you take the kick panel off you will find the tech sheet to help you diagnose this problem.
Jun 23, 2009 | Kenmore Elite 45986 Front Load Washer
FH error on Kenmore he4t only happens when using hot or warm h2o
take the lid off attached to the inlet valve to the dispenserr you will see a little white mechanisim in line with them. this is called your flowmeter take it off and blow through it is should sound like a cazoo. put it back on and try to do a wash cycle. if this doesn't help you need a new flowmeter. also if you take the kick panel off you will find the tech sheet to help you diagnose this problem. Always first check your hoses if you have flood hoses get rid of them next get a bucket and see if water is comeing out of the hoses next check you inlet valve screens see if there is sand in them if there is clean them.
Jun 11, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE4t washer won't spin
The motor controller board is likely bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 06, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE4t cycle time blinking but nothing happening
remove lower panel reach up to lock area and pull down on tab to release door remove as much water as possible go back to bottom and turn pump clean out to left HAVE PLENTY OF TOWELS HANDY..clean pump trap out and reinstall
Nov 09, 2008 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Kenmore Elite 45986 Front Load Washer Logo
453 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
