Question about Brother HL 5140 Laser Printer
Won't print My printer ran out of paper in the middle of a job. I added paper and the printer sounded like it was going to print but it did not. The light is flashing for the paper indicator and the status light is red. I opened the printer looking for a paper jam but did not find one. I turned everything off and on and that did not help. I looked for a reset button but only found the off/on switch and I did turn the printer off for a while but to no avail. It does not matter if I try printing from the menu or use Ctrl P it still does not print. I'm stumped.
    Problem Solver:
  • 12 Answers
Re: Won't print
Take the paper tray out, tilt the print backwards. Under the printer at the front you will see what looks like black hook. This is a paper sensor and should move easily, completely freely. Sometimes this can dislodge and become ridged. Check this. Of course remember to clean the paper pick up roller and pad.
Posted on Apr 25, 2008
  • Brother Master
  • 1,113 Answers
Re: Won't print
I'd guess that the machine is unable to pick up the paper so goes into jam mode, paper feed roller is worn, needs screwdrivers and parts.
Here is PARTS also needs little japanesse type fingers, gentleness, then a few bits come off from left side, spring, solenoid, and a couple of gears then tray out, 6 screws release base, few more bits and your done.
You should feed ok from bypass tray still and can have a dodgy attempt at fix by wiping paper feed roller(3cm rubber funny shaped roller sits front centre under with tray out) with something to clean it free of paper dust. ie metho, water.
Posted on Dec 26, 2007
0 characters
3 Points
I have an MG2200 Pixma printer. It stopped printing in the middle of a delayed queue because it ran out of paper. I put the paper in and then I think I turned it off and then on again. It will not...
Log off your computer so it shuts downs.
Log back on
Go to control panel
-Find Printers
-Click on Printers
Plug your printer into computer
-Printer should show up on screen
-Right Click on Printer and set as default
-Left Click on printer
-Click on see what printing
-Cancel job that's printing
Close printer
-Try to print again
Nov 02, 2013 | Canon Printers & Copiers
Lexmark T640 LCD blank..
To check if this is a hardware issue, please print a menu settings page. The purpose of this diagnostic is to check if this is a software issue or a hardware issue.
1. Press Menu to display Menus.
2. Press "down" until the "check" appears next to Reports.
3. Press "Check".
4. Press "down" until the "check" appears next to Menu Settings Page.
5. Press "check".
The message Printing Menus Settings appears on the display.
The printer returns to the Ready state after the menu settings page prints.
If the menu settings page printed without the dots, this would be a software issue. In that case, please call our Technical Support Hotline on (800) 539-6275.
Aug 17, 2012 | Lexmark T640 Laser Printer
On my home wireless network, my notebook computer's print jobs go to the correct printer but won't stop printing until it is canceled from the device manager. The PC that is on the network wor
sounds like the print job queue is overloading the wireless network, causing a hang on that side
big print jobs do that even on wired systems might consider adding more printer memory
May 26, 2012 | HP P2035n Laserjet Printer Monochrome
Printer won't print. I went to printer and it says there are 9 items to br pringted in queue but they won't print Printer says it is ready
Good Day Nanawhit!
That happens all the times when first print job encounter a problem and stops printing and it was followed by series of print jobs. Some reasons for stop printing could be a printer out of paper and printer not set as default printer.
The best way to fix it is to cancel all pending jobs. When print jobs window is cleared off pending print jobs, restart your PC and your printer. Then go to your printer and make sure it is the default printer.
After that try printing a test page. Once a test page is successful, you can now print as many as you want.
Jun 10, 2011 | Lexmark X2670 All-In-One Printer
Red light stays on and printer won't print
My C60 Epson Stylus printer is not printing. First of all the paper jammed, I pull the paper from the front and since then the catridge holder is not going to the middle to print. also the green light keepon flashing and the red light stays on. I need your help.
Jan 16, 2010 | Epson Stylus C60 InkJet Printer
My HP Officejet 4300 all in one stopped printing. Ran out of paper in middle of job. It acted like it jammed but there was no paper to jam. When I refilled the paper slot, it would not print. Deleted...
many times it happens the Cartridge rack get jammed on roller during paper jam.. so please find out the movement of cartridge over the rack is smooth or not.. reply me with your observation
Oct 08, 2009 | HP Photosmart D7260 Printer
Multiple page print job doesn't finish when paper runs out
This printer should continue to work one paper is added. If not hitting the continue button (Top silver button with an exclamation mark on it) should allow it to resume.
After that can you tell me what the blink sequence is being displayed on the panel?
Jun 17, 2009 | Lexmark E232 Laser Printer
HP 1350 all-in-one ran out of paper.
Every time this device runs out of paper, it's a hassle. I powered off the pc and the printer, and then moved the usb cable to another usb port. Power on the printer and after it has gone thru its startup, power on the computer. Then the jobs in the queue printed just fine.
Apr 14, 2009 | HP PSC 1350 All-In-One Thermal Printer
Lexmark x1240 printer will not print.
Keep your paper feed under 15 pages. The paper will tend to pull to the right, but it will print correctly on the printed page. 20 to 25 pages in the feeder will result in a paper jam. To find the status on the print job, go to your control conter and hit printers. Choose your spicific printer and you may beable to save the printjob.
Apr 16, 2008 | Lexmark X1240 All-In-One InkJet Printer
Brother HL 5140 Laser Printer Logo
153 people viewed this question
Top Brother Printers & Copiers Experts
Jim Yeh
Level 1 Expert
Jesus  Colon
Jesus Colon
Level 1 Expert
Rick Johnson
Rick Johnson
Are you a Brother Printer and Copier Expert? Answer questions, earn points and help others
